mozart Posted April 12, 2015 Share Posted April 12, 2015 So a couple of weeks ago I ordered some HGW seat belts for my WnW Sopwith Pup (code 13058) but I haven't looked at them till today. This is what's in the sealed package: Is that it.....am I missing the seatbelts or is that what that piece of paper is on the front above the PE? I can't understand the instructions if that's all there is! Max the Confused (and possibly disappointed) Link to comment Share on other sites More sharing options...
thierry laurent Posted April 12, 2015 Share Posted April 12, 2015 Indeed, Max, HGW belts are typically made of paper belts and photoetched buckles. In the most recent sets, the paper belts are laser cut whereas for the older ones, you must cut them yourself with scissors. I do not own such a set but I have comparable ones from them. Looking at the picture, you have everything to make the belts. Note that often they give you two identical parts where you only need one and they also commonly add sections of colored paper. So, you have spares in case of problem. Hth Thierry Link to comment Share on other sites More sharing options...
Fenous Posted April 12, 2015 Share Posted April 12, 2015 It looks, that parts 2 and 3 are mislabeled in instructions. Link to comment Share on other sites More sharing options...
DeanKB Posted April 12, 2015 Share Posted April 12, 2015 It looks, that parts 2 and 3 are mislabeled in instructions. Yes. Correct instructions can be downloaded from HGW's website. You also need to scrunch up the belts after cutting, as otherwise they can have the flat, PE-ish look to them. Link to comment Share on other sites More sharing options...
mozart Posted April 12, 2015 Author Share Posted April 12, 2015 Ok thanks chaps, all is clear now including the mis-numbering......but I can't in all honesty say that I'm impressed with the product! Max Harold 1 Link to comment Share on other sites More sharing options...
JamesHatch Posted April 12, 2015 Share Posted April 12, 2015 I think you'll find the material is not paper. They call it microfibre, and you need to peel the backing sheet from the parts, and then crumple them to allow them to drape naturally. Link to comment Share on other sites More sharing options...
mozart Posted April 12, 2015 Author Share Posted April 12, 2015 Thanks James, I've had a closer look and you're right, it isn't paper......but on the other hand there's no backing sheet. I'll try the crumpling idea once I've cut them out. Max Link to comment Share on other sites More sharing options...
vince14 Posted April 12, 2015 Share Posted April 12, 2015 Stick with them, Max. Once you've worked out how to use them, you'll never go back to using PE for seat belts. There's a brief 'How To' about halfway down this page: http://www.scalespot.com/onthebench/p51tamiya/build.htm - I find it's best to use a small amount of White Glue to stick the belts to the seat. And here's a pic of my recently completed 1/24 Ferrari 458 GT3 with HGW belts. Harold 1 Link to comment Share on other sites More sharing options...
Fenous Posted April 12, 2015 Share Posted April 12, 2015 Those early, not precut seatbelts doesn`t have backing paper and must be glued with CA, white glue doesn`t work. Link to comment Share on other sites More sharing options...
wrbrdmech Posted April 12, 2015 Share Posted April 12, 2015 They take a little getting used to but look very realistic once assembled. I use a glue "paste" stick instead of CA. It lets them stay flexible. Best Shane Link to comment Share on other sites More sharing options...
Out2gtcha Posted April 13, 2015 Share Posted April 13, 2015 Yes, the new HGW belts are "Laser" cut out for you. Link to comment Share on other sites More sharing options...
mozart Posted April 13, 2015 Author Share Posted April 13, 2015 (edited) Well thanks again chaps, seems like all's well then and I am muchly relieved! Next question to ponder.....do I splash out on one of those rather tasty looking Barracuda whicker seats. Yeah, I think so. :) Max the Happy Edited April 13, 2015 by mozart Out2gtcha, Harold and wrbrdmech 3 Link to comment Share on other sites More sharing options...
