Uilleann Posted January 3, 2014 Share Posted January 3, 2014 So we're all familiar with the PE panel updates that use a clear sheet of acetate to simulate glass, attached behind a PE bezel, and then all is glued to the panel itself to give a very realistic look such as Peter's work from airscale with his gorgeous Sea Fury build here: From the airscale site gallery: http://www.airscale.co.uk/gallery.php What I can't seem to work out, is how best to attach all the different materials together as cleanly as possible, while also producing a very strong bond, not likely to fall apart after a year or two. My greatest concern, is how to properly attach the clear "glass" to the back of the PE bezels without marring the finish at all. Thinned white glue perhaps? Future? The crystal clear glue from Model Master used for making windows? And of course, once all that is sorted, what do you prefer to attach the first part of this magical little 'sandwich' to the resin or plastic wall of the panel itself? CA? Something better? I'm sadly a bit limited here in my readily available adhesive options, but do have white glue, CA and Future handy and ready to go if that's the preferred 'tried and true' means to an end here. The particular parts I'm working on now are highlighted below: What say thee good people? Cheers Brian~ Link to comment Share on other sites More sharing options...
Lee White Posted January 3, 2014 Share Posted January 3, 2014 Gator glue would probably be best. Uilleann 1 Link to comment Share on other sites More sharing options...
Uilleann Posted January 3, 2014 Author Share Posted January 3, 2014 What is this magical gator of which you speak? Link to comment Share on other sites More sharing options...
D Bellis Posted January 3, 2014 Share Posted January 3, 2014 I use Future because it dries clear without marring the clear parts or causing any build-up on any of the other parts. D Uilleann and Barry 2 Link to comment Share on other sites More sharing options...
Lee White Posted January 3, 2014 Share Posted January 3, 2014 http://cs.finescale.com/fsm/general_discussion/f/9/t/134825.aspx Uilleann 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 3, 2014 Share Posted January 3, 2014 (edited) Gator Glue is a PVA glue and I prefer to use Micro Kristal Klear, also an excellent PVA glue. use Kristal Klear for all those applications Peter Edited January 4, 2014 by Peterpools Link to comment Share on other sites More sharing options...
LSP_K2 Posted January 3, 2014 Share Posted January 3, 2014 The Gator Glue you asked about. Uilleann 1 Link to comment Share on other sites More sharing options...
Silver Dollar Posted January 4, 2014 Share Posted January 4, 2014 I definitely would not use CA. It may craze or cause the acetate to cloud over. Uilleann 1 Link to comment Share on other sites More sharing options...
Uilleann Posted January 4, 2014 Author Share Posted January 4, 2014 Would there be a worthwhile advantage to the Gator product vs Future? Link to comment Share on other sites More sharing options...
Ken Stetzenko Posted January 4, 2014 Share Posted January 4, 2014 None, both are about the same once dried. I use Future to bond clear acetate parts to the photoetch and also the photoetch to the resin part etc. Future is great for this and I have even attached ship railings with future! Uilleann 1 Link to comment Share on other sites More sharing options...
Uilleann Posted January 4, 2014 Author Share Posted January 4, 2014 Cool - I suppose for small pieces as well, it isn't as likely to matter much in the end. And perhaps the future might help to give the acetate sheet that extra bit of life-like "glassi-ness" shine yeah? Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted January 5, 2014 Share Posted January 5, 2014 You can also use clear gloss enamel paint for small pieces of PE. Uilleann 1 Link to comment Share on other sites More sharing options...
pridco Posted January 6, 2014 Share Posted January 6, 2014 I've also used Tamiya acrylic clear with good results. Link to comment Share on other sites More sharing options...
Youngtiger1 Posted January 7, 2014 Share Posted January 7, 2014 (edited) Interesting find this Gator Glue for PE. I'll have to give it a try. Dip in future then CA has worked well for me in the past, but it dosen't hurt to try new things from time to time. So, with Gator...I can getrdone Edited January 7, 2014 by Youngtiger1 Link to comment Share on other sites More sharing options...
waroff Posted January 7, 2014 Share Posted January 7, 2014 Try a Micro metal foil glue.(on the PE, not on the acetate) Link to comment Share on other sites More sharing options...
