Vandy 1 VX 4 Posted November 14, 2014 Share Posted November 14, 2014 If it wasn't for the reflection and the molded accesses ports. I thought it was missing the upper wing part. Nice work Mike Link to comment Share on other sites More sharing options...
Rick K Posted November 14, 2014 Share Posted November 14, 2014 nice job Mike! Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted November 14, 2014 Share Posted November 14, 2014 (edited) Also posted this in ZM Horten Concept Note Hope you don't mind Mike From the Old Man Blog A mistake in the parts number of R-Runner has been detected!! Please check and correct the parts number immediately. There's a mistake in 8 marks of the parts number from our Horten kit "R-Runner".Once you fix these number marks, you can continue the assembly according to the instruction manual. Please correct the number marks of your Horten kit "R-Runner" according to this figure above. "8 number marks" needed to be corrected. * Click here to Download the "Important Notice of Correction" (PDF file) for Horten R-Runner. http://www.zoukeimur...r_teisei_en.pdf http://www.zoukeimur..._060b002_en.jpg\ Also wheel well cover http://www.zoukeimura.co.jp/sentiment/images/img_060b003_en.jpg Cheers Edited November 14, 2014 by Vandy 1 VX 4 Link to comment Share on other sites More sharing options...
Guest Posted November 14, 2014 Share Posted November 14, 2014 WOWZERS !!!!.........Harv Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 14, 2014 Share Posted November 14, 2014 Great work! Looks really lovely super clear like that. Agreed, well worth the time and effort. Link to comment Share on other sites More sharing options...
Bill_S Posted November 14, 2014 Share Posted November 14, 2014 Amazing! Link to comment Share on other sites More sharing options...
D Bellis Posted November 14, 2014 Share Posted November 14, 2014 Nice. D Link to comment Share on other sites More sharing options...
SinuheH Posted November 17, 2014 Share Posted November 17, 2014 Lovely work, thanks for sharing this interesting build - amazing! Link to comment Share on other sites More sharing options...
Guest Peterpools Posted November 17, 2014 Share Posted November 17, 2014 MIke Brilliant work and the clear cover is absolutely crystal! Keep 'em coming Peter Link to comment Share on other sites More sharing options...
srmalloy Posted November 28, 2014 Share Posted November 28, 2014 A pic from wood panels removed on the NASM Ho229 show what appears to be RLM02 painted on the interior lower panels, so I will be painting the right side of the aircraft interior with this color once the wood is sealed, and will probably rough it up to have some of the wood grain showing through in some areas. The Horten 223 V3 Technical Study and Conservation website, on the Coatings under 'What is the Horten made of?', indicate that it's not RLM 02, but a semitransparent green fireproofing coating; there is a picture of one of the belly panels completely covered with this coating, and the caption states that "much of the interior plywood surfaces" exhibit this coating, which is also present on the outer surface exposed by the removal of the right exhaust shield aft of the nozzle of the Jumo 004.Whether this would have been continued to the production aircraft, or was an ersatz (in the original 'substitute' meaning) used by Horten instead of the 'correct' coating because it was nonstrategic, is problematic, and your building the model as a 'what-if' project makes the point moot; if better coatings were available, they would get used.One of the things I have noticed while researching the details of the Jumo 004 engine is that ZM did a fair amount of simplification that leaves room for superdetailing. The picture series at William Maloney's Jumo 004 gallery show electrical cabling eliminated from the ZM design, as well as several parts that are just surface greeblies on the ZM parts, instead of being freestanding parts. Fiddly details, and mostly hidden once complete if installed in the fuselage, but perhaps worth doing for completeness' sake. I'd like to see an aftermarket detail set that adds the burner cans and fuel piping that is visible through the access ports in the combustion section (the part painted black in the model) that are just molded recesses in the kit, though.Annoyingly, most of the Jumo 004 engines on exhibit have been sectioned across the 'interesting' part of the compressor turbine casing, removing the details that we would be looking for, and of the various complete engines in pictures, most of them appear to either have been replaced/repainted or the color of components changed during the production history of the engine. And sometimes the design itself changes -- one picture I found shows the two electrical boxes on the left side of the engine, instead of being mounted horizontally as in the kit (and most of the pictures I found), mounted vertically about the same position. D Bellis, mattlow and Vandy 1 VX 4 3 Link to comment Share on other sites More sharing options...
preditor Posted November 29, 2014 Share Posted November 29, 2014 (edited) Fantastic work amazing i am building this kit at the moment and am going to use the woodgrain decals i bought at telford even though i have never used them before so i will have to practice but was wanting to expose the engines and was wondering how to do this without totally leaving of the center panel it is a slow build but such a great kit, keep up the good work, all the best roy. ps so what colour should the steel airframe be if not RLM02 Edited November 29, 2014 by preditor Link to comment Share on other sites More sharing options...
LSP_Ray Posted November 30, 2014 Share Posted November 30, 2014 Great job on the clear areas! Impatiently waiting to see the completed model. Link to comment Share on other sites More sharing options...
JamesHatch Posted November 30, 2014 Share Posted November 30, 2014 (edited) Such a great job Mike. Next to Radu's in the Concept Note book, I've seen no other build come even close to this. Just great! Edited November 30, 2014 by JamesHatch Link to comment Share on other sites More sharing options...
seiran01 Posted November 30, 2014 Author Share Posted November 30, 2014 I haven't dropped by my thread since my last post and I have to say wow, thank you everyone for the compliments, I'm flattered and it really means a lot! I haven't touched the kit in a few weeks as I've been doing my quick-build of the HK do335 kit. Am still plotting how I want to finish this one off and I just cannot settle on a direction. The only thing I do know for certain is that I want to do something a little different than the "standard" RLM scheme the plane is usually depicted in. I've not completely ruled out the red bull scheme even though I will admit that it was originally done up as a joke. Uschi's new wood grain finish was a contender but I probably won't go that route on the exterior. I'll consider any suggestions you all want to throw my way! Cheers Mike gerry1 1 Link to comment Share on other sites More sharing options...
srmalloy Posted December 12, 2014 Share Posted December 12, 2014 I haven't touched the kit in a few weeks as I've been doing my quick-build of the HK do335 kit. Am still plotting how I want to finish this one off and I just cannot settle on a direction. I've been thinking about what I want do to with my ZM Shinden kit; I remember in the preview images of the ZM notes book on the Shinden that it had some 'fantasy' variations, like a bare-metal USAAF version, and it reminded me of the U-234 having carried a crated-up Me-262 on its abortive voyage to Japan. It gave me the idea for a 'what-if' build for a technology exchange the other way -- a diorama with the Shinden painted in late-war Luftwaffe camouflage and markings, with a ground crew and a reviewing group of Nazi bigwigs observing. Vandy 1 VX 4 1 Link to comment Share on other sites More sharing options...
