Hello now my F-84 is comming  a end and its slowing down for paint to dry.
I havemade the disicion to make a start on thenext kit.
this one will also be foild.
The kit im going to use.
The markings im going to use are from col.W.B.Wilmot Suwon.
some of the aftermarket only the nose ring is behind in the mail.
Mark
Hi Mark
Terrific  choice for another NMF/Foil project. I have the same kit pretty much ready to go and will be using the AMS cockpit set. I was going to jump back into my Sufa project but might join you if you don't mind after I finish Duchess Arlene.
Keep 'em coming
Peter
careful around the rudder.......Mine was a bit to talll and too thick.....In hind site I should have glued the rudder half to each fuselage side.....now about those skyblazer decals.......
Rob
Beauty mark! I'll join you on your next foil adventure with my mustang :)
I will looking forard to your foil work.
Hi Mark
Keep 'em coming
Peter
Lets go Peter jump in maybe i can steel some idees from u ;)
Rob
Thanks for the heads up and if u whant those decals sent me a pm and the are ours
Nice choice, Mark.
Still need to tackle a big sabre as well… too many ideas.. too many dreams… to little time….
Keep the mojo going….. :popcorn:
i know that feeling :hmmm:
Mark
Terrific!
I also built same kit OOB and I can tell you, that careful dry fitting and reinforcement helps many fitting issues (still you need some putty, because of soft edges & moldings).
In Stash I have another kit with full aftermarket sets. I'm looking your WIP forward...!  :popcorn:
Thanks for all the intrest in this one.
I made a start on the airbrakes and the fit whas good after a lot of dry fitting.
The plastic of the kit is thick.
The left side before(in the kit)
Aires.
Right side from the kit.
And the aires ones.
So far the fit is good.
Next up painting the air brakes
Mark
