Zero77 Posted December 6, 2012 Author Share Posted December 6, 2012 (edited) I have worked on the front and main wheel bay. Actually, i closed the fuselage yesterday, now have to putty / sand / regrave it. I have also progressed a bit on the engine, i will post pics when they would be painted, but i am very happy with my inlet, that i managed to get seamless (it was hard !). Edited December 6, 2012 by Zero77 Link to comment Share on other sites More sharing options...
Guest Posted December 6, 2012 Share Posted December 6, 2012 Very well done ! I like your style................Harv Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 6, 2012 Share Posted December 6, 2012 Wow, great work! Kev Link to comment Share on other sites More sharing options...
mark31 Posted December 6, 2012 Share Posted December 6, 2012 Great work on the wheelbays. Looking forward to ure next update. Mark Link to comment Share on other sites More sharing options...
Zero77 Posted December 10, 2012 Author Share Posted December 10, 2012 New update : I have worked on the engines, or rather on 1 engine because i am not sure yet if i let the engine door open, but anyway it would be only the left one, not both. As i have already shown on another topic, i have spent a lot of time on praparing the inlet ducts in order to have them as seamless as possible. I am quite happy white the result. My process was : gluing, masking the inside except the seam, puttying the seam (with Mr surfacer), smoothing with thinner (mr color thinner), sanding with a piece of sanding paper rolled around a piece of sprue, then polishing with micromesh 3600, regraving the rivets that have almost disappeared (as possible...), spraying a coat of primer (alclad grey primer), then sanding with fine grain (1000) and micromesh, then as the seam was still present next to the entrance of the ducts puttying again, sanding again, micromeshing again, regraving again, then one more coat of primer , then repolishing, then painting with the grey/green (same as the wheel bay) but with an addition of semi-gloss white in order to have a lighter color (if it is too dark, one cant see anything inside those ducts....), and then one more polishing. Link to comment Share on other sites More sharing options...
Zero77 Posted December 10, 2012 Author Share Posted December 10, 2012 I have also progressed on the engine : Link to comment Share on other sites More sharing options...
Zero77 Posted December 10, 2012 Author Share Posted December 10, 2012 (edited) I have added some rivets, pipes and wires, but i only detailed what is visible once in the fuselage. I still dont know if the door will be open or not, so i dont want to spend to much time on detailing something that maybe hidden. And even if i let the door open, only a very few of the engine can be seen. Edited December 10, 2012 by Zero77 Link to comment Share on other sites More sharing options...
Zero77 Posted December 10, 2012 Author Share Posted December 10, 2012 (edited) I have also found a way to correct a bit the flares lauchers. I have moulded (silicone) the rear launchers to have a good template with holes instead of cylinders, and made a copy in resin. And after cutting and modifying the stuff, i managed to obtain quite a good flare box, which i can put in the whole launching device. Edited December 10, 2012 by Zero77 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 10, 2012 Share Posted December 10, 2012 Wow, terrific work mate! Nice problem solving and great paint work. Kev Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 10, 2012 Share Posted December 10, 2012 Spectacular work. One incredible build Keep 'em coming :thumbsup: Peter :popcorn: Link to comment Share on other sites More sharing options...
Zero77 Posted December 18, 2012 Author Share Posted December 18, 2012 (edited) I knew the front wheel bay was always closed when the plane is on the ground, except a very little door, but i never payed attention that the main wheel bays are also almost closed !!!! I just noticed that yesterday.... That's a pity all those nice aires pieces wont be visible when finished... Edited November 4, 2015 by Zero77 Link to comment Share on other sites More sharing options...
Zero77 Posted December 20, 2012 Author Share Posted December 20, 2012 Arg, i cant make my mind if i make the flaps extended or retracted.... I have never seen any picture of a frogfoot with extended flaps when park on the ground (nor the leading edge), but it give the model a bit of life. In addition, the kit flaps are a bit too thick compared to the wing thinckness so when retracted there is a little step, and now the flaps are glued it would be very difficult to thin them without loosing the engraving. I think i will build them extended, and we will see... Extended : Retracted : Any opinion guys? Link to comment Share on other sites More sharing options...
HADman Posted December 20, 2012 Share Posted December 20, 2012 Zero, this is nice building! I will see the progress too Feri Link to comment Share on other sites More sharing options...
Guest Posted December 20, 2012 Share Posted December 20, 2012 Just amazing, Zero ! Love what your doing. I would like to get one of these, someday............Harv Link to comment Share on other sites More sharing options...
Zero77 Posted December 21, 2012 Author Share Posted December 21, 2012 (edited) The fisher resin wheels. The details are amazing, and they are a great addition compared to the OOB wheels (with vinyl tyres...). On the other hand, i am not very satisfied with my paint job. I think i will clean this dirt, add a slight coat of flat varnish and re-dust them again. Edited December 21, 2012 by Zero77 Link to comment Share on other sites More sharing options...
