SinuheH Posted December 30, 2013 Share Posted December 30, 2013 Hi gents I'm thinking of building an IAF F-16C Barack, and it would appear that the Academy F-16CG/CJ would be the easiest route, rather than the Tamiya block 50. However, I see the kit has been struck from Academy's catalogue…….. Before I take the Ebay plunge….. what was this kit like …… or is it better to use the Tamiya kit and Isracast conversion (to make a small mouth F-16). Thanks and best, S Link to comment Share on other sites More sharing options...
Babs Posted December 30, 2013 Share Posted December 30, 2013 I think that the Tamiya kit is the best choice to make a Block 40 F-16 C. If you want make a Block 30,you need the NSI air inlet and the landing gear, present in the kit "Thunderbird" but not easy to find. The Academy kit allow the two possibility but less accurate on several points, including the air inlet NSI Link to comment Share on other sites More sharing options...
Dave Williams Posted December 30, 2013 Share Posted December 30, 2013 The Academy kit is still out there, but it's in a new box. http://www.1999.co.jp/eng/10194032 Different decals, but it contains the same plastic as the original CG/CJ kit. Link to comment Share on other sites More sharing options...
SinuheH Posted December 30, 2013 Author Share Posted December 30, 2013 (edited) I think that the Tamiya kit is the best choice to make a Block 40 F-16 C. If you want make a Block 30,you need the NSI air inlet and the landing gear, present in the kit "Thunderbird" but not easy to find. The Academy kit allow the two possibility but less accurate on several points, including the air inlet NSI Thanks, I will probably go with Tamiya. The Academy kit is still out there, but it's in a new box. http://www.1999.co.jp/eng/10194032 Different decals, but it contains the same plastic as the original CG/CJ kit. Thanks Dave, but that version is also currently sold out on the link you mentioned, and is also no longer listed on the Academy website - the only F-16 they have listed at the mount is the F-16I Sufa. Edited December 30, 2013 by SinuheH Link to comment Share on other sites More sharing options...
Dave Williams Posted December 30, 2013 Share Posted December 30, 2013 Thanks Dave, but that version is also currently sold out on the link you mentioned, and is also no longer listed on the Academy website - the only F-16 they have listed at the mount is the F-16I Sufa. Strange, I see the Block 40 kit on Academy's web site. Also, Sprue Brothers has the kit in stock http://store.spruebrothers.com/product_p/aca12106-os.htm Plus, you can still find the kit on eBay, also the original boxing for a lot cheaper. Just saying, if you want the kit, it's still out there. The Tamiya route will be a lot more expensive. Link to comment Share on other sites More sharing options...
SinuheH Posted December 30, 2013 Author Share Posted December 30, 2013 (edited) Thanks for the help Dave, I somehow missed that - I was looking at the site of the EU distributor - as international postage usually is a deal breaker. Edited December 30, 2013 by SinuheH Link to comment Share on other sites More sharing options...
BloorwestSiR Posted December 30, 2013 Share Posted December 30, 2013 Just an FYI, the Tamiya T-bird kit is discontinued so is getting harder to find as well especially at a reasonable price. Carl Link to comment Share on other sites More sharing options...
SinuheH Posted December 30, 2013 Author Share Posted December 30, 2013 (edited) Thanks for the info Carl! A while ago they were on sale locally…. I should have added one to my stash. Edited December 30, 2013 by SinuheH Link to comment Share on other sites More sharing options...
