My update of the yesterday work on the firewall. The progress is slowly because
Of research and varying appear on some RL sources and of the tiny parts which needs to be drilled out and to be connected. 2 missing parts are not shown here and will be added today.
2hours of built just to replace the original kit parts - visible in the foreground.😈😇 l addwd two 1mm brass tubes bent them into shape and polished. I also used a boot of a litz wire to rebuild rubber pipe collar. All parts in glued just on one side only to remove.
Edited by Urs
To be honest l feared the new bigger tube would not fit. This time l use a 1.5mm brass tube to replace the kit part to be seen in the foreground. Short after first bent l had to drill 1.0mm to sold in a coolant filling hose. Plug will be added later.
I love detailing engines.......but there's no way I could aspire it that level of skill or patience. Simply amazing work Urs.
Max
  • 2 weeks later...
Well, now l'm fed up with wires/lines and things.😅😅 The lines and wire still running wild on the firewall will be connected after the paint job. Today l did the ignition lines on the engine sides and on top of the rocker housing. That prominent part Tamiya missed to model - strange.😴 Now l go further with the cockpit.....
The thin copper wire running across the whole engine is not yet connected and will be fixed after afinal asm.
Guest Peterpools
Tom
Terrific work on the Merlin and engine compartment
Keep 'em comingi
Peter
