simmo Posted January 18, 2015 Share Posted January 18, 2015 Sorry if this is in the wrong forum but here goes. Im in the process of building my Typhoon in the makings 175 Sqn SW399. The problem I have is witch mod of radiator did it use? The decal sheet shows a red and yellow paint scheme on the front grill ( part D16 ) but should this also be used with part D 17 ( think this is a filter of some kind ) It just seems odd having part D 16 just hanging there not doing a lot. I have looked through lots of pics and seen all kinds of radiator mods on the Typhoon but not one of this aircraft, Can anybody help? Oh and while Im on a roll, Anybody seen any pics of the late style rocket rails fitted to Typhoons? I can only find them fitted to Mozies. Thanks in advance, Ill go away now! lol. Link to comment Share on other sites More sharing options...
Patrick HMD Posted January 19, 2015 Share Posted January 19, 2015 (edited) simmo, the instructions say to not use part D-16 if using part D-17 which is referred to as the cuckoo door type filter. Not sure if this is correct or not, but that's what the instructions say. From what I understand, the cuckoo type filter was a field modification done after the typhoons became operational on the continent. Later production typhoons had this modification installed at the assembly line. Seems like the typhoon you're doing is later production, post September '44. This may be a better explanation. Also notice the lower picture with the late style launch rails. Here are some more images of the late style launch rails. This one with what appears to be a cuckoo-style filter. These look slightly weathered. One more. I'm also doing a 175 sq. bird. Mine is an earlier production with tempest tail and 3 blade prop. I chose to use the coc-coo style filter. Not sure if it's correct, but that's what I chose. HTH Best regards Patrick Edited January 20, 2015 by LSP_Ray Spelling, so isn't caught by profanity filter. Uncarina 1 Link to comment Share on other sites More sharing options...
simmo Posted January 19, 2015 Author Share Posted January 19, 2015 Hi Patrick Thanks for the pics. think you are right , I will just have to follow the instructions. The pic of the later rocket rails, do you know if they are armour piercing heads? Link to comment Share on other sites More sharing options...
Patrick HMD Posted January 19, 2015 Share Posted January 19, 2015 (edited) simmo, I'm no rocket expert, but according to my references they are high explosive fragmentation heads, anti-personnel, obviously. The kit supplied rockets are either HE or semi armor piercing (SAP) rockets. Best regards Patrick Edited January 19, 2015 by Patrick HMD Link to comment Share on other sites More sharing options...
simmo Posted January 20, 2015 Author Share Posted January 20, 2015 Thanks once again Patrick, very useful stuff there. Still having doubts about the rad. lol. On one of the above pics I think I can see a filter of some kind behind the door. Will keep looking for info untill I need to fit the thing. Once again thanks. Link to comment Share on other sites More sharing options...
