LSP_Ron Posted February 26, 2017 Share Posted February 26, 2017 I just measured mine two examples with a vernier caliper. The Tamiya ones are 7.2mm wide and the resin are 8mm if that helps. Ron Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 26, 2017 Author Share Posted February 26, 2017 I just measured mine two examples with a vernier caliper. The Tamiya ones are 7.2mm wide and the resin are 8mm if that helps. Ron Thanks, Ron. So, a little wide then, but not by any amount worth worrying about. Kev Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 26, 2017 Share Posted February 26, 2017 Kev, that resin exhaust panel is made by Moskit. There should be a pair of fairings that fit on the inside of it. I can try to find mine if you need a reference. Carl Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 26, 2017 Author Share Posted February 26, 2017 Kev, that resin exhaust panel is made by Moskit. There should be a pair of fairings that fit on the inside of it. I can try to find mine if you need a reference. Carl Ah, that makes sense, Carl! The instructions mention that the exhausts themselves are available separately, but do show you how to assemble and fit them. I do in fact have those internal fairings, and have decided to fit them first, and insert the exhaust assemblies into them, rather than the other way around as suggested by the instructions. I was worried that if I installed the exhausts first, the fairings wouldn't fit over them. At least this way I have a bit more wiggle room. Kev Link to comment Share on other sites More sharing options...
CANicoll Posted February 26, 2017 Share Posted February 26, 2017 Kool, I did forget about the correct, I didn't go back and re-read the thread. I think the wheels are correct. The kit ones are definitely too thin. I used the same set but I can't recall where I got them. I thought it was Two Bobs? This looks like it was taken at Udvar Hazy? Is that right? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 26, 2017 Author Share Posted February 26, 2017 OK, so after a quick'n'dirty test fit of the exhaust assemblies, it looks like they'll pass muster. It was too awkward to try to take a photo of them in place while I was holding them in place, so you'll have to take my word for it! The bonus is, if I play my cards right, I should be able to leave them out until possibly after painting. It depending on whether the sections that protrude forward end up interfering with the engine once it's in place. Either way, I think I'll have to go for the closed cowl flaps option, as there's just no way I'll be able to make the area behind the engine look decent. Kev BiggTim 1 Link to comment Share on other sites More sharing options...
Allan Peters Posted February 26, 2017 Share Posted February 26, 2017 The kit tires are way too narrow and as Ron says your resin set is only slightly wide though the center of the tread pattern is a little off. Regarding the colour of the tail gear, I wouldn't worry whether you do it white, light grey or silver. The bottom of the aircraft and the tailgear were so dirty from exhaust, oil and dust you won't make out the colour after weathering anyways. Good luck with the exhaust. Allan Link to comment Share on other sites More sharing options...
ClumsyDude Posted February 26, 2017 Share Posted February 26, 2017 Love seeing you ploughing into this again Kev. It's looking really neat. Jim Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 26, 2017 Author Share Posted February 26, 2017 The kit tires are way too narrow and as Ron says your resin set is only slightly wide though the center of the tread pattern is a little off. Regarding the colour of the tail gear, I wouldn't worry whether you do it white, light grey or silver. The bottom of the aircraft and the tailgear were so dirty from exhaust, oil and dust you won't make out the colour after weathering anyways. Good luck with the exhaust. Allan Thanks, Allan. So, resin tyres it is. I just need to decide whether I'll modify the tread or not. Thanks for the advice on the tail wheel assembly, too. I reckon a heavily weathered off-white should do it. Kev Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 26, 2017 Author Share Posted February 26, 2017 Love seeing you ploughing into this again Kev. It's looking really neat. Jim Thanks, Jim. I can't believe how long I've been hammering away at this build, on and off - and how long there still is to go! I'm aiming to see it through to the end now without any breaks or distractions. Oh, look! A butterfly! Kev ClumsyDude 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 26, 2017 Author Share Posted February 26, 2017 Focus, young Kevin, focus…. Great to see you back at the coal face. May you have smooth sailing always. Thanks, Dan. Not sure if I'll achieve much today, but I'll try to get to the workbench at some stage. Kev Link to comment Share on other sites More sharing options...
dennismcc Posted February 27, 2017 Share Posted February 27, 2017 Lots of action going on, definately not the easy way, those Moskit exhausts look good and if you can fit them after painting that will be really handy. Cheers Den Link to comment Share on other sites More sharing options...
Out2gtcha Posted February 27, 2017 Share Posted February 27, 2017 Good to see this one back on the bench! I too have the Moskit exhausts and really love the looks of them. Not sure how they will fit in the end, but Ill definitely be watching so I know what to do. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 27, 2017 Author Share Posted February 27, 2017 Thanks, guys. In the end, I only had about 10 minutes at the workbench, so I glued a missing part to the tail wheel assembly (after having to repair it due to a horribly placed sprue gate). I think I can start painting the tail wheel area now, and once that's done, I should be able to join the fuselage halves. Woo hoo! Kev Link to comment Share on other sites More sharing options...
scvrobeson Posted March 2, 2017 Share Posted March 2, 2017 Those Corsair gear legs were the first set I mastered for G-Factor. There was definitely no wheels supplied with the set Matt Link to comment Share on other sites More sharing options...
