mattlow Posted January 21, 2012 Share Posted January 21, 2012 Loic 1. Depends on how you wish to display the engine. If it is in situ, there would ne no need for the bolts as the manifold would be covered by the exhausts and probably also by the box like covering structure usually seen (seems to be used to heat air and pipe it to wings in most cases). If it were displayed next to a/c as a new engine there are usually cover plates over the manifolds (and front and rear often have support legs bolted to them). Maybe holes would be better - remember you could get the current way you've done it cast and then modify a copy - safer...? 2. I'd do the the air system first and then make sure fuel injection system fit the remaining space. Matt Link to comment Share on other sites More sharing options...
Loic Posted January 21, 2012 Author Share Posted January 21, 2012 Matt, I will leave these as they are for now and see what to do later. I too think I am going to start with the air system for the very same reasons Link to comment Share on other sites More sharing options...
richdlc Posted January 21, 2012 Share Posted January 21, 2012 very cool stuff loic Link to comment Share on other sites More sharing options...
Loic Posted January 22, 2012 Author Share Posted January 22, 2012 Hi guys, and thanks for your kind words Rich. I did work on the air intake manifold yesterday. This is one cool piece and despite I had to take some short cuts, it turned out rather OK. I unfortunatly did not shot much WIP pics... but here is what we have got so far. First couple are just dry fit test shots with the newly detailled cylindre + head blocks: Then the manifold itself made from aluminium tubing, styren and wires. The centre "linking" pieces is not yet completed as I am hesitating between 2 methods to make it: And now, dry fitted on the engine: Even if they are rather small, I like the 24 inlet pipes, they look like my Alfa Romeo intake Manifold .... This is also where I took the bigger short cut as they normally are curved but I was unable to get that effect right on a 2mm long x 2.4 mm OD pipe... I have applied a bit of sanding to simulate the curve and that is good enough I think even if not perfect. Link to comment Share on other sites More sharing options...
Radub Posted January 22, 2012 Share Posted January 22, 2012 Loic, I must say that I love everyhing you are doing with this model. Nice, very nice! Radu Link to comment Share on other sites More sharing options...
Loic Posted January 22, 2012 Author Share Posted January 22, 2012 Many, many thanks mate Link to comment Share on other sites More sharing options...
fozzy Posted January 22, 2012 Share Posted January 22, 2012 True craftmanship !! the engine your building is simply fantastic Loic ...I love watching this build Link to comment Share on other sites More sharing options...
mattlow Posted January 22, 2012 Share Posted January 22, 2012 Holy cow! I reckon, if marketed, this would be the most detailed in-line engine around - looks as good as the Eduard 'Brassin' DB 601. A joy to watch this come together as well. Matt Link to comment Share on other sites More sharing options...
Loic Posted January 22, 2012 Author Share Posted January 22, 2012 Thank a lot guys Matt, I am currently working on the fuel injection unit... that's one funny part to work out ! Stay tuned guys Link to comment Share on other sites More sharing options...
A.Wolf Grant Posted January 22, 2012 Share Posted January 22, 2012 Good Grief ........ Terrific engine build. Obantzzzzzz........... < faints in admiration > Link to comment Share on other sites More sharing options...
Loic Posted January 22, 2012 Author Share Posted January 22, 2012 Thanks Obant Link to comment Share on other sites More sharing options...
richdlc Posted January 22, 2012 Share Posted January 22, 2012 I demand you cast copies - demand it! Link to comment Share on other sites More sharing options...
DougN Posted January 22, 2012 Share Posted January 22, 2012 This engine is really fantastic! I'm sure you could send it to any of the casters out there (like Grey Matters) and they would be happy to cast it up. If the rest of the kit comes out as nice as this engine, it will certainly be a stunner! Doug Link to comment Share on other sites More sharing options...
Loic Posted January 22, 2012 Author Share Posted January 22, 2012 (edited) Hey guys, well, we will see what happen in the future but I heard you Here an update on today's work. First was the rear part of the air intake system. It was "sculpted" from a piece of solid styren. The 2 pieces of metal tubing are here to help centering/positioning the parts. It is only the tubing linking the manifold to the charger that I need to do now. That is not an easy bit cause it needs to be bend just right. I will keep this for later .... Edited January 22, 2012 by Loic Link to comment Share on other sites More sharing options...
Loic Posted January 22, 2012 Author Share Posted January 22, 2012 (edited) ... Then I moved to the fuel injection pump/system. I tryed to shot proper WIP pics, they are not very good but I hope you will like them anyway... First side: Second side: ... Edited January 22, 2012 by Loic Link to comment Share on other sites More sharing options...
