zaxos345 Posted March 1, 2019 Author Share Posted March 1, 2019 (edited) And some overall photos with parts dry fitted...I can say that the cockpit is done!!! Hope you like it.... John Edited September 29, 2022 by zaxos345 F`s are my favs, private_hell, Starfighter and 18 others 21 Link to comment Share on other sites More sharing options...
Spooky56 Posted March 1, 2019 Share Posted March 1, 2019 Love it, and welcome back zaxos345 1 Link to comment Share on other sites More sharing options...
Mr b Posted March 1, 2019 Share Posted March 1, 2019 Wow eveything looks so good the seat espically.... outstanding skill rgds zaxos345 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 1, 2019 Share Posted March 1, 2019 5 hours ago, zaxos345 said: Hope you like it.... I do I do! That pit looks excellent, and very realistic. The IP looks especially good zaxos345 1 Link to comment Share on other sites More sharing options...
zaxos345 Posted March 1, 2019 Author Share Posted March 1, 2019 Thank you very much for the comments guys!! John Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 1, 2019 Share Posted March 1, 2019 Excellent work, John! Kev zaxos345 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted March 2, 2019 Share Posted March 2, 2019 That is absolutely beautiful!!!! Such clean precise work Derek B and zaxos345 1 1 Link to comment Share on other sites More sharing options...
Squizzy Posted March 2, 2019 Share Posted March 2, 2019 It's great to see this build on track, and what an amazing looking cockpit! zaxos345 1 Link to comment Share on other sites More sharing options...
Isar 30/07 Posted March 2, 2019 Share Posted March 2, 2019 Good to see you back! FANTASTIC work! zaxos345 1 Link to comment Share on other sites More sharing options...
Durangokid Posted March 2, 2019 Share Posted March 2, 2019 That pit looks fantastic! zaxos345 1 Link to comment Share on other sites More sharing options...
zaxos345 Posted March 2, 2019 Author Share Posted March 2, 2019 Thanks guys for the comments! John Link to comment Share on other sites More sharing options...
chuck540z3 Posted March 13, 2020 Share Posted March 13, 2020 Beautiful and detailed work John! Cheers, Chuck Link to comment Share on other sites More sharing options...
chrish Posted March 13, 2020 Share Posted March 13, 2020 Whooooooo.....that’s sharp! love it! Link to comment Share on other sites More sharing options...
zaxos345 Posted April 24, 2021 Author Share Posted April 24, 2021 (edited) Good evening lads, Time to resurrect this topic once again!! It will be a long post with sections, please excuse me for that, hope all the work and photoes to make you forget it!! Closing the fuselage Before that I had to install the M-61A Vulcan gun and add some detail on the rear area of the gun. I also painted all the details not accessible after closing the fuselage. And i finally i closed the fuselage. Not an easy thing to do as i had to align everything, from the cockpit tub to the rear fuselage details to the intake and all the zacto details. Time consuming, a lot of dry fit before taking the decision to put glue on it, but thankfully everything went like a charm! Rear cone glued on without problems, and i spent some sanding periods to get the trumpeter plastic to behave itself!! i also glued on the canoe and the rear cone! Canopy frames I changed some of the details of zacto canopy frames to the A-7H ones.... Wolfapack AIM-9P4 pylon and launcer Engine area... Nose gear leg A-7E Nose gear leg was different from the one used on -7H. I needed the -7D one and a fellow modeller was kind enough to provide me with one!! As you can see i shortened the ''V'' shape of it and i added a lot of details (steering mechanism, landing lights etc.) painted and weathered! h [/thumb] ..... Edited April 24, 2021 by zaxos345 dodgem37, daveculp, Greg W and 3 others 6 Link to comment Share on other sites More sharing options...
zaxos345 Posted April 24, 2021 Author Share Posted April 24, 2021 (edited) Main gear legs Main Landing gear legs also needed a lot of work to make them resemble the real ones! I use the two metal ones for the main legs and the plastic one as i have to glue it on the resin and i need to put a pin inside to strengthen this point. Below you can see all the details added, some of them from Eduard exterior set! Wheel wells I placed the rest of the resin and i improved the rear section as it was wrong and to add some but not a lot detail inside!! Also the decals on the wheel well doors are custom made from photoes taken from a real bird! Hook Had to modify the trumpeter one from rectangular to cilindrical one, so i cut the front and rear sections, added a rod, epoxy putty and some sanding, modifying the ''horse shoe'' painted and weathered! Really happy with the outcome! Wings Trumpeter gives you the option for folded wing but if you want not to use this option you need to strenghten the point where the two halves are glued together, the joint is very weak. Also i used long strips of a really straight plastic in order to be sure that i will glue them really straight. The wings have a big span and even the slightest curve will be real present on the final symmetry of them!!! I also placed thick strips of plastic where the holes for the weapons are, i will use metal pins to make the joint stronger so i needed something to bite on! Weapons and pylons I will depict the aircraft as a Quick Reaction Aircraft for Attack Mission with 1 Aero1D external tank and 5 Mk-83 LDGB bombs. So i decided to deal with the weapons now as some details should be added to them. We used rear mechanical fuses for soft targets. So i needed to build 5 of them and try to place them on the bombs!! The external tank comes from a Hasegawa 1/32nd A-4!! The trumpeter ones are terrible!! Finnaly i placed the wings on the fuselage, with minimum of work, nice job here from trumpeter. I masked everything and i am read to throw some paint onher as soon as possible!! As you can see i have glued the windshield on...took me some time to make it bahave its self!!! Thanks for your time and patience, hope you like it!! John Edited April 24, 2021 by zaxos345 Supersonic, scvrobeson, Cheetah11 and 14 others 17 Link to comment Share on other sites More sharing options...
