ericg
Kinetic Hawk RAAF, FINISHED!!!!!!!!
Guest Peterpools
Eric
Looking simply stellar... The Archer Rivets are on must buy and try list, after seeing how realistic they look in your hands.
Keep 'em coming
:popcorn: :popcorn:
I was thinking about the loadout for this model and I really wanted to do one with the CBLS 200 practice bomb dispensers. I am not aware of anyone that makes these particular units, so I conjured one up in google sketch up (a CAD program) and printed it out on my 3D printer. All I need to do is work out which bomblets the RAAF machines carried and I will make those up as well.
Here is the Master, I will cast this one up and refine the resin unit and then recast it once I have put some additional detail into it.
I also 3D printed a casting block:
Ready for moulding.
Guest Peterpools
Eric
WOW ... now that's scratch building. Looking real good
Keep 'em coming
:popcorn: :popcorn:
Here is the BDU-33 that I have just finished, well, this one is the first draft anyway. I have made it in two pieces so that I can cast it and they have been placed together in these shots. I will modify this one slightly as there is still some work to do. (it does look a little `fat' in these pics)
Here is how I did it. A block of evergreen plastic, a dremel and a scalpel...... I drilled some brass rod into the guts of the plastic so that the dremel had something to grip.
7FC0231B-6DA4-4CE3-8F71-1A0B8AD06395-101
280D3AFD-655F-40D6-8FE3-CFA59B71E6D5-101
Here it is placed inside the CBLS (this is the first resin copy of my CBLS master) for fit. Looks OK. I will make the mounts soon.
FB919DFF-A1CB-45A8-8D89-500B820A2FDD-101
I managed to get the HUD completed, this is a very trick part of the kit and very fiddly. The kit HUD glass is pretty thick so I sanded it down and then polished each piece to make them nice and clear. after a few attempts to get it right I finally was able to superglue each part into place. I then dipped the entire assembly in future and am very happy how it came out.
9CED0A2C-9688-43E5-90F6-7548C71292F0-138
c6464dc0-f159-44c5-9c61-01176300fd63_zps
Another part of the kit I wasn't happy with is the two holes either side of the rear fuselage. It is possible to see straight through to the other side. I used a cotton bud stalk to fill in the holes and as they are put in at an angle it is now not posisble to see straight through.
1BA08B75-88CC-4C7C-8871-3FC0A8393A13-138
F95A20BD-ABC6-4887-934C-C9B7CA354E8E-138
064BD280-03E1-43C9-88A6-49DA41523F89-138
There is a bit of hardware that should be on the rear fuselage above the horizontal stabilizer, which I knew I wouldn't be able to live with if I didn't add it.
133038E3-4333-4A1A-821B-5176F97C8B43-138
I couldn't fit my circle template into the space required to scribe one of the inspection panels, so I punched an appropriate sized circle out of some of the photoetch sheet with my Waldron punch and die set.
604AE815-BEC6-415D-BD52-59D9D5315295-138
2800AD31-FA43-4D79-A13E-EE42255BF9D3-138
Here is the BDU-33 in resin. Fiddly little things but they came out OK. The 2 that I have done so far are my test units to see how they fit in the CBLS pods. I still need to refine them slighty to make them perfect and then I will mould them so that I am able to do many at a time instead of 1.
5EBD429D-3A58-4C86-8E18-16922FDB0DCB-138
07b316ae-1657-4431-9a8a-c2fd0d6628ef_zps
I have moulded the bracket mechanism integrally with the Bomblet so that they are easy to cast and there are less parts to worry about.
the fit longitudinally:
B587E291-2FDB-4CA3-A72D-4368D5A65149-138
The fit laterally.
A63E0837-C565-4877-AB56-A85F7D04CFB1-138
Hi dan.
Yes they are one part moulds. I find that one part moulds are easier to use but they don't last as long as they get more if a work out when releasing the part. Glad you are enjoying the thread.
Eric
Guest Peterpools
Eric
Immensely enjoying and learning a host of new techniques all along the way. Fantastic work on the HUD and the rear fuselage details. Simply stellar work. :thumbsup: :thumbsup:
Keep 'em coming
:popcorn: :popcorn:
