LSP_Paul Posted February 17, 2013 Share Posted February 17, 2013 Really nice work on the pit Eric! Those seats are gonna look the biz! Keep up the great work on this really neat aircraft. All the best, Paul Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 17, 2013 Share Posted February 17, 2013 Eric Looking good Keep 'em coming Link to comment Share on other sites More sharing options...
Derek B Posted February 17, 2013 Share Posted February 17, 2013 Excellent work Eric - Definitely a huge improvement on the standard kit parts! Derek Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 17, 2013 Share Posted February 17, 2013 You're doing a great job on the cockpit. I've left mine OOB for the most part so it's great to see a more detailed approach. So now that you've taken all the bits from the F-18 kit, what do you plan to use there to replace them? Carl Link to comment Share on other sites More sharing options...
ericg Posted March 9, 2013 Author Share Posted March 9, 2013 HI Carl, I built the Hornet ages ago and used an Aires cockpit, so there were plenty of spares. Onto the Progress, I have advanced steadily on this build and have the fuselage closed up and the main wings on. I have started detailing the airframe according to my references to make it as detailed as possible to the RAAF machine. Here are the huge gaps that are left after gluing the fuselage and wings together. There is a massive trench down the middle of the panel aft of the front wheel bay which will require alot of attention as it isn't supposed to be there. The slightly overdone raised rivet detail seems to be melted down around the panel aft of the airbrake housing, not sure how I will fix that. Onto the changes. The rear fuselage has a bump on it which I felt was a little soft, so I made a new `bump' from sprue. There are some glo panel formation lights that reside in this part of the fuselage as well so I fabricated the raised panel from thin tin that they sit on. Before: After: The nose of the Hawk also has some raised panels (maybe for the pilots beers?) that I wanted to replicate so I punched some plastic card cirlces and modified the nose to suit. Before: After: luis pacheco 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 9, 2013 Share Posted March 9, 2013 Eric Would have expected a little better fit from Kinetic but without a blink of the eye (I'm sure it took a lot longer then that) the fixes and corrections are done. Nice work on fixing the trouble spots and putting them behind you. Keep 'em coming :popcorn: Link to comment Share on other sites More sharing options...
Kagemusha Posted March 9, 2013 Share Posted March 9, 2013 Nice to see more progress Eric, incidentally the panels for the nose are provided on the etch sheet. Link to comment Share on other sites More sharing options...
LSP_Paul Posted March 10, 2013 Share Posted March 10, 2013 Nice Job Eric, Shes coming along well! Keep up the great work, Paul Link to comment Share on other sites More sharing options...
ericg Posted March 12, 2013 Author Share Posted March 12, 2013 Hi Kagemusha, I just noticed! oh well, I figured that the plastic card panels would be easier to work and apply detail to as in this pic. I have also added another round panel to the right hand side of the nose cone: I have added some of the panels required for the formation lights, these are on the photo etch sheet, but I wanted to do something different. I have also begun deleting some of the panels that weren't showing up in my references inmmediatly below the formation lights and will rescribe the correct ones. I also added the little strip on the lower strakes, as well as hollowed out the small tube that sticks out in front of the strakes. Here are the photo etch vents which actually settle into the plastic quite nicely once the join is coated with mr surfacer and sanded. One are which I thought needed attention was the leading edge wing root join. Rather than rescride the very soft detail of this panel I thought it would be easier to do something else. As you can see it is very softly detailed and there should be a definate panel over the join. A template was made from paper, and traced onto thin aluminium I then preshaped the piece and then glued it to the join. I then burnished the panel with various tools and then sanded it to make it nice and smooth. both finished they complete that area of the model nicely and will look great once primed. Derek B and Whitey 2 Link to comment Share on other sites More sharing options...
Whitey Posted March 12, 2013 Share Posted March 12, 2013 Looking good mate. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted March 12, 2013 Share Posted March 12, 2013 Very neat work Eric! Kev Link to comment Share on other sites More sharing options...
Anthony in NZ Posted March 12, 2013 Share Posted March 12, 2013 Brilliant work Eric! I love the way you tackle things. I love that instrument panel, I have started doing a similar thing on my A-4K panel. Always enjoy your updates Cheers Anthony Link to comment Share on other sites More sharing options...
Derek B Posted March 12, 2013 Share Posted March 12, 2013 Nice attention to detail Eric Derek Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 12, 2013 Share Posted March 12, 2013 ERic Your attention to detail and going the extra mile is amazing. The wing fillet was a perfect touch. Keep 'em coming :popcorn: Link to comment Share on other sites More sharing options...
ericg Posted March 15, 2013 Author Share Posted March 15, 2013 I have finally finished the instrument panels and coamings. I put 143 individual parts into the four major parts of the panel to make what you see here now. As usual I enjoyed this process, tuning many photos of the real thing into hopefully a 3d mini version. Now the hard part will be to paint it. I went from these: To these: Close up front panel Close up rear panel: It all fits! Close up of the front coaming I am going to display this model with some squadron patches and wings: Derek B, Whitey and luis pacheco 3 Link to comment Share on other sites More sharing options...
