Lancman Posted November 26, 2013 Posted November 26, 2013 Hi silver dollar not sure how it measures up but here's a couple of pics of my ID kit with a few measurements, don't how these compare Nige. 1 = 78mm, 2 = 45.5mm, 3. 82.5mm, 4. 71mm and 5. 30.5mm these are roughly done as my digital calipers battery is flat. doh!!!! Graham Dan Paxton 1
Lancman Posted November 26, 2013 Posted November 26, 2013 Thanks for that Nige I thought she looked about 6 months pregnant but I now plan to put her together as is and when finished hand her over to my son's ATC Squadron. Graham
Silver Dollar Posted November 27, 2013 Posted November 27, 2013 Thanks Graham for the pic. I'll wait for anymore measurements and scale them up or down.
Dan Paxton Posted November 27, 2013 Posted November 27, 2013 question for the fortress many.... are you all building and representing the narrow walkways of the period or the more recent wall to wall walkways for tourist to climb in and around? Know what I mean? Some boxes were wooden and are now metal (some ammo boxes) just a question and by no means is any answer right or wrong.......each artist has their own vision of the finished product...... V/R Dan
Silver Dollar Posted November 27, 2013 Posted November 27, 2013 I made mine like the original should be with one plywood plank in the waist and the narrow 6" catwalk in the bomb bay. Unfortunately, I don't remember which restored fortress is the most accurate. When I was at McGuire AFB about 30 years ago, Texas Raiders came in as part of Armed Forces Day. Since I was also a member of the Confederate Air Force at that time, I was allowed to be a "Crew Member" to take care of tourist questions. I was in full flight gear all the way down to the blue bunny, boots, helmet, O2 mask and A2 jacket. I remember trying to get to the waist from the cockpit and that was by no means an easy task with all that gear on. I hope that was an accurate resto because that's what I'm going by. Dan Paxton 1
Hubert Boillot Posted November 27, 2013 Posted November 27, 2013 Graham, I really think you should measure that model again. There's no way that fuselage is that far out!! It looks better to my eye than the OOB HK fuselage. I think a remember a side-by-side photo in Richard's (Richdic) building thread of his vac B-17, where the vac kit fuselage looked definitely fatter than the plastic kit, which itself seems to have taken the same extra load as I have ... So Graham's dimensions may be true, if not scale-accurate . Hubert.
Guest Peterpools Posted November 28, 2013 Posted November 28, 2013 Nige You're doing an incredible job of re-engineering and correcting the Fortress to exact dimensions. Unfortunately, in my wildest dreams, I would never have your skill and talent to do this type of work. Enjoying your build to the upmost Keep 'em coming Peter
Silver Dollar Posted November 30, 2013 Posted November 30, 2013 Nigel, you must have been a surgeon in a past life. That went together like it was molded that way. I like the way you use the plastic card as a dimension guide.
ghatherly Posted November 30, 2013 Posted November 30, 2013 Hi Nige, I am just going to second what Peter said, as it sums up my feelings completely. Gary
Lancman Posted November 30, 2013 Posted November 30, 2013 Hi Nige, I re-measured the model with the callipers (with new battery) and they came out as follows nose=46.7mm, front of windscreen=78.2mm, behind wing root=82.9mm, behind waist guns=70.6mm and tail guns=32mm. So the ID vac is fatter than the HK kit also I am using the nose cone from the combat kit and it fits so I guess the combat kit is fat too. I can't slim her down as that's the size she needs to be so the transparencies fit. Graham
Guest Peterpools Posted November 30, 2013 Posted November 30, 2013 NIge All the pieces work together and you're making significant progress. Just take small steps at a time, this way, you can see and fell your continuous progress. Keep 'em coming Peter
Ripaman Posted November 30, 2013 Posted November 30, 2013 Hi Nigel, Looks like you got the shape licked on this one, has made a big difference to the overall look. Very well done. Regards Richard
Silver Dollar Posted November 30, 2013 Posted November 30, 2013 I didn't know the tunnel entrance was off center. I've got to go back to my research. Everything is looking like it fits really well. Wow, that's a major windscreen difference. I assume you'll be remaking the clear windscreen part. What material will you use for that? I'm eager to see how you deal with it.
Azgaron Posted December 1, 2013 Posted December 1, 2013 Quite some work you're putting into this build! Looks good though! HÃ¥kan
