spindrift007
British Phantom FG1 1/32 build
Here are some images relating to the my post above ( resin “plug in”)
As you can see the resin part will need a good clean up. I also need to shorted by about 2 -3 mm. The pitting will be the major problem. I have seen that some guys use mr surfacer 1000 to smooth out these sort of things. If anyone knows about this method I would be very interested. The conversion part is just sitting on the kit part at the moment and looks to wide and high in the photo, but it’s about right. Have included images of the original kit part and the Wild Hare conversion set also to give an idea of the differences for the Spray engines.
To answer you question Lee, I had issues with the angles at the edge and also the cuts down the center of the bottom of the airframe. I would love to see some of you photos if you have any.
Some more progress images from my FG.1 build. Slow going with some earthquaking distractions over here. But back into it now!
Work done on intakes, decided that I will use covers, changed my mind , then changed it back! I have 4 other 1/32 Phantom projects planned and all have seamless intakes ready and waiting, so one without I can live with.
The rear underside plug has been cleaned up somewhat, but still needs some work. One of the sprey engines can be seen in aprox in the correct place.
Very nice work Stephen, I hope to be at a similar point in my build shortly. Glad to see you made it over to the GB! Did you cast resin copies of the WH kit, or are you going to go the route shown in the tutorial? keep up the good work! :speak_cool:
Dude, that is looking nice. Looks like your almost done with the major part of the conversion. This is going to be one nice sucker when done. Mike
Hi Lee,
If you are talking about the engines, lets say the WH kitparts were very usful, and have saved alot of time. The rear bottom airframe "plug" was made from a plaster of paris mould from the WH kit as I did not seem to be able to get the shape right as in the tutorial. The rest is by the book (tutorial).
Hi Lee,
Ooops, I just re-read my post, and can see that I was vague- sorry about that.... I was referring to the resin burner cans, if you had cast copies of those too, in addition to the rear fuselage part, or if you were going to scratch those- build looks good! I almost, but not quite, wish that i went the FOD cover route- almost....
Lee
Another update, sorry for the delay but hopefully the hard stuffs over with and now progress should be quicker
I have now finished the major airframe modifications, installed the cockpit and primed the kit. Still needs a touch up here and there but 99% "airframed" to an FR1.
Next will be the wings and tail section, nose and trying to get the rest of the parts into the cockpit!
Look forward to any comments and recommendations.
That looks terrific---
Frank Mitchell
Starting to move ahead on this build now. Hope to get it finished by 14th Aug for the club aircraft comp. Have completed the airframe conversion and now onto the major paint work. Light a/c grey, med grey and barley grey. Preshading is done and the underside painted as you can see. Will be doing top, sides today/ tomorrow. Got to get it finished!!
Looks good but don't rush it just for a contest. Take your time and do it right first as there will be other contests to take it to.
