Airfix 1/24 Spitfire Mk IA.... Yet another question 12/28
Hi Barry;
You might already have this covered, but Edgar once told me that Battle of Britain Spits would almost certainly have the metal seat fitted as opposed to the composite seat...so it will need to be painted green not the reddish brown colour.
Which particular aircraft a you planning to do?
Best regards;
Steve
Hi Barry;
Best regards;
Steve
"Battle of Britian Spitfire" is a broad term, and too general to determine which seat (amongst other changes) would be appropriate.  According to Edgar's research, plastic (i.e. the redbrown seat) were approved for use from May14th, 1940.  So if your "BoB Spit" was built after that date, then it could have had a plastic seat, but before that date, it would seem a metal seat is appropriate.
Doug
Quite correct Doug, I should have been more specific, so thank you for the reminder of the date. It would be very helpful to know which particular airframe Barry is building. That could determine a whole host of factors which might need considered for the build. Apparently, no seat armour before June 1940, but it was rushed into service after that date. I imagine that there must have been quite a few Spitfires using the older hand pump undercarriage retraction as well during that period too.
Best regards;
Steve
The night* and white underside scheme was in use from 1938 until June 1940.
How quickly existing aircraft were repainted to Sky was likely a matter of weeks rather than overnight, allowing for the new colour to be distributed and confusions over Sky Blue and Sky Grey to be settled.
It occurs to me that we really need an Edgar Brooks Memorial Archive where the results of all his original research could be collated, preserved and perhaps even added to. As it is, loads of his nuggets of information are salted away in forum posts randomly scattered.
* The black colour would actually be 'night', a mix of Carbon Black with Ultramarine pigment added for durability but it should not look blue-ish.
A very dark grey would be more suitable for scale models
Edited by Chek
I had wondered who would rise to the mantel of "Resident Spitfire Aficionado" not meaning that one can or should be able to replace someone like Edgar.
I like your suggestion! :thumbsup:
Barry
  • 2 weeks later...
