blackbetty Posted June 20, 2014 Share Posted June 20, 2014 very nice work there. sorry for the mistake with the A-7 gear.... i will eventually make some zuni warheads out off brass stock, the drawing helps a lot EmperorKai 1 Link to comment Share on other sites More sharing options...
Youngtiger1 Posted June 20, 2014 Share Posted June 20, 2014 Nice job Kai and I must say I'm drooling on my iPad screen looking at those AMS bombs. I really need to order those quick. Harold and EmperorKai 2 Link to comment Share on other sites More sharing options...
P Stoner Posted June 21, 2014 Share Posted June 21, 2014 Really good work Kai. L EmperorKai 1 Link to comment Share on other sites More sharing options...
Girlscanplay2 Posted June 21, 2014 Share Posted June 21, 2014 Kai You are doing a GREAT JOB with your build! Looking forward to seeing more, and I will be watching for sure! Teresa EmperorKai 1 Link to comment Share on other sites More sharing options...
EmperorKai Posted June 24, 2014 Author Share Posted June 24, 2014 very nice work there. sorry for the mistake with the A-7 gear.... i will eventually make some zuni warheads out off brass stock, the drawing helps a lot No apologies necessary my friend. You were passing along helpful info Kai LSP_Paul 1 Link to comment Share on other sites More sharing options...
EmperorKai Posted June 24, 2014 Author Share Posted June 24, 2014 (edited) Thanks much! I haven't had much of a chance to check in lately, but have been plodding along with the build. I've finished up the wing center section now and thought this would be a good opportunity to share my process through a progression of pics. Here, the original kit part and my scratch built replacement. Some additional lead wire and Eduard photo-etch was added for some fine tuning. Gunze Surfacer 1500 was then applied over the finished assembly. A couple of years ago I mixed up a jar of custom dark gray wash made up of Acryl flat black and burnt umber in a solution of 70% alcohol and distilled water. I've used it now on a dozen projects and still have plenty left. Here, I've applied 2 heavy washes to the primed part to build up shadows and set the stage for the white base coat. For this project (and any USN project I might do next), I mixed up a batch of "USN Killed White" with 7ml Tamiya XF-2 Flat White and aabout 2 drops of Tamiya XF-20 Medium Gray. This was then airbrushed- here you can see the resulting color depth in the white base coat. Base painting was next- Tamiya JA Gray, Testors Chromate Yellow, MM Chrome Silver, Aircraft Interior Black, Polly Scale Oxide Red and an enamel dark silver I mixed with Chrome Silver and Flat Black. I regularly bounce between acrylics and enamels without much issue. Tamiya X-22 Clear was then airbrushed for a nice satin finish. A pin wash was then applied using a mix of Abteilung Black and Shadow Brown. I really enjoy this step since this is when all the details start to pop out. And a couple of pics from the left and right side of the wing center section temporarily in place. After the pin wash, MM Flat was sprayed to lockdown everything. I ran into a problem when that last clear coat "unsettled" the pin wash, so I touched up with the USN killed white and the airbrush which worked out as it blended some of the pin wash a bit. Lastly, pastels were applied to finalize some of the highlights. The inside of the fuselage was airbrushed Tamiya JA Grey and lightened up with Tamiya Yellow-Green. I've been able to finish a few other sub assemblies and am now working on the cockpit so I'll have some follow-up pics in the next day or so. Thanks for looking! Kai Edited June 24, 2014 by EmperorKai Kagemusha, Seversky and Daniel Leduc 3 Link to comment Share on other sites More sharing options...
andromeda673 Posted June 25, 2014 Share Posted June 25, 2014 amazing work man! those wheel bays look AWESOME! EmperorKai 1 Link to comment Share on other sites More sharing options...
LSP_Paul Posted June 25, 2014 Share Posted June 25, 2014 That looks Awesome Kai! Keep up the great work and thanks for sharing your technique! Paul EmperorKai 1 Link to comment Share on other sites More sharing options...
P Stoner Posted June 25, 2014 Share Posted June 25, 2014 Good work Kai. Your doing a awesome job on the detail work. Very nice corrections. Paul EmperorKai 1 Link to comment Share on other sites More sharing options...
Joe Osborne Posted June 25, 2014 Share Posted June 25, 2014 Very nice build! Love the detail. I've written down that formula for USN Killed White. Looks spot on. EmperorKai 1 Link to comment Share on other sites More sharing options...
marauderdriver Posted June 25, 2014 Share Posted June 25, 2014 DAMN SON ! That is KILLER.........I think I quit...........I lied ,but MAN ! watch'in you jack EmperorKai 1 Link to comment Share on other sites More sharing options...
Starfighter Posted June 25, 2014 Share Posted June 25, 2014 That is a great looking paintjob, Kai! Can't wait to see the cockpit! EmperorKai 1 Link to comment Share on other sites More sharing options...
Barry Posted June 25, 2014 Share Posted June 25, 2014 Awesome detail work Kai! Barry Harold and EmperorKai 2 Link to comment Share on other sites More sharing options...
Youngtiger1 Posted June 26, 2014 Share Posted June 26, 2014 Wow Kai...that looks totally awesome. I like how all different shades in that thing.. EmperorKai 1 Link to comment Share on other sites More sharing options...
EmperorKai Posted June 26, 2014 Author Share Posted June 26, 2014 (edited) Thanks much for the kind words! I was able to finish up the cockpit and have some update pics. The process used for the cockpit was the same except that pastels were used more heavily for the black areas. First up, a shot of the tub itself. MM Light Ghost Gray and Aircraft Interior Black are the main colors used here. Abteilung oils, Mig Dark Wash and some pastels were used for weathering. The AMS Resin Martin-Baker Mk. F-5 seat. The seat in the tub- starting to come together. The instrument panel and dash from the Aires set. This picture shows fairly accurately the subtlety of the pastels and weathering. A straight shot of the IP. I noticed later that this and some of my other pics are a little on the bright side, so some of the weathering contrasts more than it actually does. ...and lastly, some pics with all the pieces together (dry fitted, no glue yet). The main weathering on the dash was done with pastels, so naturally I left a fingerprint while posing the pieces. Easy enough to fix, though I'm thinking I might use the airbrush for more permanent fading effect. Thanks for looking! Kai Edited June 26, 2014 by EmperorKai Seversky, Kagemusha and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
