D.B. Andrus Posted July 19, 2015 Author Share Posted July 19, 2015 (edited) Shimming the Fuselage: (Please note that performing this procedure will result in minor "tolerance stacking" when attaching the lower wing. I recommend gluing the upper wing halves to the to the fuselage before proceeding. This will help with fitment of the bottom wing assembly. Some adjustment will be necessary.) The cowling on my copy of the kit didn't fit very well. Too large in comparison to the fuselage. Rather than squeeze the cowling to fit the fuselage, and subsequently have an egg-shaped power-egg , I decided to slightly widen the fuselage from approximately mid level to the bottom. This was accomplished by adding a .040" (1.02 mm) shim at the place indicated: As this addition will throw off the fit of the bottom center wing plate some additional shimming from .005" to .020" (.13 mm to .51 mm) will need to be done: ( Added mock-up MG 151 receivers as they can be seen through the brass ejection port on the real deal.) This results in a somewhat tighter fit which I find more a bit more faithful to the original a/c( cowling is hand-held, second photo shows a less accurate fit than in reality): Thanks for looking in. More later. Cheers, D.B. PS: The lower, side latches are yet to be re-scribed. Edited July 20, 2015 by D.B. Andrus RBrown, Anthony in NZ, mywifehatesmodels and 1 other 4 Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 19, 2015 Share Posted July 19, 2015 DB, it looks super neat. Love the problem solving! Jim D.B. Andrus 1 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted July 19, 2015 Author Share Posted July 19, 2015 Thanks, Jim! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 20, 2015 Share Posted July 20, 2015 Very neat work, D.B.! Kev Link to comment Share on other sites More sharing options...
D.B. Andrus Posted July 20, 2015 Author Share Posted July 20, 2015 Thanks, again, Kev. Link to comment Share on other sites More sharing options...
D.B. Andrus Posted July 20, 2015 Author Share Posted July 20, 2015 Thank you, Clunk! Link to comment Share on other sites More sharing options...
Darren Howie Posted July 20, 2015 Share Posted July 20, 2015 Great modelling D.B! Very smart use of the shim to help fit issues. Great work.. Link to comment Share on other sites More sharing options...
D.B. Andrus Posted July 20, 2015 Author Share Posted July 20, 2015 Thanks very much, Darren. Link to comment Share on other sites More sharing options...
Mal_Belford Posted July 20, 2015 Share Posted July 20, 2015 Looks great buddy, and as i see you fixed that hatch on the wingroot, removed the panel line on it....as i missed myself, but ive learned my lesson fast ill ashure you. So keep em coming. /Mal D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Azgaron Posted July 21, 2015 Share Posted July 21, 2015 Nice work! HÃ¥kan D.B. Andrus 1 Link to comment Share on other sites More sharing options...
D.B. Andrus Posted August 8, 2015 Author Share Posted August 8, 2015 Contrary to my usual M.O. this kit has not reached the Wall of Doom (mine are hanging by their tails on the wall). Have been very busy with other things, more photos coming soon. Cheers, D,B. Link to comment Share on other sites More sharing options...
tomv87 Posted August 10, 2015 Share Posted August 10, 2015 Very nice craftsmanship there-- well done! D.B. Andrus 1 Link to comment Share on other sites More sharing options...
Kahunaminor Posted August 11, 2015 Share Posted August 11, 2015 Nice work and a very complete and easy to follow WIP with clear instructions. Many thanks And I am looking forward to more. Regards, D.B. Andrus 1 Link to comment Share on other sites More sharing options...
