dutik
WNW Germany Junkers D.1
OK, here we will see WNWs secret new Junkers D.1 kit come together.
Well, you say there is no such kit? :hmmm:
:crying:
OK, then let's scratchbuild our own Junkers :thumbsup:
With my summer vacancy just a few weeks ahead I've mustered my Winsock datafiles, Junkers photobooks and other resources. There is a paper kit available which will give me some templates to cut out surfaces of the wings and fuselage. And -very important!- a set of lasercut wooden spars and bulkheads too. This will be a major shortcut to find the proper wing profile and fuselage shape :thumbsup: To be honest: wing profile is a major concern, as I've learned with my stalled UT-1 build (see here: http://forum.largescaleplanes.com/index.php?showtopic=34309&page=3 ). I've ordered both. Next stop will be to buy some proper corrugated sheet styrene. Located some 0,5 mm styrene with a "corrugation" of 1,0 mm which should come close enough to scale Junkers Wellblech.
And of course it will have some real (and important) WNW parts in it: The Benz III engine :)
Here we go!
Regards!
- dutik
There was the resin Escadrille Model Co Junkers D1 - have one in the loft somewhere...
Great subject - good luck with your build!
Iain
While still waiting for the paper kit to arrive (as well as for the beginning of my vacancy, with is still a few weeks ahead) maybe I am allowed to please you with another WW1 related build?
This is not an airplane (so, BEWARE!!!), but an armored halftrack in 1/35 scale. To bee honest: plane modelling is very demanding. No chance to hide glitches with a few layers of mud. But tank modelling is well suited to sand and glue a few parts even after a long and demanding working day. OK?
OK. The russian(!) Austin-Kegresse armored halftrack is another WW1 high-tech development that made it too late to the battlefield like Junkers all-metal german fighter and was used in extense right afther the end of WW1. Like the D.1 in the vast areas of the Eastern Europe, of course. Mr. Kegresse was working for the tzar and developed a halftrack suitable to the russian road conditions, especially during the "bezdoroshnoje" ("no ways left") time of spring and autumn. The military command was pleased with the results too and ordered the system to be fit to license build Austin armored trucks. Due to Russias weak industrial base as well as the quagmire of the Russian revolutions the armored halftracks were not ready before the end of the Great War, but served the Bolshevics with distinction during the Civic War. The Polish Army were able to capture a few of them and put them back in service against the former owners. Remember, that the Polish Army led by Pilsudski was the only army in the world to ever defeat the Soviet Union in a regular war and force them to a Peace Treaty with favourable results. In fact Poland sized a good part of the Ucraina as result of the Polish-Soviet war...
This is a kit made by Armo/Jadar of Poland. All resin:
The body is cast as one hollow piece with a seperate floor. While having a longitudinal cast-in spacer they sidewalls bent inwards and had to be pressed back to a straight shape with the help of some bulkheads.
This is how the hull is supposed to meet the rear u/c, i.e. the tracked part. While on-spot to scale is the suspension too flimsy to shoulder the weight of the hull, so I drilled out the main shaft and inserted a thick rod. To connect it sufficient with the hull I am now adding two more rods at suitable locations. One is in place now. These rods are not at the real vehicle, but will be mostly invisible with the running gear in place.
Enjoy!
- dutik
I am somewhat confused about the choice of the correct engine. Winsock calls out for Mercedes III and BMW III, without giving information if the BMW was used for the fighter competition only or with (some) of the serial fighters too. At least the Benz is not the one I need, because it was used just with a prototype (also the airframe had a well visible different outline). So Mercedes or BMW?
Guess Mercedes should be the right one. At least it is at the fighter in Le Bourget that was captured by the Entente in frontline service. So I've pulled out WNWs Mercedes D III engine sprue. Well, WNW is not only making fine kits, they are also making fine sprue! If you don't know the layout: the engine sprue holds all parts to make the 160/180/200 hp subtypes. But parts are not just somewhere attached to the sprue, the sprue is divided into 4 segments, one each holding the common parts for all or just the parts needed for one of the subtypes. It's impressive, but thats not all: At the center is a molded on inscription calling out which sector are the parts for what subtype! You also get 4 different propellers, each named at the sprue too!
Regards
- dutik
Building the suspension is the most boring part of AFv modelling. Lot of wheels. Cut, fit, glue; cut, fit, glue. Repeat again.
It's coming into shape. More resin to be cleaned. Started with the aircrafts Mercedes engine too (upper right), to have at least a little bit of LSP modelling. Did some stash diving and recovered some sets of very nice Karaya MGs. Spandaus and Parabellums. The cooling jackets are ready made. No need to bend, glue, solder or else. Sweet, indeed. Recommended!
Regards
- dutik
Incoming!
This was in the mail today:
Paper kit to the left, lasercut parts to the right. The small part are the jackets for the mg.
Just 2 pages in colour (good print) plus another one b/w. Simple kit with not a lot of parts, but a good starting point to use it as a template.
These are the lasercut wingspars (one wing):
Looks nice, even without glue. No I have to find some time to drive to town to hit the copyshop to enlarge the Windsock drawings.
Regards
- dutik
No much progress, but I was able to enlarge the Windsock drawings.
Well, the available photocopier worked maximal A4 to A3, which is 141%. But 1/48 to 1/32 is 150%. Damn. So I had to do some mental arithmetic, in the afternoon, after a day at business, and with 30 ° Celsius outside and much more inside the copyshop :help:
A brain wave hit me (and I missed the saving dice throw too) to find the solution to make first a copy of 120%, then a second step of 125%. Voila, 120 + 125 percent add to 150 percent. The weird world of arithmetics :mental:
Wingspan of the real airplane is 900 cm. This translates into 28,1 cm in 1/32. The copies are spot on :frantic:
OK, I have to do a lot of business the next days (and weekend too), so there will be a short break now :sorry:
Regards
- dutik
I sure you are already aware that the paper model is 1:33 scale. I mention it only because you seem to intend to use it for templates. Interesting thread so far...
Thank you for pointig out to that issue. There is some give or take to be calculated. The corrugated sheet is much thicker than paper. So this could be sufficient to meet the right overall size when added to smaller 1/33 templates of the interior. Thats why I have made 1/32 drawings ready. Of course I still have to add a little bit to get the wingspan and chord right, as well as fuselage lenght. I want to figure this out next week (at least I planned to do so). If the size should be to small it is no problem to enlarge the paper parts one by one to 1/32 scale, because I have an suitable A4 photocopier at hand.
Regards
- dutik
It sounds like you are "on top" of everything...carry on! I seem to remember a thread here where a modeler was building an SB2C Helldiver in plastic using a paper model as patterns. You might look that one up as a source of problem-solving.
