phantomfan Posted November 1, 2011 Share Posted November 1, 2011 Hi all guys, this morning I was inspecting my Trumpeter P-51B kit (Kit #02283 Mustang III) and I have discovered that the painting & markings guide it is not provided... This is a separate sheet than the building instruction, printed in colors on glossy paper. For me a scan will be enough but if anyone has that page stored somewhere, I gladly pay any shipping cost to receive that. Thanks in advance. Regards. Marco Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 1, 2011 Share Posted November 1, 2011 I have kit #02274, and I could scan its markings guide if that's any help to you? Probably not I'd imagine, since it's a different kit with (presumably) different markings. Kev Link to comment Share on other sites More sharing options...
phantomfan Posted November 1, 2011 Author Share Posted November 1, 2011 Hello Kev, thanks for the reply. Unfortunately my kit is the RAF version, even though the plastics are the same the Markings are different. Thanks anyway for the interest. All the best. Marco Link to comment Share on other sites More sharing options...
BloorwestSiR Posted November 1, 2011 Share Posted November 1, 2011 (edited) I have that kit. Let me see if it fits in my scanner and I'll make you a copy. How much of a rush are you in as it may take a day or two to get it? Edit: Found a link with them on-line so here you go: http://www.1999.co.jp/eng/image/10081788t2/60/2 http://www.1999.co.jp/eng/image/10081788t4/60/4 Carl Edited November 1, 2011 by BloorwestSiR Link to comment Share on other sites More sharing options...
phantomfan Posted November 1, 2011 Author Share Posted November 1, 2011 Hi Carl, thanks, I have seen the images of 199.co.jp they are good but I was hoping for something a little better. I don't know if the page will fit a regular scanner, if that is A4 size it will work for sure. In any case, do not worry, I can wait till you can do that. Thanks. Marco Link to comment Share on other sites More sharing options...
Ralph-D Posted November 1, 2011 Share Posted November 1, 2011 Hi Marco, be patient till tomorrow. I need to do the scan in the office. The paint instruction is in A3. Did you finish the P-51 Miss Marilyn II. Salute Ralph Link to comment Share on other sites More sharing options...
Juggernut Posted November 1, 2011 Share Posted November 1, 2011 I've got a solution....put the cover back on the box, walk to your nearest recycling center and toss it in the bin. Then wait until Tamiya releases a P-51B. Yes, that's how bad the Trumpeter P-51B is. Just kidding of course but there are some serious issues with the kit. If you're not aware of them, you will be (best Yoda voice). Link to comment Share on other sites More sharing options...
phantomfan Posted November 1, 2011 Author Share Posted November 1, 2011 Hi Marco, be patient till tomorrow. I need to do the scan in the office. The paint instruction is in A3. Did you finish the P-51 Miss Marilyn II. Salute Ralph Hi Ralph, probably I have a copy of that guide inbound from a my friend, I think I have solved the problem. Anyway I am not building the Miss Marylin II, coould be someone else with a similar ID... Thanks anyway for the help. I've got a solution....put the cover back on the box, walk to your nearest recycling center and toss it in the bin. Then wait until Tamiya releases a P-51B. Yes, that's how bad the Trumpeter P-51B is. Just kidding of course but there are some serious issues with the kit. If you're not aware of them, you will be (best Yoda voice). Hi hope Tamiya will release a B very soon, till then the Trumpeter is the only option and I will go for it trying to solve the main issues... Anyway, thanks for the wise suggestion... Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 1, 2011 Share Posted November 1, 2011 I'd actually love to hear what the main issues are, as I intend to build mine (and the Revell kit!) irrespective of what Tamiya does. It's be good to know what I'm up against. Kev Link to comment Share on other sites More sharing options...
LSP_Ron Posted November 2, 2011 Share Posted November 2, 2011 Check out my build in the in progress section Kev. It shows most of the issues. I can't post a link right now because I am posting on an iPhone Ron Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 2, 2011 Share Posted November 2, 2011 Check out my build in the in progress section Kev. It shows most of the issues. I can't post a link right now because I am posting on an iPhone Ron Thanks Ron. I'll seek it out. Kev Link to comment Share on other sites More sharing options...
LSP_Ron Posted November 2, 2011 Share Posted November 2, 2011 I have a little time to burn before heading out for dinner. Here are some issues as I recall The rear windows are not tall enough and could stand scratch replacments The typical wheel well issue is there as with all kit except tam. Pretty easy fix through AM or scratch. Gear doors are miss shaped. I ignored this. To hard to fix. Inner leading edge of wing has no dihedral. I ignored this also. Cockpit is lacking. Edwards set is a good start to fixing this. Carb intake under spinner is far to small. Tough to fix. I didnt find a solution. Top of cowl is to pointy. No fix known outside milliput and some creative juices. HTH. Got to go. Ron Link to comment Share on other sites More sharing options...
R Palimaka Posted November 2, 2011 Share Posted November 2, 2011 (edited) Ron's list is an excellent overview of the main issues. Two more I found: - the exhausts are not aligned properly, so that they angle up from the panel lines. A bit of a tedious fix but looks much better when straightened - the bottom of the rear fuselage is too square. A little filing and sanding to round out the corners improves things there. Lone Star sells some excellent resin bits for this kit, including a nice cockpit, corrected wheel wells and an absolutely beautiful Malcolm hood complete with rails. I just received my Eduard coloured photo etch, and they will add a lot of realism to the cockpit. That also means I have no more excuses for procrastinating about building my Mustang III for the Mustang Madness GB... Richard Edited November 2, 2011 by R Palimaka Link to comment Share on other sites More sharing options...
phantomfan Posted November 2, 2011 Author Share Posted November 2, 2011 Lone Star sells some excellent resin bits for this kit, including a nice cockpit, corrected wheel wells and an absolutely beautiful Malcolm hood complete with rails. Hi Richard, is the Malcolm Hood a separate set or enclosed with the cockpit? I cannot find the pictures on LS website... Thanks. Marco Link to comment Share on other sites More sharing options...
R Palimaka Posted November 2, 2011 Share Posted November 2, 2011 That's interesting, but you're right, it's no longer on his website. It was a separate set, and came with the rails. Maybe if you contact him directly he might still have them? That would be too bad if he was no longer producing them. Richard Link to comment Share on other sites More sharing options...
