Elboogie Posted May 25, 2015 Author Share Posted May 25, 2015 Thank you Oliver. But don't take that time away from your build. Whenever you can post something is alright with me. So I started doing small things to my helicopter. I took off the window mask and I was hoping that I didn't paint anything on the inside of my window, and alas, I did not!! And It really looks good on the Diorama, which I hope I can finish before I have to go back to work. Then I glued in my windows to the cabin door, and placed the cabin doors on the helicopter. Then the strobe lights on the top of the tail and below the helicopter. Not a lot of work tonight. I will tell you what happened to my rotor blades tomorrow. The rotor blades are together and looks good but it took me a hour and a half to fix the problem. Richard dutik and jgrease 2 Link to comment Share on other sites More sharing options...
Hawkwrench Posted May 25, 2015 Share Posted May 25, 2015 Your helo is looking great Richard. You should be proud! Really, really nice blackhawk! Tim Link to comment Share on other sites More sharing options...
Elboogie Posted May 25, 2015 Author Share Posted May 25, 2015 Your helo is looking great Richard. You should be proud! Really, really nice blackhawk! Tim Yeah I am really proud of the job that I did on the Black Hawk. I will list the things that I did not do well when I post my final pictures when I am done with everything. lol But thank you for the compliment. Richard Link to comment Share on other sites More sharing options...
kike_gt Posted May 26, 2015 Share Posted May 26, 2015 It looks really nice Richard! great build I have really enjoyed watching it como to life! Having that tutorial from Oliver will be great for lots of us eager to push our skills to get better! thanks to both for sharing with us! Link to comment Share on other sites More sharing options...
Elboogie Posted May 26, 2015 Author Share Posted May 26, 2015 So, let me tell you guys what happened when I started to put my rotors together. Now there is a nub on the rotor that is suppose to be attached to the main rotor assembly. I had all 4 rotor in their places and then one nub broke off and the rotor blades was detached from the main rotor assembly. Then another starting breaking, along with another. Now looking at the nub on the rotor blades, something told me to drill these points out and insert a steel rod to make them more solid. So now that 3 of my rotor blades are off of the main rotor assembly, I basically got a little upset and was wondering on how to fix the problem. SO I just filed the nubs completely off of the rotor and I drilled a spot in the rotor blades and a hole in the main rotor assembly. Inserted a steel rod in their place and carefully set the rotors in place. THEN one of the rotors broke because of the hole that I put in the main rotor assembly. NOW I AM PISSED OFF!!!! So I did a Whooo saaaa, got a drink, took a hour away from the model, and then went back to it. How in the hell was I going to fix this problem. Fortunately, the part that broke still held its shape so all that I had to do was glue the part together but because the part that broke was holding up the rotor blade, I didn't think it would hold. SO I went back to the problem and inserted a small pin in the part that broke and then glued the pin. Now the part that broke will hold the rotor blade so I carefully glued the part and even though I hate to use this, I used CA accelerator and everything glued together strong. Now the rotors look correct: But I still have more cables to add to the rotors but I don't have guitar string that is that scale because Family Music Center is closed because of the holidays, so I have to pick up some guitar strings tomorrow and complete the rotors. I added on my tail rotor to the Helicopter but I know that the tail rotor is suppose to be canted but is it suppose to be that canted? I think I added the tail rotor on there right. Still have a lot of work to do. Richard Link to comment Share on other sites More sharing options...
Elboogie Posted May 26, 2015 Author Share Posted May 26, 2015 Just a little update on my diorama. I finished the concrete blocks that I created for the diorama. I am still not sure whether I will add them or not. Richard Link to comment Share on other sites More sharing options...
Elboogie Posted May 26, 2015 Author Share Posted May 26, 2015 While almost everything is attached to the helicopter. Except for the munitions. I am waiting for stuff to set on the helicopter and then I will start working on the guns and other stuff. This has been my longest build to date (since December of last year) so I am glad you guys are along to help me. I started working on my figure that I am including in the model. It is Legend productions Sgt. Rob (18 bravo) in Iraq. The first thing that I did when I opened the package was ask myself, what did I get myself into? I love the details on this figure. So after everything is detached from their resin base, the arms didn't match together. It was something that I anticipated. So I grabbed the Milliput and proceded to fill in the gaps on the arms. Of course when the milliput cures, I will sand the milliput to shape and then I will add on the hands and weapon. I hate the weapons because they are so small. lol Richard jgrease 1 Link to comment Share on other sites More sharing options...
dutik Posted May 26, 2015 Share Posted May 26, 2015 Very nice build As for the rotors: **** happens ... OK, I've started to muster the helo kits in my stash Because of your build - dutik Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted May 26, 2015 Share Posted May 26, 2015 (edited) Ralph use a q-tip dipped in water to blend the milliput. Before it cures. That will reduce your sanding. Apart from that it looks greatCheers Edited May 26, 2015 by Vandy 1 VX 4 Link to comment Share on other sites More sharing options...
Loic Posted May 26, 2015 Share Posted May 26, 2015 Link to comment Share on other sites More sharing options...
Elboogie Posted May 26, 2015 Author Share Posted May 26, 2015 Ralph use a q-tip dipped in water to blend the milliput. Before it cures. That will reduce your sanding. Apart from that it looks great Cheers Yeah I did that exact thing for the milliput. Thanks for the suggestion. I think it will look ok when I am done sanding it. Richard Link to comment Share on other sites More sharing options...
Elboogie Posted May 26, 2015 Author Share Posted May 26, 2015 Very nice build As for the rotors: **** happens ... OK, I've started to muster the helo kits in my stash Because of your build - dutik Pull it out of the stash. This is my first helicopter and since I have been building this Black Hawk, I have acquired 3 more helicopter models that I plan on doing. Helicopters are a little different but I like them. Richard Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted May 27, 2015 Share Posted May 27, 2015 Yeah I did that exact thing for the milliput. Thanks for the suggestion. I think it will look ok when I am done sanding it. Richard I was checking out your work on my phone. It looked different Cheers Link to comment Share on other sites More sharing options...
Elboogie Posted May 27, 2015 Author Share Posted May 27, 2015 Here's a little story: So I am working on my model and my wife comes up to see what I am doing. Now naturally, I always ask my wife how my model looks after weathering happens. She is the greatest person to ask her opinion because of two reasons. #1. She will tell you the truth. #2. She doesn't know what the helicopter should look like and has no interest in planes or helicopters. So I figured I would ask someone who doesn't know what the helicopter looks for their opinion. Now most of the time she is happy with the model so far and she always compliments me on my build..... BUT..... This time she looked at the diorama first and she thought that was excellent. Then she looked at my Helicopter and she just stared at it. Then she said...... "Looks Incomplete." I looked at her with a confused look on my face. Then she said, "the model looks incomplete. The bottom of the helicopter looks good but the rest of the helicopter looks like it just came out of the factory." I looked at her with a look as if to say "what the hell does she know about something coming from the factory?" LOL She just said that the top of the helicopter looks pristine almost new, and the rest of the helicopter looks like it has been there for a while. Her words. She is absolutely correct. So I looked at the helicopter and it does look to "pristine" lol. So I broke out the Europe Dust pigment and started to do the panel lines. Now on the pictures, I don't know if I have enough light to show you guys but here they are: I wanted to add the Europe Dust very lightly over the Helicopter. Now I asked my wife, now how does it look? She came over and took a look and said, now it looks complete and in use. Then she looked at my diorama and said she doesn't like the concrete blocks. So I was thinking about doing better ones. Then she went back to her computer. Gotta love the wife. She keeps it real. So I started to add my tail rotor to the helicopter. Now the tail rotor. You know when you do a project and something really looks good? The airbrushing and the silver dry brushing. To me the tail rotor is the part that I am most proud of out of the whole helicopter. Then I started to add the swivel arms to the miniguns: I have another problem that I think I am going to run into, but we will see. IF I run into the problem, I will let you know. lol Richard Link to comment Share on other sites More sharing options...
Elboogie Posted May 27, 2015 Author Share Posted May 27, 2015 I was checking out your work on my phone. It looked different Cheers How does it look different? Is it because you are viewing thru your phone? That is strange. I am a IT person with sprint, and I know that when I look at LSP thru my phone, some peoples build looks a little different than when I am viewing thru my computer. Strange. Richard Link to comment Share on other sites More sharing options...
