Anthony in NZ
75 Sqn RNZAF Mosquito Detailed Build
Thanks Chris!  I primed it with Mr Surfacer last night ready for  Archer rivets..... Feels like it is coming together ready to work on the upper wells in the wings where all the plumbing is.
But I have to get back to the stbd nacelle so I don't get tooo far behind and forget how I did stuff as I am making it up as I go LOL
Setting up the correct location (this isnt the correct location, just placed in the gap for test fitting etc)for the oil tank and made new lower tank mounts and added some Eduard etch.
Progress is painfully slow I know....
Edited by Anthony in NZ
Hey Anthony
  Just went through your build of the Airfix 1/24 Mosquito. Let me just say WOW! fantastic work. You mentioned you would like some better detailed. 303 machine guns, try this guy on Shapways - 1/24 Browning 303 MkII RAF Set001 by HOLDEN8702. They are 3D printed, they look good. I'm thinking about getting a set for my Mossie.
  Do you have any pictures of the port and starboard interior cockpit walls. Ones that show the placement of the reinforcement circular plates for attaching all the fittings to the inside walls. I found another build of one by ajaycad on here, LSP, but I'm not sure that it's correct, plus he only shows one side. If you have pictures that show this better I would greatly appreciate it. Also he used 3mm dia circles, is this correct? Also what thickness should i use?
Thanks Ron G
Hey Anthony
  I almost forgot could you also post a couple of pictures of the Paragon exhausts for this ki. Im think about modifying the kit parts and want something to go by. I would really like a set of Neils (Paragon) exhausts but I think that would be near impossible, plus I'm retired and on a fixed budget...lol:D
Ron G
Edited by RonGUSA
On 9/3/2019 at 4:41 PM, shark64 said:
BK?
LOL, I was looking at my shelf of doom and thought....."I really should finish that, Oliver would be happy about that too!"
I seriously must get onto finishing off the wiring in the nose so I can close up the fuse
12 hours ago, RonGUSA said:
Hey Anthony
Thanks Ron G
Ok Ron, I will see what I can sort out.  Also hold off, there is a superdetailed Mossie nose gun bay coming for this kit.  It's pretty awesome and extensively researched.
Dave is really a master with the detail he has put on his kit, go with his measurements.  I would have to look through my drawings (I have about 7000) to see if I can find a location diagram of those mounting ferrules.  But in all honesty.  I would locate the throttle box and other items in the cockpit then work off them as references for all the others.  That's what I am doing.
11 hours ago, RonGUSA said:
Hey Anthony
  I almost forgot could you also post a couple of pictures of the Paragon exhausts for this ki. Im think about modifying the kit parts and want something to go by. I would really like a set of Neils (Paragon) exhausts but I think that would be near impossible, plus I'm ret3and on a fixed budget...lol:D
Ron G
I'll take some photos tomorrow, I might even have a spare pair of shrouds...
Thanks for your feedback on this build, its been a long road...
Cheers Anthony
Ok so Ron has got me going on this kit again.
One area I had tried to ignore was the outer wing section profile.  Remember I extended the leading edge to make it pointier?  I thought I would be happy with this, but the more I looked the more I knew the issue was deeper and tried to ignore it.  I will try and illustrate...
Note the wing outer section has a noticeably thinner outer section at the forward spar
This is because the inner section where the radiators are mounted are built up higher for the radiators only on the inboard sections, see here...
Now look at the kit....
I managed to get it back to this, I still need to add a thin shim to restore the outer wing dihedral.  I have put test piece of 30 thou (after the photo) and everything lined up nicely again...phew
Which now gives the correct cross section and 'look' of the wings I was trying to achieve by extending the leading edge and ignoring this bigger issue.
What do you think?
I am just restoring the surface detail on the upper wings and replacing the weather capping strip.  The Port wing will then be fixed and I will run you through how I did it when I do the stbd wing...its not pretty but it worked
Thanks for looking in
Anthony
