dutik Posted November 24, 2015 Author Share Posted November 24, 2015 I think I have less issues with my 35 years old Revell Mirage than you get with your 21 century kit ......Happy modeling mate Alain Depends... Fit of large parts is on par. Casting of the ancient Revell kit is much better without mold lines, surface steps and ejector marks on visible surfaces. Intake area needs some putty and sanding for both kits. Revells approach to the intake area is much better than Italeris, but without an intake duct inside the fuselage. Italeri is ahead with surface details and any small parts like cockpit and UC/UC bays. If you want to engrave Revells kit and add decent details to all the "pits" and all that small parts like air scoops then this adds considerably to the workload. And the external stores from Italeri are good enough to be sold as an aftermarket set right on its own. Will show some images of my Revell kit soon. I've got the large paneel lines in place, but still on the way to add all that small inspection covers all around. Not to mention to fix the places where I slipped with the engraving tool or misaligned the whole line... Regards - dutik Harold 1 Link to comment Share on other sites More sharing options...
dutik Posted November 24, 2015 Author Share Posted November 24, 2015 Here is to the left the intake with the too short part of the intake "mouth": One of the Revell wings engraved: There was some warp at the leading edge that was ironed out, remaining gaps filled with putty and sanded flush. Also added an extra to Italeris wing: A hollow square profile as wing spar to keep the wings straight and to get them horizontally aligned. And a glimpse at the Revell kit / Dagger that I am still rescribing: Enjoy! - dutik alain11 and Kagemusha 2 Link to comment Share on other sites More sharing options...
rafju Posted November 24, 2015 Share Posted November 24, 2015 "A hollow square profile as wing spar to keep the wings straight and to get them horizontally aligned"Hi Dutikbe careful with the wing dihedral, it must be of -1°.Raf Link to comment Share on other sites More sharing options...
dutik Posted November 24, 2015 Author Share Posted November 24, 2015 Watch these my empty hands! Avra-kedavra! (harrg-press-bent-shape) Ta-daa! A magic dihedral! Will keep this in mind - dutik Link to comment Share on other sites More sharing options...
karimb Posted November 24, 2015 Share Posted November 24, 2015 looking great Dutik! Link to comment Share on other sites More sharing options...
ClumsyDude Posted November 24, 2015 Share Posted November 24, 2015 Loving every update dutik ... you're doing a great job mastering the old revell kit. Jim Link to comment Share on other sites More sharing options...
karimb Posted November 25, 2015 Share Posted November 25, 2015 great progress Dutik Link to comment Share on other sites More sharing options...
dutik Posted November 27, 2015 Author Share Posted November 27, 2015 (edited) The frontal intke plates are in place. Watch that gaps where the intake lip meets the fuselage, both intakes. There are also some other places that are in need for a styrene wedge to get them closed. Feels like building a short run kit or something made by Mach2, Toga or AER. Don't walk away, RUN! OK; I will get this fixed, but it might take some days... The foil is a new Tamiya product: Yellow tape fitted to foil of a half meter width. Great idea if you want to cover areas that don't react well to tape, like bare metal finishes or large decals (like "wooden" surfaces). Wrapped the cocpit into it to avoid dusting. Meanwhile adding details to the pilot and his seat. Life preserver is in place. The Isracast seat got a styrene oxygen bottle at the back and proper hoses. Its not a F-22, so no need to choke the pilot Regards - dutik Edited November 27, 2015 by dutik Link to comment Share on other sites More sharing options...
alain11 Posted November 27, 2015 Share Posted November 27, 2015 hi as I said earlier this kit seems to be a shame , such "wrong" fits are not acceptable nowadays ....some other "good" news are coming next as the nose cone ....look at E Gallier build Alain Link to comment Share on other sites More sharing options...
dutik Posted November 27, 2015 Author Share Posted November 27, 2015 After this mess shall be sanding the nosecone pure recreation... Regards - dutik Link to comment Share on other sites More sharing options...
ClumsyDude Posted November 27, 2015 Share Posted November 27, 2015 (edited) Smooth work on a disappointing kit dutik ... Jim Edited November 27, 2015 by ClumsyDude Link to comment Share on other sites More sharing options...
dutik Posted December 3, 2015 Author Share Posted December 3, 2015 (edited) Sorry for the break! After that SNAFU with the intakes I had to fall back and regroup Switched to the Revell kit and Major Puga. The Isracast seat has a good outline, harness and nice rivets, a hallmark of the early Martin Baker seats, but somewhat basic details on the "bang" side of the seat. After looking at a number of images (there is not a lot around there, at least not showing close up the details of all that connectors, timers, release cables and so on) I added some bits and pieces in the most visible places: Some more gizmos needed at the top. Guess Major Puga would welcome a helping hand or two too Regards - dutik Edited December 3, 2015 by dutik Link to comment Share on other sites More sharing options...
ClumsyDude Posted December 3, 2015 Share Posted December 3, 2015 Looks great dutik. That's some really crisp scratch building. Jim dutik 1 Link to comment Share on other sites More sharing options...
dutik Posted December 6, 2015 Author Share Posted December 6, 2015 Remember that I told you about major warping of the port fuselage of the Revell kit? Not Revells fault, just the age of the kit (40+ years in the box...) This calls for some heavy metal to get things straight: Superglued the pre-cut aluminium block in place. Added a liberal amount of filler too. And the holes are for two screws to keep things aligned: Grinded just some nice openings in the hull to insert the screws. This should teach the fuselage a lesson Regards - dutik Lars Befring 1 Link to comment Share on other sites More sharing options...
Guest Posted December 6, 2015 Share Posted December 6, 2015 Good show !......Harv Link to comment Share on other sites More sharing options...
