stevegallacci Posted January 19, 2016 Author Posted January 19, 2016 (edited) And some more progress. To help the look of the thing, I'm rescribing pretty much everything, both in that the existing lines are too faint (an odd thing to complain about) and that most of them are either wrong or missing. The one thing I haven't dealt with is the rather fat wing, especially the thick leading edge, which skews the look of the wing to engine joint. Edited January 19, 2016 by stevegallacci fab and Wurzacher 2
Kahunaminor Posted January 20, 2016 Posted January 20, 2016 Hi Steve, Pulling up a chair to watch. Regards,
stevegallacci Posted January 23, 2016 Author Posted January 23, 2016 More progress. The panel lines are not perfectly accurate, in part due to the not quite accurate shapes involved, but look better than the kit versions. Wurzacher 1
Guest Peterpools Posted January 24, 2016 Posted January 24, 2016 Steve Excellent work on the panel lines, both correcting and adding Keep 'em coming Peter
stevegallacci Posted January 26, 2016 Author Posted January 26, 2016 And some more progress. Wurzacher and Mebo 2
Out2gtcha Posted January 26, 2016 Posted January 26, 2016 Excellent.....................I think the re-scribe on the fuselage top looks really great
Out2gtcha Posted January 26, 2016 Posted January 26, 2016 I havnt dug out my 234 in more than a year, and this has me curious how accurate my kit is
stevegallacci Posted January 26, 2016 Author Posted January 26, 2016 I havnt dug out my 234 in more than a year, and this has me curious how accurate my kit is Which kit is it? A few posts back Radu mentions some good drawings, seems that every thing else is pretty bunk, so that is a major factor. Out2gtcha 1
Out2gtcha Posted January 26, 2016 Posted January 26, 2016 (edited) Which kit is it? A few posts back Radu mentions some good drawings, seems that every thing else is pretty bunk, so that is a major factor. Sorry, failed to mention that..............it is in fact Radus/MDCs resin Ar-234. Not an expert on the 234 in any way, so was curious about the differences between the Fly version and the MDC kit. Edited January 26, 2016 by Out2gtcha Alburymodeler 1
stevegallacci Posted January 26, 2016 Author Posted January 26, 2016 Sorry, failed to mention that..............it is in fact Radus/MDCs resin Ar-234. Not an expert on the 234 in any way, so was curious about the differences between the Fly version and the MDC kit. If it's Radu's version, is likely going to be spot on. The Fly kit has some good looking details, but the general outside of the kit is based on rather weak data. See the early snap a to see how far off the control surfaces were when I started. Out2gtcha and Wurzacher 2
Wouter Posted January 27, 2016 Posted January 27, 2016 That's just mad... I've bought the Fly Ar234 too, but on second thought it would have been wiser to go for the Radu/MDC resin kit. I don't need a rivet perfect kit, but seeing what you have to do to get it even close is to the real thing is just.. well, I can't wrap my head around it. Good job btw!
stevegallacci Posted January 27, 2016 Author Posted January 27, 2016 That's just mad... I've bought the Fly Ar234 too, but on second thought it would have been wiser to go for the Radu/MDC resin kit. I don't need a rivet perfect kit, but seeing what you have to do to get it even close is to the real thing is just.. well, I can't wrap my head around it. Good job btw! I haven't done anything major, just filled in some rather faint lines and scribed some new ones. The only other thing I'd recommend doing to improve the look of it would be to sharpen the wing leading edge, as the kit has a rather fat leading edge radius. In all, only a step up from basic build 101. D Bellis and Out2gtcha 2
JRutman Posted January 28, 2016 Posted January 28, 2016 Nice job so far. I didn't even know this kit existed! Radus' kit would be hard to top I think but you work with what you have right? I built this plane years ago but then only the Combat models vac was available. J
Guest Peterpools Posted January 28, 2016 Posted January 28, 2016 Super progress Keep 'em coming Peter
Chris Wimmer Posted January 30, 2016 Posted January 30, 2016 (edited) Here is the kit versus my replacement intake/centerbody for the jumo. The brass tube extension fits to the cut-off intake section of the kit. Hi Steve, felt a bit concerned about your assertion the Trumpeter air intake was too short. Stopping by at the museum yesterday I found you are absolutely right. Keep up your good work that I'm following with interest! Cheers Chris Edited January 30, 2016 by Chris Wimmer mattlow, fab and Wurzacher 3
