LSP_K2 Posted February 14, 2011 Author Share Posted February 14, 2011 Didn't the "flak boats" have another deck added to the front of the conning tower with additional AAA? J Yes, and that's exactly what I intend to do. A lot of type VIIC's were modified to accomodate additional anti aircraft guns too, so that will be my configuration. Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 15, 2011 Author Share Posted February 15, 2011 Wouldn't you know it? Today I hear that CMK will soon be releasing a 1:72 U-Boat bunker! I will proceed with my own however, as it's very specific to this project. Link to comment Share on other sites More sharing options...
ladder4boy Posted February 16, 2011 Share Posted February 16, 2011 Kevin.. that's how it ALWAYS works! besides, doing it your way will probably be cheaper and more rewarding! or, at least you can tell yourself that! Very interested to see how this comes out. Been wanting to buy one of those 72nd scale u-boats for a long time and do a cut away with all the CMK upgrade stuff.. Man.. so many ideas, so little time! Are you going to do the sub partially submerged? If so, what's your plan for replicating the water? Cheers! Jerry LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 16, 2011 Author Share Posted February 16, 2011 Kevin.. that's how it ALWAYS works! besides, doing it your way will probably be cheaper and more rewarding! or, at least you can tell yourself that! Very interested to see how this comes out. Been wanting to buy one of those 72nd scale u-boats for a long time and do a cut away with all the CMK upgrade stuff.. Man.. so many ideas, so little time! Are you going to do the sub partially submerged? If so, what's your plan for replicating the water? Cheers! Jerry I agree; if you want something brand new, just have me (or anyone else), build one. Building my own will be more rewarding. I'll be building the bunker to fit my idea, not making my idea fit the bunker. Yes, sub will be floating; product used will be Envirotex, probably over a bed of some sort, maybe acrylic sheet. Envirotex Polymer Link to comment Share on other sites More sharing options...
Smokey Posted February 17, 2011 Share Posted February 17, 2011 Kevin, Looking good. I will be following your progress here. I always wanted to do a scene like you are doing with a U-boat. A while back Accurate Armour came out with a 1/35 scale Resin kit of a Type VIIc. It is a massive kit 74" long and it has been in the box since I bought it. I was looking at doing a partially submerge U-boat sitting in a U-boat pen. Don't have the room for a massive kit like that so was thinking of doing a 1/72 scale one for now. Keep up the good work. Dan LSP_K2 1 Link to comment Share on other sites More sharing options...
Cunumdrum61 Posted February 24, 2011 Share Posted February 24, 2011 (edited) Great idea with the U boat pen. I look forward to seeing it progress. I want to add a couple of hints for you in regards to the resin and pouring it Test the polymer resin you are going to use on something else first. Resins produce a lot of heat as they cure and can melt plastic. A helpful hint is when you mix the resin pour it straight into a ziplock bag and then you can squeeze the trap air bubbles out of it before you pour it. To pour just snip off one corner of the ziplock bag and let it flow out to the worksurface and you will have a bubble free pour. Hope that helps you out. Good luck with your project. Edited February 24, 2011 by Cunumdrum61 LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted March 15, 2011 Author Share Posted March 15, 2011 Great idea with the U boat pen. I look forward to seeing it progress. I want to add a couple of hints for you in regards to the resin and pouring it Test the polymer resin you are going to use on something else first. Resins produce a lot of heat as they cure and can melt plastic. A helpful hint is when you mix the resin pour it straight into a ziplock bag and then you can squeeze the trap air bubbles out of it before you pour it. To pour just snip off one corner of the ziplock bag and let it flow out to the worksurface and you will have a bubble free pour. Hope that helps you out. Good luck with your project. This Envirotex product seems to be self de-aerating. When I used it on my Big Boy base, all the bubbles (what there were of them), just rose to the surface and popped. I may end up using mostly acrylic gel medium anyway. Link to comment Share on other sites More sharing options...
JRutman Posted March 16, 2011 Share Posted March 16, 2011 I would go with the gell medium as well buddy. The seawater in those pens was pretty dirty and you would not have to worry about transparency with the water at all. Just worry about the color and the surface sheen. Piece of cake. Cool dio idea J LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted April 5, 2011 Author Share Posted April 5, 2011 I would go with the gell medium as well buddy. The seawater in those pens was pretty dirty and you would not have to worry about transparency with the water at all. Just worry about the color and the surface sheen. Piece of cake. Cool dio ideaJ I'll be running down to my favorite HS Thursday, and pass right by an Art Mart on the way. I'll stop and grab some gel medium then. I'm kind of anxious to play with it to see what can be accomplished. Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 7, 2011 Author Share Posted June 7, 2011 I decided to change gears a bit this afternoon and play with some figures and accessories I'm slowly accumulating for this effort. So far, I've bought two CMK figure sets, and I will undoubtedly be adding more. I want the bunker to look somewhat busy, so I'm guessing between ten and fifteen figures should do it. Link to comment Share on other sites More sharing options...
dodgem37 Posted June 8, 2011 Share Posted June 8, 2011 Das Boot in 3D. I'm looking forward to this. Sincerely, Mark LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 13, 2011 Author Share Posted June 13, 2011 Das Boot in 3D. I'm looking forward to this. Sincerely, Mark Thanks Mark. I've changed my mind regarding the balsa foam; I'll be using 3/4" plywood or foam core instead. The roof, or at least part of it, will still be balsa foam though. More to come. Link to comment Share on other sites More sharing options...
LSP_K2 Posted January 14, 2012 Author Share Posted January 14, 2012 Decided I'd play some more with this today. Somehow, I've lost my scroll saw, so I can't open up areas between bays. I've also come to the determination that Balsa Foam will just be way too expensive for this, so I've opted to go with wood instead. Link to comment Share on other sites More sharing options...
BradG Posted January 15, 2012 Share Posted January 15, 2012 Now this I will be following. Like yourself, I bought two of the Revell Schnellboots to get the quad 20mm so I could build U-Flak 1. LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted January 15, 2012 Author Share Posted January 15, 2012 No further progress can be made on hull until after all these holes are opened up, so I spent some time this evening doing just that. The holes above the upper torpedo tube door will (probably) be under water, so I won't bother with them at this point. Link to comment Share on other sites More sharing options...
