Bf109 E-4/B "Yellow 6" Oblt. Otto Hintze 3./ Erpr.Gr210 1940
nmayhew
hi
i got the fuselage together, with the aid of my various clamps
i was careful not to use superglue AND misalign the pieces, like i did last time unsure.gif
as you probably know, the pins / holes on the kit pieces are woefully small, verging on the non-existent, and you should view it as a good limited run kit really - at least that way you know what to expect
everything lines up...Tamiya extra fine cement just touched over the join and capillary action takes care of the rest - that's the beauty of using clamps
i glued the pieces from tail / behind the cockpit first, and worked my way forward from there
the cocktail stick is not a hangover from a dinner party sadly cool.gif, but in place to keep the gap between the cockpit instrument panel and the top of the gun deck - for some reason it didn't line up straight on its own
no drama, as long as you dry fit and check before you apply the glue!
in the 2 pics above you can see the large gap still present at the nose
don't be worried if you have this -only minimal force is required to bring them together
i am leaving mine "open" whilst i work out what i am going to do with the engine.
more in a mo
Edited by nmayhew
despite the use of the plasticard insert along the kit spine, i still wasn't 100% happy with the join...here it is after i sprayed with mr surfacer 1200 (rattle can)
this close up shows what i mean - there is almost a furrow at the join
a bit of gentle sanding with 600 grit helps things out
however, once you do this, you lose all the fine rivet detail
now on my previous 109 build i just ignored it - indeed i erroneously sanded away the spine join completely! doh.gif
so, i set about re-doing rivets with my "beading tool", using nearly the finest "point", along the seam line...
and then for some insane reason started to go over all of the other rivets whilst i was at it!!blink.gif
this wasn't very hard actually, as you have the kit once there as a guide, and i must admit it was strangely therapeutic, if cramp-inducing!
i hope that the reivets will therefore show up a bit more once all the primer and pain goes on; we'll see i guess!
before rivets:
after re-rivetting:
not a massive difference, but i'm still learning :)
ok more gripes with eduard again
the gun deck just sits too high - there is no other way to put it - and i remember this being an issue from Frank Crenshaw's build, but obviously only once i had already glued everything in there doh.gif hmmm.gif
it is the ammo feeders that i now remember snipping off in my last build!
note that this is the case irrespective of whether the main cowling goes on or not;; the only way around it if you don't cut the parts down is to have everything exposed forward of the cockpit, which certainly wasn't what i set out to do
apart from that, i think it will be pretty obvious that everything is too high when viewed side on
i shall return to this problem later...
engine next...
right now to the good bit
with my sincerest thanks to the team at Eduard, i am now the proud owner of one of their Brassin range DB601 engines
i will post a few pics and thoughts, but JamesH has just reviewed it on Scale Plastic and Rail if you want the full low-down...
the moulding is exquisite in its detail
and Eduard finally give you a nice resin supercharger intake
i'm not sure if you can seem but in real life the intake grills are angled inwards (thank you Mattlow for highlighting this! coolio.gif) and i think Eduard have captured this:
all my parts were pretty much as pictured in Jim's review apart from the cowling itself, which has a bit of inward warping
i'm not fussed about the warp as i will dip it in hot water and wedge it open with something when the time comes
my main question concerns whether this cowling is meant to fit on top of the engine "closed"? i still don't know if it will
ideally i would like to be able to just wiggle the cowling off, just like they did in real life (it is not a straight liftm as the MG barrels protrude the openings very slightly), in order to show off the nice engine
if it won't fit over, then we are heading into PhilB diorama territory, which i really didn't plan on doing!! ph34r.gif
1. thoughts on what to do with that gun deck
my default option will be to chop it down and, if the main cowling if off, hope that you can't peak underneath and see too much damage!
2. detail pics of the DB601 - preferably maintenance shots of the engine still on / in the plane with just the cowling off
3. colour call outs of the DB601 parts and in particular the wiring and pipes etc (this is the bit that i struggle with)
4. help with whether there should be large stencilled lettering on the engine, and if so where to source...
all suggestions much appreciated!
cheers
Nick
ok a few bits and bobs to add over the past week or so
first up corecting the fuel hatch that is moulded in the wrong place and wrong shape - see screen grab from Frank Crenshaw build on Arc:
here is my plane with what we started with
i used my hasegawa template, which is beautiful, but not so friendly on curved surfaces
had to use real heavy tape to get it conform
the first scribing was done GENTLY (i cannot emphasize this enough) with a needle / sewing pin, and once i had the faintest of grooves (just like me on the dance floor! ninja.gif) i used Radu's scribing tool
hopefully this pic shows it a bit better...
more in a moment
i should add that i have gone rivet crazy, and re-done the whole fuselage, over the past few days
strangely therapeutic, and also a good indicator of whether you need to get your eyes tested, which, indeed, i do notworking.gif
anyway, some early fumblings with the engine
it is doubtful if the engine will fit into the lower cowling "tub"
you can see how much the sides splay out
to get a more accurate idea i glued the cowling together
the covering piece you see here needed quite a bit of sanding to make it fit - on my previous kit i glued it on first i think and had problems - this way is much easier
this kit is NOT hasegawa or tamiya!!
BUT the above ugliness is relatively easy to fix, so if you are prepared for a little work, you will still have a nice looking bird! speak_cool.gif
sanding, or should that be excavations, next!
i used a rotor tool with various attachments to help me sand out the area as recommended by Eduard
i went as far as i dared - holding the fuselage up to the light and parts of the cowling are virtually translucentninja.gif!
the fit is still nonsense BANGHEAD2.jpg (sorry no pic, i forgot)
i would love to be proven wrong, but sadly the only way (i can see) to fit this beautiful resin engine into the kit is to butcher some of the casting on the undersides crying.gif
finally you can see we have a fit, as the exhaust intakes line up (this is a good guide, and how i kknew that we were WAAAY off beforehand)
more in mo
ok final post on this for tonight
once i had a ball-park fit, i set about thinning the edges of the cowling so that it no longer resembles a Tiger tank mantlet!
i also thinned the gun deck cover (this is actually only 1 piece of 3 kit parts which on the real thing was just one part, but you probably all knew that anyway!)
ok i'm done now
next i will remove most the engine strusts from their casting blocks and see whether i attach them first, and insert the engine afterwards - i am leaning towards that solution, but we'll see
cheers for looking
Nick
Hi Mark,
I think that they maybe missed a trick by not providing a new radiator (or is it oil cooler, I never know, but i mean the bit underneath!) and also new lower cowling panels.
I don't think given what the master pattern maker did already for this set that it would too much extra work and it would have the advantage of removing any fit issues whilst providing more detail, and actually you would get to see the detail they already give you in that gorgeous but otherwise unseen detail on the underside of the engine.
Cheers,
Nick
Pity about having to grind down that engine. It is one nice piece of casting. One would think it would fit their own kit.
Ummmmm... ? I just bought that kit too and had been pouring over the four pages of pictured instructions. The page which shows the blower attachment and Engine block fit to the Gun bay, Clearly shows a Tear drop shaped Orange area w/ their symbol for "Grinding" ?
I 'd assume that it is suposed to fit it maybe though that you have to either grind that area out very well with your dremel and/or slice that Bubble in the forward lower nose off and grind away onthe inside of it to mkae it cover back over again ?
I'd scan it here but Id have to post it somewhare else before I could post it and I am short for time just now.
YOurs Mike
YOurs Mike
hi Mike
i am happy to say that if someone can indeed grind out the cowling so that it fits without any chopping of the engine, i would be genuinely pleased to see it!
note also i got it to fit BEFORE i added the big tubing underneath
PM me if you want details
Lovely work as usual there Nick!
Brings back happy memories of grinding off all that lovely detail on my Aires DB605 for my 109 build.
I had exactly the same problems.
The only thing I can think of is that the default setting for these am engines is to have all the detail there.
I think they presume that all the cowlings including the lower one will be displayed open.
I know that my Aires upper cowlings including the one over the Mgs would not fit over the engine/mg's at all.
When the likes of thee and me decide to have the lower cowling closed then its out with the grinder.
Just a thought though, if these am engines/cowling sets are accurate then shouldn't all the cowlings fit over them just like the real thing?????
Still it looks great and you are doing a terrific job! :thumbsup:
Phil
hi Phil,
thanks for your interest - your recent build is for me the benchmark on how to tackle these projects and come up with a very realistic diorama
at present i am fiddling with the gun deck, where only part of the detail will be visible, anyway...
the point is that you have (i presume) an accurate engine, but an injection mould lower cowling, therefore i would not expect a fit; no big deal, but my guess is that even if you thinned the lower cowling to molecular level, it still wouldn't go in there
the upper cowling is a different kettle of fish - that is very thin indeed, but with all that internal rib detail, i think the intention is that it is left upside down to one side
whilst we are on the cowling, there is a glaring error, albeit a small one: the holes for the MGs are almost upright as they are on the original kit cowling, whereas they should be sloped quite appreciably - the little collar pieces, even though chunky and over sized (PE would be better here), should illustrate what i mean if you have a kit to hand
bottom line, this set s very very nice indeed BUT, it could have been SOOO much better if they had given you a resin lower cowling and all the radiator gubbins as well
that way you'd get a real show stopper of a set which would actually be MUCH easier to construct, and one which would likely draw modellers in who otherwise perhaps would be a bit wary of all chopping and grinding
just my 2 new pence...
