Wolf Buddee
Bitten by a Mosquito!
Guest Peterpools
Wolf
A photo or two of the Arado would be nice. And I'll be patiently waiting for the Mosquito's return
Peter
Edited by Peterpools
Guest Peterpools
Hi Ron
At time I've felt the same as the sub assemblies do seem endless at times. Every time I'm ready to move forward, I find some aspect of the build I missed or needs to be redone. Could it be, the Mossie is actually too detailed?
Peter :hmmm:
Guest
Heh, heh, heh, ya had t' ask eh, Harv? :)
Martin gave me a Revell Arado Ar 196A-3 kit for my birthday. I figured I'd better build it before I turn another year older. Plus I thought there's no point in adding another "unbuilt" kit to the stash. I don't think I'll do a build thread for this one although I might just post a pic or two.
How's the Corsair comin' along?
Cheers,
Wolf
Just got back from Texas today. I hope to start back on it this week my friend !......Harv
Edited by Guest
Something about this Mossie kit, building it seems to go at the speed of life.  I haven't even looked at mine in probably 10 months or maybe more.
Hi Ron
Peter :hmmm:
Well, seeing as mine stalled for a year before I got back to it this month, I'd be inclined to agree with both of you. At least neither of you were crazy enough to try doing two at the same time which i think is what did me in initially.
As for Wolf, I can't wait to see updates once that side project is done.
Carl
Wolf
You're finishing Wizardry ranks right up there with Peter's aluminum work... Different mediums but amazing results none the less. Really really nice.
Geoff
Guest Peterpools
Hi Wolf
Waiting patiently for you to re-join the party
Peter
I'm finally back at the Mossie. Work has started on Eduard's Brassin Merlins, or at least the starboard one. There's no doubt that Tamiya's Merlins are brilliant but Eduard's Brassin engines are incredible with a higher level of fidelity in their detail that couldn't be achieved with injection moulding. Cutting the pour block off the front of the main engine block was a little nerve wracking as you have to be extremely accurate with your cut and clean up. If it's off a little bit so will be everything else on the forward end of the engine assembly. I found a couple of the small detail parts were broken but I was able to piece them back together or replace part of the broken piece with card stock. I also had some pin hole damage to one piece which needed fixing. No biggie, just annoying. One bit of advise I can give, I suggest reading well ahead in the instructions particularly when it relates to any wiring or piping you have to add. Holes need to be drilled, cleaned, or deepened in certain parts for the added wiring and if you don't do it before hand you're going to run in to trouble as you won't be able to access certain areas one the parts have been glued together. I also suggest using 5 minute epoxy as an adhesive as it gives you plenty of time to align pieces properly. Being familiar with the Merlin engine helps too as I learned a lot from detailing the engine on my Spitfire. Even though Eduard's instructions are very good, knowing how some of the plumbing is routed makes planning ahead an easier task. The only complaint, and it's not really a big complaint, is that Eduard elected to do the top ignition conduit and the ignition leads as a photo-etch piece. Considering that they supply you all the spark plug fittings for the outer cylinder banks and you have to provide your own wire for the actual leads, the photo-etch piece at the top, which is far more visible, looks way too 2 dimensional. I'll have to scratch build a better conduit and ignition leads. I'll try and post a pic of what it should look like. Other'n that Eduard's Merlins are incredible. Time to get some paint on some of these pieces.......... :thumbsup:
Cheers,
Wolf
Guest Peterpools
Wolf
Simply gorgeous - what a casting. I snapped to attention as soon as I saw your post and the the Mossie was back on the bench. I've been waiting a long time for the build to start down the line again and will be following with intense interest.
Speaking of Mossie's, mine is one piece of plastic away from being finished: the antenna that is waiting to be glued into position on the vertical stabilizer and our journey will be in the books. I needed a bit of RnR and started the Sufa to build up the juices for the finals bits and pieces. I'm planning to finish tomorrow and then over the next few days take the final images; both for the last thread update and the Ready for Inspection glamour shots.
Keep 'em coming
Peter
