Guest Posted May 15, 2013 Share Posted May 15, 2013 Great show ! Love your work on this. Looking very good !.............Harv Link to comment Share on other sites More sharing options...
ericg Posted May 16, 2013 Author Share Posted May 16, 2013 Some more modelling fun for the day, in between casting lots of resin. The leading edges of the intakes are a darker colour than the inside and the outside of the intakes. I think it must be a protector strip or something. Using the technique as above, this process was much easier to do. I also have noticed that the leading edge of the tail is also darker so masked it of and sprayed it. Some painting fun... NOT! Here are the main undercarriage legs before the application of an Archer dry transfer placard... and after.. These dry transfer placards are very cool. Just toolin' around to see how it looks, really starting to enjoy this build. I still need to adjust the bombs slightly into position. Whitey 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted May 16, 2013 Share Posted May 16, 2013 WOW! Really nice work Eric... I always believed that the realism is in the small details and you definitely have an eye for that!! And, the skills to make it all that much more realistic! Great job mate! Cheers Alan Link to comment Share on other sites More sharing options...
ericg Posted May 23, 2013 Author Share Posted May 23, 2013 Well I have started the decal process, which I always enjoy. First I layed down a nice coat of Future I purchased the Hamilton Hobbies decal sheet, mainly for the 76 Squadron band on the tail. Here is the kit cartograph band that I have cut out (to help with positioning compared to the Hamilton decals. The colour of the kit band is very different (and wrong) compared to the Hamilton ones. I am trying to use the kit decals where possible as they are Cartograph after all. I feel the Hamilton decals are neccesary for the finish of the kit as they contain some stencils that the kit decals miss. There are some register issues though and for this reason I am using alot less of them than I would have liked to. Here is the 76sqn Panther head (kit decal) applied to the Hamilton band. I thought I would give the Maketar mask set (RAAF roundels) a go as I haven't used a masks before. The kit decal roundels are way too dark and will not look right applied to the model. I was going to use the Hamilton set but they are a bit too fuzzy for my liking... so I decided to mask em. Impressed with the process so far, although my colour choice was too light a shade of grey. I have since scrubbed the pain off and will re-apply once the touch ups dry. Thin paint and low pressure is the name of the game here As I said before, a bit too light. I think the closest colour I am going to get is going to be Tamiya fine surface primer (grey), so I will give it a go tomorrow. I spotted some placards on a walkaround that I thought would look good (and my good mate Whitey also picked up on them) so I thought I would try some of the Archer dry transfers. (If you can read what they say, you are WAY to close to my model... !!) Link to comment Share on other sites More sharing options...
shaky962 Posted May 23, 2013 Share Posted May 23, 2013 I don´t have words to describe this amazing work. Congratulations!!!!!!!! Link to comment Share on other sites More sharing options...
ericg Posted May 24, 2013 Author Share Posted May 24, 2013 So here are the results of using the Maketar RAAF roundel set. Overall, I am very impressed with this method of applicatino of the national markings and would highly recommend them to anyone. They are actually very easy to use and have th eobvious benifit of being able to conform to any surface. My reference pics have the leading edges of the wing roundels going over 2 of the vortex generators, and I reckon that alone would have caused all sorts of problems with the traditional decal. For the record, the roundels are painted with the nice grey colour of Tamiya fine surface primer. Whitey 1 Link to comment Share on other sites More sharing options...
Guest Posted May 24, 2013 Share Posted May 24, 2013 Perfect !...........Harv Link to comment Share on other sites More sharing options...
Nic C.D. Posted May 24, 2013 Share Posted May 24, 2013 Those roundels look fantastic! We are so lucky these days with all those wonderfull new products. Image you have to cut out those roundels yourself... Great job ! Nic Link to comment Share on other sites More sharing options...
ericg Posted May 25, 2013 Author Share Posted May 25, 2013 I finally decided on a tail number, that being A27-22 I have used a combo of the kit decals and Hamilton Hobbies decals, mainly for the stencils. They sort of compliment each other in that where the kit decals are missing a stencil, the Hamilton sheet has it and vice versa. The small black line is a detail that I have seen in lots of walkarounds that I thought would look good. I cut up some black decal and applied it. Here is one place that you will need the Hamilton decals, the NO STEP signs in the kit are the wrong colour and dissapear as soon as they are applied. Whitey 1 Link to comment Share on other sites More sharing options...
mgbgtv8steve Posted May 25, 2013 Share Posted May 25, 2013 Brilliant Eric, just brilliant! You've certainly done this kit proud and it's not even finished yet!! As a 'lazy modeller' sitting here in the UK what I'd like now is for you to list out all the 'conversion and addittional' bits you've put on it - don't want much do I? Now how about some progress on your Hunter T.7?? Best wishes, Steve S. Link to comment Share on other sites More sharing options...
ericg Posted May 25, 2013 Author Share Posted May 25, 2013 Hi Steve, Good question. I have done the following (off the top of my head) Scratchbuilt instrument panels New throttles Modified Control Sticks Modified nose leg Changed some details on the main gear legs and added brake lines Added raised rivets under the rear of the fuselage and parachute pack housing Scratchbuilt inner and outer pylons Scratchbuilt gun pod added 2 new aerials Scratchbuilt CBLS 200 pods added a highly modified Matterhorn circle det cord to the canopy Scribed a whole heap of missed panel lines scratchbuilt the two horizontal antenna's eather side of the tail Removed the vortex generators aft of the outer wing fence And I still have lots to do! The Hunter is on the Shelf of Doom until I can match accurate colours of the Cam. Eric. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 25, 2013 Share Posted May 25, 2013 Looks amazing Eric. Can't wait to see it at Expo! Kev Link to comment Share on other sites More sharing options...
shaky962 Posted May 25, 2013 Share Posted May 25, 2013 Eric you make really an amazing work!!!!!!!!!! Link to comment Share on other sites More sharing options...
mgbgtv8steve Posted May 25, 2013 Share Posted May 25, 2013 Thank you Eric for detailing exactly what's needed to bring this kit up to such a high standard - now which bits are available from you 'cos I really want to do an RAF Hawk T.2? Steve S. Link to comment Share on other sites More sharing options...
ericg Posted May 26, 2013 Author Share Posted May 26, 2013 Since I am all about tweaking this kit (and in this late stage I shouldn't be doing stuff like this... ) I really have something for sight gauges, so I had to come up with something creative to depict the one that is on the right hand side of the fuselage. Here is the kit fuselage, notice the small raised ring above and to the left of the Danger Hot Air decal. Decal no. 156 is supposed to go over the top of it, I am pretty sure it is too big and there certainly wont be any depth to it. I drilled out the raised circle, ensuring there was enough of a ring left. I then punched out the decal to size, as well as a disk of thin plastic card, and some silver decal, all the same size. I then very carefully removed some of the yellow portion of the decal, leaving some of the vertical black line. and this is result. this small disk then drops straight into the hole drilled previously. Once i have finished with the final clear coat on the model, I will then pop a drop of clear glue into the hole to simulate glass.Notice by removing some of the yellow, I have given it a level below full reading. Whitey 1 Link to comment Share on other sites More sharing options...
