SinuheH Posted December 31, 2013 Share Posted December 31, 2013 Great work, Brian - those wheels look fantastic. Concerning Aires - I sometimes wonder if the ever saw the kit that they manufacture their parts for…. Keep the mojo going…. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 31, 2013 Share Posted December 31, 2013 This makes me want to get back to my 190S build! Great work Brian. Kev Link to comment Share on other sites More sharing options...
PhilB Posted December 31, 2013 Share Posted December 31, 2013 (edited) Please slow down. You have to make this build last until you can get some new kits! I wish you would bork something up once in a while so we know you are human after all. Oh! Just remembered Dixie Boy...................................................................... :rofl: Top stuff as usual. Carry on. Edited December 31, 2013 by PhilB Link to comment Share on other sites More sharing options...
DougN Posted December 31, 2013 Share Posted December 31, 2013 (edited) Looking good Brian! I like the prop spinner better now, I was thinking it looked a bit too worn after the first chipping/weathering session Oh - and don't forget to scribe the offset line on the top and bottom of the rear fuselage, as the real thing is made of two halves that come together, with the join being offset a bit on the starboard side. IIRC, the kit parts join on this offset line, so you can just scribe the join lines and you should be all set. Doug Edited December 31, 2013 by DougN Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 31, 2013 Author Share Posted December 31, 2013 Thanks guys! Looking good Brian! I like the prop spinner better now, I was thinking it looked a bit too worn after the first chipping/weathering session Oh - and don't forget to scribe the offset line on the top and bottom of the rear fuselage, as the real thing is made of two halves that come together, with the join being offset a bit on the starboard side. IIRC, the kit parts join on this offset line, so you can just scribe the join lines and you should be all set. Doug Are those scribe lines on the Has plans, or are there any good top/bottom view drawings I could reliably go off of that would show where to scribe them? Thanks for da assist! Link to comment Share on other sites More sharing options...
109 Posted December 31, 2013 Share Posted December 31, 2013 Great Sturmbock. I had the luck to spent an afternoon with Hannes Weik, Staffelkapitän in VI.Sturm/JG3 and I have to build his white 7. All the best for 2014! Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 2, 2014 Author Share Posted January 2, 2014 Thanks again for the kind words. A bit more progress on my Würger over new years day, between shoveling the walks, blowing snow off the drive and trying to keep warm. I broke out the G-Factor gear, and got a dry run at those to test fit, and all seems good. There are some unusual seam lines on the brass gear left from the manufacturing process that I will continue to sand and smooth to get rid of, but the fit overall and overall casting is excellent. The gear is also very stiff and resists bending readily. Im now in the process of removing the seam lines, and polishing the oleo sections. MDC also give some great thin wire, and ribbed rubber brake lines in their resin tire set that I will eventually be adding as well. Will see if I can add some Airscale placards as well where applicable. I got the EP cockpit glued together with the exception of the control stick, then got the wells fitted and taped them on, along with both halves of the wings. Once I knew were everything would end up being, I glued down the IP hood and gun covers: The gun cover and IP hood fit great, but to ensure a tight watch-like fit, I had to apply a small amount of filler on the EP hood to make sure it will align perfectly with the combination of it, the Has gun cover, and the Black-Dog armored windscreen: Leading edge fit will be excellent: Wing root fit will be same; I also took some Tamiya tape and taped the cowl assembly together. Dry fit is stellar. In order to get that super tight fit of the gun covers, it also required me to push it snug, up against the EP hood. This left a VERY tiny gap between the cowl and cover, so I slipped in a super thin piece of styrene sheet to flush things up: Perfect alignment now: With a GREAT testament to the overall fit of the kit, I took just a few pieces of Tamiya tape and taped the cowl, fuse and wings together, while just press fitting the gear and wheels in place to see if shes starting to look like a butcher bird............................... Yep! Aires wheel well set now wrestled into submission and fitting fine: All for now ladies and as always, thanks for looking in on me! Cheers, Uilleann 1 Link to comment Share on other sites More sharing options...
JRutman Posted January 2, 2014 Share Posted January 2, 2014 Looking very cool and deadly on its' legs. What company made those metal gear? They look too high to me. I think they used the plans for a plane with no weight on the ground as most plans are drawn like that. If you don't believe me check out some pics of the real deal,the oleos are more compressed. Don't get me wrong,the build is awesome.....just sayin' J Link to comment Share on other sites More sharing options...
Jamme Posted January 2, 2014 Share Posted January 2, 2014 That's a nice UP here, Brian. Congrats, as the fit of the pieces his not the greatest. Cheers, Jamme Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 2, 2014 Share Posted January 2, 2014 Brian Terrific progress and the fit looks right on the mark. Love the way the gear looks and fits. Right now we are under a blizzard watch for the next 48 plus hours - plus frigid cold as well. Oh what joy. What ever happened to the mild winters we are supposed to have here on the Island? Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 6, 2014 Author Share Posted January 6, 2014 (edited) Thanks for the kind words gents! Looking very cool and deadly on its' legs. What company made those metal gear? They look too high to me. I think they used the plans for a plane with no weight on the ground as most plans are drawn like that. If you don't believe me check out some pics of the real deal,the oleos are more compressed. Don't get me wrong,the build is awesome.....just sayin' J They are the white brass gear made by G-Factor.................I had to stop twice and look the gear over, as your right, without the gear doors, they did look long. What I found was interesting................. When measuring the G-Factor gear VS the OOB Hasegawa parts, the G-Factor set is about 1.5mm shorter than the Has gear legs overall: When comparing the oleo compression, the G-Factor set is dead on to the OOB Has set: I started looking through my pics of 190s on the ground with the oleos extended to the point the G-Factor/Hasehawa gear was. I found several pics that indicate that the oleos may be scosh extended but both Has and G-Factor seem to have them pretty close: This wartime 190s gear is even a bit more extended (and closer to the Has/G-Fact gear) Even the repro 190s I found have their oleos extended quite substantially. This pic shows a restored/repro 190 at Duxford that if you look at the model at the same angle as this pic is taken, very nearly matches the extended oleos of the G-Factor/Has gear: I think a lot of it might be the gear pictured without any gear doors, and without the wheels fully put all the way onto the gear as well. Besides the gear is SUPER DUPER strong, and I wouldn't risk any surgery to correct such a small discrepancy, as Im sure with this long legged bird, any such mods would compromise the strength of the gear. On to more progress! Edited January 6, 2014 by Out2gtcha Uilleann 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 6, 2014 Share Posted January 6, 2014 Brian Pretty neat detective work. Things sometimes aren't as they seem. Gee, now where have I hear that before? Keep 'em coming Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 6, 2014 Author Share Posted January 6, 2014 (edited) I spent some time cutting out the Mk 108 canon ejector shoots, (boring no pics) and priming the gear and other resin parts. This took quite a while with all the sanding and smoothing and priming, so I wont bore anyone with pics of that stuff. While the primer was drying, I did get in several sets of belts I ordered as both Radus paper belts and HGW textile belts work really well. I knew Id likely find a place to use both/either, so I would have one set for a future build. I had not really had a chance to use any of the text printed HGW laser belts yet, so I went with those, and will use Radus belts on a future Luftwaffe build. I removed the belts from their protective backing and kneaded them up a bit as per HGW. I found doing this then straightening out the belts, then crumpling them again, then straightening again for several cycles, gets teh textile belts to a more supple and realistic looking point. This way they seem to take much better to washes, clears, and especially to conforming to the seat to look like real flexible fabric belts. After the last round of kneading, straightened the belts out once again, and tacked them to a piece of double sided tape. I then gave them several light coats of MM lacquer gloss. Then came a wash of Flory Models dark dirt, followed by a spray of MM flat clear. Here they are installed in the EP pit: Funny enough, I actually found the pilot oxygen hose from my previous Master Details pilot I used on my XF5U-1 that I thought broke off from the pilot and fell into the model to be forever lost..................................this wasnt the case! I actually found the bloody thing on the floor when I swept up before starting the 190. So...............even though its not Luftwaffe, it does have good visible hose ribbing to it, so I painted it up and prepared to install it: Then, once dry, I installed it where the EP instructions indicate: Once that was done, I finished painting the flight stick, and installed that as well: Finally, it was time to bite the bullet and get the whole pit installed in the fuse. As with most AM there is no true "drop fit" and such was the case with the EP pit. More scraping, sanding and smoothing had to be done on the outside of the pit to get it to fit correctly. I got the cockpit installed, glued up, then I painted the rear canopy sill, then weathered it: Hard to see, and/or capture well on film, but much easier seen IRL, are the IP and sidewall details (the IPs look MUCH less blue IRL too) : Nothing perfect here as usual, but Im pretty happy with the progress so far. Now that the canon ejector shoots have been cut, and the resin shoots dry fit, I also got the under-wing canon breech panels installed and got some injector pin marked filled inside the flaps. All that is left in the pit now is to finish the gun-sight and get the "glass" installed in it, then get the gun-sight itself installed. Back to work later tonight (BOOOOOO!) so progress may be a bit slower until next weekend. Hope all had a good holiday season and a great new year so far! Cheers to one and all, Edited January 6, 2014 by Out2gtcha Tewika, Uncarina, Uilleann and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 6, 2014 Author Share Posted January 6, 2014 Thanks Peter. Your a posting machine today! Wasn't sure if you'd left any threads un-posted! No real detective work as such, just Jerry's observation seemed on and it got me thinking maybe Hasegawa and Ernie both got it wrong. I dont thing "wrong" was the word, just maybe a very slight bit over extended when looking at some pics, and closer to being spot on in others. Kahunaminor 1 Link to comment Share on other sites More sharing options...
JRutman Posted January 6, 2014 Share Posted January 6, 2014 Didn't mean to make a fuss. I was wrong. Isn't the first time and won't be the last,that's for sure. J Link to comment Share on other sites More sharing options...
