Martinnfb Posted August 14, 2014 Share Posted August 14, 2014 Excellent , Thank You Derek. M. Link to comment Share on other sites More sharing options...
LSP_Matt Posted August 14, 2014 Share Posted August 14, 2014 Wow! Awesome. Thanks Derek. Matty Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 14, 2014 Share Posted August 14, 2014 There is a whole lot more to come yet Kev! (You may want to collate the useful bits for future LSP reference at some point when I am done if you so wish?). Derek I'm afraid I won't have anything like the time required to do such a thing Derek, but if you're prepared to put an article together, I'm prepared to publish it! Kev Link to comment Share on other sites More sharing options...
Guest Posted August 14, 2014 Share Posted August 14, 2014 But...whats it all about Alfie ?........Harv Link to comment Share on other sites More sharing options...
Derek B Posted August 14, 2014 Author Share Posted August 14, 2014 I'm afraid I won't have anything like the time required to do such a thing Derek, but if you're prepared to put an article together, I'm prepared to publish it! Kev Will do Kev. The easiest way for me would be to create it as a word document the create a .pdf document from it which I can e-mail to you (or several smaller word documents if you with to edit the contents) - Does that sound OK with you? Derek Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 14, 2014 Share Posted August 14, 2014 Will do Kev. The easiest way for me would be to create it as a word document the create a .pdf document from it which I can e-mail to you (or several smaller word documents if you with to edit the contents) - Does that sound OK with you? Derek Word documents are fine Derek, but whatever you do, don't embed the images! Send them along separately if you can. The ideal approach is to write placeholder text into the document for the images ("image one goes here", etc), and then name the images to match. If that's too much trouble I'll certainly understand. I may get time at some point to scrape it all out of this thread. Kev Derek B 1 Link to comment Share on other sites More sharing options...
DougN Posted August 14, 2014 Share Posted August 14, 2014 Great work so far - I really appreciate the effort you've put into examining the kit. I'm looking forward to the next bit with fixes! Doug Link to comment Share on other sites More sharing options...
D Bellis Posted August 14, 2014 Share Posted August 14, 2014 From the side, both are similar in shape, but the Revell part is slightly deeper that the Revell one. Shouldn't that read "From the side, both are similar in shape, but the Hasegawa part is slightly deeper than the Revell one"? All in all, superb! Thanks Derek! Looking forward to your comments on the landing gear, wheels, prop and spinner... D Link to comment Share on other sites More sharing options...
Derek B Posted August 14, 2014 Author Share Posted August 14, 2014 Shouldn't that read "From the side, both are similar in shape, but the Hasegawa part is slightly deeper than the Revell one"? All in all, superb! Thanks Derek! Looking forward to your comments on the landing gear, wheels, prop and spinner... D I shall edit it D (thanks for pointing it out - that is what happens when you type in the early hours of the morning when you are tired). It should say that the Revell kit is slightly deeper than the Hasegawa kit. Thank you for the nice comments. Derek Link to comment Share on other sites More sharing options...
alaninaustria Posted August 15, 2014 Share Posted August 15, 2014 Interesting presentation Derek, I take back my comments - no harm intended! I like the analysis and comparisons in the latest update to the different sources provided... I am looking forward to seeing how you correct the highlighted areas of interest! Cheers and happy modeling! Alan Link to comment Share on other sites More sharing options...
Derek B Posted August 15, 2014 Author Share Posted August 15, 2014 Interesting presentation Derek, I take back my comments - no harm intended! I like the analysis and comparisons in the latest update to the different sources provided... I am looking forward to seeing how you correct the highlighted areas of interest! Cheers and happy modeling! Alan No problems at all Alan - The corrections will be coming soon (probably early next week as I am busy, but we shall see). Best regards Derek Link to comment Share on other sites More sharing options...
Derek B Posted August 15, 2014 Author Share Posted August 15, 2014 Whilst I am still sorting out my photographs and data, here are the scans of the George Cox drawings of the Spitfire Mk.I, kindly supplied to me by Edgar Brooks, which I am using as my primary reference source. Derek Bill Cross and D.B. Andrus 2 Link to comment Share on other sites More sharing options...
Chek Posted August 16, 2014 Share Posted August 16, 2014 Great work Derek, good to see your dedication being laid out for our benefit. Although I can't help thinking ... if only you were instead working on the SLA prototypes sorting all this out a year ago before any metal was cut. Derek B 1 Link to comment Share on other sites More sharing options...
Derek B Posted August 17, 2014 Author Share Posted August 17, 2014 Great work Derek, good to see your dedication being laid out for our benefit. Although I can't help thinking ... if only you were instead working on the SLA prototypes sorting all this out a year ago before any metal was cut. I would if they had asked me Check Derek Link to comment Share on other sites More sharing options...
Pascal Posted August 19, 2014 Share Posted August 19, 2014 ... The corrections will be coming soon (probably early next week as I am busy, but we shall see). Best regards Derek Looking forward to that. Will you correct the length of the fuselage ? Link to comment Share on other sites More sharing options...
