LSP_K2 Posted January 15, 2016 Share Posted January 15, 2016 I don't believe that's the same aircraft, D. The particular machine I'm referring to, was with the 531st FS, 21st FG, Iwo Jima. Link to comment Share on other sites More sharing options...
D Bellis Posted January 15, 2016 Share Posted January 15, 2016 I don't believe that's the same aircraft, D. The particular machine I'm referring to, was with the 531st FS, 21st FG, Iwo Jima. Interesting that two airplanes from the same Fighter Group on the same island would have the same name. What colors were the 531st? White outlined with Black? D Link to comment Share on other sites More sharing options...
LSP_K2 Posted January 15, 2016 Share Posted January 15, 2016 Interesting that two airplanes from the same Fighter Group on the same island would have the same name. What colors were the 531st? White outlined with Black? D Indeed it is. Yes, white, outlined in black with white spinners, black cowl fronts. Here's another photo, though not the one I was looking for. Name is not exactly the same either, as this photo amply illustrates. Also, while doing some Googling for further 21st FG information, I stumbled upon this site, and though not dedicated to any particular squadron or group, nonetheless has some pretty cool Mustang photos. D Bellis, Out2gtcha and sandokan 3 Link to comment Share on other sites More sharing options...
Brad-M Posted January 16, 2016 Share Posted January 16, 2016 Hey Eli, Don't forget Shangri-La I'm in too!! Brad lawman56 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted January 16, 2016 Share Posted January 16, 2016 Are those inner gear doors sagging? I thought they didn't sag open when sitting? OK, I'll get my coat. LOL Link to comment Share on other sites More sharing options...
Brad-M Posted January 16, 2016 Share Posted January 16, 2016 Ron, I thought that eventually when the air bleeds away, the doors will open. Brad Link to comment Share on other sites More sharing options...
Guest Posted January 17, 2016 Share Posted January 17, 2016 I believe you are correct....Harv Link to comment Share on other sites More sharing options...
LSP_Ron Posted January 17, 2016 Share Posted January 17, 2016 Sorry Brad, my post was just a bad joke. When the Tamiya kit came out there was "the great door bleed debate", did they or didn't they bleed down.... Ron Brad-M 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted January 17, 2016 Share Posted January 17, 2016 Yup, I agree 100% Link to comment Share on other sites More sharing options...
Juggernut Posted January 17, 2016 Share Posted January 17, 2016 (edited) My Take on the clamshell door issue (without having looked at the hydrauic system schematic in a while): Without positive hydraulic pressure (caused by said dump of hydraulic system pressure with the cockpit control) in the clamshell door actuators holding the doors closed, the weight of the doors (mass x gravity) will overcome the static pressure in the actuator which will cause the doors to open albeit very slowly (there are no mechanical uplocks for the clamshell doors when the gear is down and locked) especially if the seals are tight. The fluid that was in the "upside" of the actuator will be displaced back to the reservoir. Eventually, if left alone for the right amount of time, those clamshell doors will open most of, if not all the way. From what Jennings has observed, that amount of time may be longer than the "between sortie time". Edited January 17, 2016 by Juggernut David66 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted January 17, 2016 Share Posted January 17, 2016 I don't want to go into the full argument, but since this thread is about the B/C, isn't it true the B/C had mechanical system so the doors stayed up? Or was that the A I am remembering? Link to comment Share on other sites More sharing options...
Bill M. Posted January 17, 2016 Share Posted January 17, 2016 What I've always understood is that all of the P-51's had their landing gear doors and flaps controlled by a hydraulic system and that when the system was pressurized, the interior landing gear doors would be up. When everything was shut down and the hydraulic pressure would bleed off, sometimes over several hours, the doors would gradually descend. This is why Weser them in all sorts of positions. I don't know for sure about the flaps, but I'm pretty sure the they would descend too with the bleed-off of hydraulic pressure-- I just don't know if it was gradual or not. Bill M. David66 1 Link to comment Share on other sites More sharing options...
ironman1945 Posted January 17, 2016 Share Posted January 17, 2016 When I converted my Hobbycraft Mustang IA back to a Mustang I (you can see it here, if you like http://forum.largescaleplanes.com/index.php?showtopic=30710&hl= my research indicated that Allison engine Mustangs had mechanical latches which locked the landing gear doors in the up position when on the ground. This latch could be mechanically released for maintenance, if required. From what I remember this did not apply to B/C/D Mustangs. Dave/Ironman1945 D Bellis and David66 2 Link to comment Share on other sites More sharing options...
LSP_Ray Posted January 17, 2016 Share Posted January 17, 2016 When I converted my Hobbycraft Mustang IA back to a Mustang I (you can see it here, if you like http://forum.largescaleplanes.com/index.php?showtopic=30710&hl= my research indicated that Allison engine Mustangs had mechanical latches which locked the landing gear doors in the up position when on the ground. This latch could be mechanically released for maintenance, if required. From what I remember this did not apply to B/C/D Mustangs. Dave/Ironman1945 That is what my feeble memory was trying to recall! So it was A's then. From B's on it was simply hydraulic. Thanks, Dave! Link to comment Share on other sites More sharing options...
Night Hog Posted January 17, 2016 Share Posted January 17, 2016 It should be clear to HKM that a lot of folks are drooling for the 51B/C. Every day you wait is money lost. BTW I have been working for some time on a Trumpy/ZM Frakenstang. All looks good except for the not laminar flow wing. I am sure that the day after I finish it, the HKM kit will hit the shelves...soooo back to work. Kagemusha 1 Link to comment Share on other sites More sharing options...
