Farao Mike Posted July 4, 2013 Author Share Posted July 4, 2013 So as easily conclude from all this is that Hasegawa's kit is the most accurate,right ?This would be useful to have in mind the next time I will start a P-47 model.In any case,thank you all... Link to comment Share on other sites More sharing options...
LSP_Mike Posted July 4, 2013 Share Posted July 4, 2013 Mike, if you are striving for that level of accuracy, then it looks like you either have to build up the wing tip, or stretch the wing by cutting and adding a bit along a panel line. In comparing the trumpy parts to the Hase parts, it seems the trumpy parts need the stretching much more that the Hase parts; it looks from here(Calif) that cutting off the wingtip and adding a piece would make the wing more accurate, yet be straightforward. Is it worth the effort? Link to comment Share on other sites More sharing options...
