mdeanstrauss Posted January 14, 2015 Share Posted January 14, 2015 will follow this closely... I have a Corsair/Raiden double build scheduled for the future... good work... m Urs 1 Link to comment Share on other sites More sharing options...
Urs Posted January 18, 2015 Author Share Posted January 18, 2015 (edited) The central wing section before airbrushing the shown area with flat black. Later in the built you have no chance to access the gabs inbetween the flaps. That Hog got raised flaps as you can see to better show the wing profile. airbrushed and washed wheel bays I have to add some hydraulic lines her but lacked the needed wires to build them today. l'll create them tomorrow. There are few things to pimp withthat kit. One such is the sterring rod of the counter trim tap That spoiler to the left R14 is mentioned in the manual but the wing preparation for that is not mentioned within the Tam manual. The guns were made out of injection needles and brass tubes. Edited January 18, 2015 by Urs Mal_Belford, Anthony in NZ and Whitey 3 Link to comment Share on other sites More sharing options...
David Hansen Posted January 18, 2015 Share Posted January 18, 2015 FWIW, building the model flaps up is not only operationally authentic but it makes the finished model a LOT easier to handle. david Link to comment Share on other sites More sharing options...
Urs Posted January 18, 2015 Author Share Posted January 18, 2015 Most of Kiwi Hogs photo references shows them with raised flap in park position. Maybe the RNZAF had advice to handle the flaps on ground than USN/USMC had. Link to comment Share on other sites More sharing options...
Wolf Buddee Posted January 18, 2015 Share Posted January 18, 2015 Nice work so far Urs. I'll be following along for sure. Cheers, Wolf Urs 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 18, 2015 Share Posted January 18, 2015 Nice progress on the Big Bent Wing Bird and some nice touches that Papa Tamiya omitted. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
mdeanstrauss Posted January 18, 2015 Share Posted January 18, 2015 nice photography to Urs... Link to comment Share on other sites More sharing options...
Urs Posted February 4, 2015 Author Share Posted February 4, 2015 (edited) Three pics of the actual stage of work on theR-2800-8W. The parts are just snapped together w/o gluing, also the sheet metal covers for the cylinder heads are missing here. Next steps are washing, drybrushing and add copper wiring. The engine still naked here w/o wiring, washing and dry brushing. Colors used for the cylinders as ALCLAD Burnt Iron on the radial centre and ALCLAD Airframe Aluminium. Basic gear box color is Tamiya XF-66 - toned down with for the darker areas and brighten up with XF-2 for the highlights. Edited February 4, 2015 by Urs Tnarg, Anthony in NZ, leoasman and 4 others 7 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted February 4, 2015 Share Posted February 4, 2015 Great to see another update! Thank you Link to comment Share on other sites More sharing options...
otis252 Posted February 5, 2015 Share Posted February 5, 2015 Excellent work indeed. What did you use to drill out the ignition harness ring and the spark plug holes? Chuck Urs 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 5, 2015 Share Posted February 5, 2015 Beautiful work on the Big P&W Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Urs Posted February 5, 2015 Author Share Posted February 5, 2015 Excellent work indeed. What did you use to drill out the ignition harness ring and the spark plug holes? Chuck My first idea was to drill out but gave up. A 2nd view on the real engine showed a coupling at the end of the wires connecting to the ring. So l just decide to use a Aluminum tube of 1.0mm/0.4mm and cut them to length and glued them on the model ignition ring. The copper wires l'll just put in the tube endings now. Link to comment Share on other sites More sharing options...
otis252 Posted February 5, 2015 Share Posted February 5, 2015 Thanks, excellent idea. Chuck Link to comment Share on other sites More sharing options...
Urs Posted February 7, 2015 Author Share Posted February 7, 2015 (edited) now connecting the 36 copper wires..l got the feeling being Sisyphus.. Edited February 7, 2015 by Urs Mal_Belford, Anthony in NZ and D.B. Andrus 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 7, 2015 Share Posted February 7, 2015 Wow, terrific work on the engine wiring Urs! Kev Link to comment Share on other sites More sharing options...
