Totalize Posted April 5, 2017 Author Share Posted April 5, 2017 Anyone know if the RB Productions cockpit harnesses are paintable? R Palimaka 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted April 5, 2017 Share Posted April 5, 2017 I think the RB Productions harnesses are made of paper with a high rag content, so they could probably be stained or painted I would think. Link to comment Share on other sites More sharing options...
Totalize Posted April 5, 2017 Author Share Posted April 5, 2017 (edited) Thanks RP. I will post a picture of my work on the harness. I got some spill over of white glue around the PE/brass eyelets and it turned the paper a brownish colour. Just call me Mr. Hamfisted. Dave. Edited April 5, 2017 by Totalize R Palimaka 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted April 5, 2017 Share Posted April 5, 2017 Ooh...that's annoying...but a good warning for when I do mine. Hopefully it will all turn out as good as the rest of your work so far! Richard Link to comment Share on other sites More sharing options...
Totalize Posted April 5, 2017 Author Share Posted April 5, 2017 (edited) Yeah. I will have to make the best of it. Here's a picture. You can see some of it around the eyelets. I am not too worried about the top of the harness as photoetch piece is suppose to go there and you won't really see it once its in the cockpit. Not sure if the white glue I used had some issue either. I didn't use Elmers. Damn. Edited April 5, 2017 by Totalize Shaka HI, mpk and MikeC 3 Link to comment Share on other sites More sharing options...
Totalize Posted April 17, 2017 Author Share Posted April 17, 2017 (edited) Well, guess what? I seemed to have misplaced the rest of the seatbelt straps that came with RB productions set. I ordered another set but I thought I would take a stab at using flat lead strips. Fortunately, the set I have were the right width for the remaining harness pieces. The cool thing about this material is its sort of/kind of realistic in that the I can adjust the length of the straps. Anyway, I don't know if I am going to use them as I am not super confident I can match the colour with the original paper ones. Take a look and let me know what you guys think. Edited April 17, 2017 by Totalize mpk and MikeC 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted April 17, 2017 Share Posted April 17, 2017 Nice work! Kev mpk 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted April 18, 2017 Share Posted April 18, 2017 Looks just fine. Paint it and give a light wash - with the belts in place in the model, only you will know notice that they were lead replacements! Link to comment Share on other sites More sharing options...
Totalize Posted April 28, 2017 Author Share Posted April 28, 2017 (edited) HI Guys, Back with another update. The cockpit is now complete and the fuselage halves are together. I painted and weathered the harness by first spraying it with a gloss coat then painting it with a very thin layer Vallejo Model Color acrylics. After that I gave it a wash with oils. I tried to scratch the bayonet mount that attaches to the rear of the harness. I still need to add the hanger cable. I have a single rod coming off the rear of the bayonet housing which may not be correct. I used the diagram from my spitfire book to make it. I also decided to add the oxygen hose. I made this with copper wire wrapped around a pin vise bit, then bent it to shape and filled all the gaps with some automotive putty. While the putty was still wet I scraped off the excess to reveal the ridges of the hose. After drying I gave it a light sanding. The Diagram I used. The triangle front section I have hidden by the metal plate below the regulator. Edited April 28, 2017 by Totalize Shaka HI, MikeMaben, MikeC and 2 others 5 Link to comment Share on other sites More sharing options...
Totalize Posted May 3, 2017 Author Share Posted May 3, 2017 (edited) I am about to put on the domed rivets for the aircraft using the Archer set. The Tamiya "How to" build the Revell Spitfire has the domed rivets going past the cockpit to the front of the fuselage above the wing root. In looking at some pictures on line and this does not look correct. It seems all the rivets from the cockpit forward were flush? Any input would be much appreciated. Edited May 3, 2017 by Totalize MikeC, mpk, Maurice and 1 other 4 Link to comment Share on other sites More sharing options...
Shaka HI Posted May 3, 2017 Share Posted May 3, 2017 Do what the pictures you find say... (Or wait for Martin.) Cockpit looks good! mpk 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted May 3, 2017 Share Posted May 3, 2017 I am not a Spitfire expert, and even less the late Edgar, but my understanding is that the flushed rivets were ahead of the cockpit, and the domed ones behind. (In kit form, the best surface detail is still probably the 1969 Revell Mk. 1 kit) Hubert mpk 1 Link to comment Share on other sites More sharing options...
Iain Posted May 3, 2017 Share Posted May 3, 2017 Yup - domed only from rear of cockpit back (frame 11) - as per that photo. Iain Chek and mpk 2 Link to comment Share on other sites More sharing options...
Totalize Posted May 4, 2017 Author Share Posted May 4, 2017 (edited) Thanks a bunch guys. Your input is very helpful. Working on the rivets now. Will post a couple of pics. Cheers! Edited May 4, 2017 by Totalize mpk 1 Link to comment Share on other sites More sharing options...
Chek Posted May 4, 2017 Share Posted May 4, 2017 Yup - domed only from rear of cockpit back (frame 11) - as per that photo. Iain ... although Supermarine did build a fully flush riveted Spitfire, on which they conducted aerodynamic experiments using split peas glued on to simulate domed rivets. Presumably not removing them one at a time.... That's how they discovered that aft of frame 11, the cheaper and quicker to manufacture domed rivets made little difference to top speeds. mpk 1 Link to comment Share on other sites More sharing options...
