BradG Posted June 30, 2015 Author Share Posted June 30, 2015 (edited) Not too much progress over the last day or so, just lots of little things; masking the rudder off for paint, painting the exhaust, landing light and touch up paint here and there. However I was mucking around with how to yellow the canopy. I got a couple of spares from the tub of bits and tried future dipping in tinted paint, heavily thinned yellow both brushed and sprayed on, but all I did was make a mess, so I pulled out my modelling pigments (as suggested) and a soft make-up brush and this came out. It's a combination of yellow Tamiya pigment and brown from MiG, worked into the inner surfaces and then lightly applied over the outer to knock the sheen off. It's a little delicate, but as long as I don't put a wet finger on it, it'll be fine. That also means if you want to try something like this and screw up, said wet finger will remove it so you can start again. Edited June 30, 2015 by BradG Menelaos and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
BradG Posted June 30, 2015 Author Share Posted June 30, 2015 Also a question; did the Ki-43 have an armoured windscreen? I'm thinking no, but if it did, the armoured glass wouldn't be yellowed. Link to comment Share on other sites More sharing options...
Menelaos Posted July 1, 2015 Share Posted July 1, 2015 (edited) I don't think there was an aditional armoured windscreen.. look here http://data3.primeportal.net/hangar/bill_spidle3/ki-43_iib_hayabusa/images/ki-43_iib_hayabusa_39_of_47.jpg http://data3.primeportal.net/hangar/bill_spidle3/ki-43_iib_hayabusa/images/ki-43_iib_hayabusa_26_of_47.jpg Edited July 1, 2015 by Menelaos BradG 1 Link to comment Share on other sites More sharing options...
BradG Posted July 2, 2015 Author Share Posted July 2, 2015 I brushed on some Future, although I don't normally use that as a gloss I will be having a go at an oil filter to break up the monotone olive drab. It seemed to work ok, so decals were put on. As you can see, two of them shattered for no apparent reason. I also painted the red rudder, flattened the tires (although you can't see them too well) and started putting together a few cans and drums to sit on the base. I just have to wait for the decals to dry and I'll give them a coat of floor wax too. Menelaos, Girlscanplay2 and Out2gtcha 3 Link to comment Share on other sites More sharing options...
BradG Posted July 4, 2015 Author Share Posted July 4, 2015 Here's my first attempt at an oil filter. I don't mind the effect, it certainly gives the monotone paint scheme some character. I've only done the wings, so you can see the contrast between the effect and just the straight OD on the fuselage. Sorry about the pics, I was hoping for some sunlight today but woke up to grey skies and rain. I'll probably work a few pigments into the surface too after I seal the filter. Menelaos and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
Guest Posted July 4, 2015 Share Posted July 4, 2015 Brad, don't know how this slipped by me !Glass looks good. Your dot filter looks good. I've yet to try it. Keep going lad......Harv Link to comment Share on other sites More sharing options...
BradG Posted July 4, 2015 Author Share Posted July 4, 2015 Oil wash completed on the fuselage, I probably could have gone a little harder with it, but I'll be using some pigment anyway in the next steps. I'll let it set for a good couple of days before attacking it further. With that done, I moved onto the base. Previously I'd used real soil, but it just wasn't fine enough and looked out of scale, but a tip from Facebook (and I resisted using that for so long) suggested grout. I had some left over from recent bathroom repairs so I spread some out, dry, on the base and used an eyedropper to flood it with water. That's all I did and it worked out way better than I thought it would! Next up are some accessories for the base. Menelaos, Iain and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
BradG Posted July 5, 2015 Author Share Posted July 5, 2015 Last in progress update before the final completed pictures as I'm almost there. The base was completed with a few bits of junk and some grass tufts from MiniNature. I've also been working on oil streaks and general grime on the under surface. Not much left but some final paint touch ups, canopy, flat coat and antenna wire. Girlscanplay2 1 Link to comment Share on other sites More sharing options...
BradG Posted July 6, 2015 Author Share Posted July 6, 2015 Doneski. That's 4 group builds in a row for me. Girlscanplay2, olgerd83, Lee White and 4 others 7 Link to comment Share on other sites More sharing options...
alain11 Posted July 6, 2015 Share Posted July 6, 2015 hi nice build ,the paint job is plain but efficient , good job too on the canopy .. I like her!!!!!! .. don't be offend , if I say : this plane , is as sad as the depicted country Alain nice little dio !!!!!!!!!!!!!!!!!!!!! BradG 1 Link to comment Share on other sites More sharing options...
LSP_Paul Posted July 6, 2015 Share Posted July 6, 2015 Great Job Brad! Ill be adding it to the GB gallery ASAP! Thanks for participating with us! Paul BradG 1 Link to comment Share on other sites More sharing options...
Girlscanplay2 Posted July 7, 2015 Share Posted July 7, 2015 Great job Brad! Congratulations! BradG 1 Link to comment Share on other sites More sharing options...
Erwin Posted July 22, 2015 Share Posted July 22, 2015 Very nice.Well done job. BradG 1 Link to comment Share on other sites More sharing options...
