My first 1/32
Akondo
 Share
Oxygen hose creation
Completed pilot figure...minus the hook up to the oxygen supply.
First attempt at preshading. I need to upgrade my compressor from my small but trusty Testors mini blue.
Almost there.... :D
This is the part of the hobby I really enjoy. The research and the discussions on the subject is my favorite part. The books and pictures one pours over to find a detail that most people wouldn't even see. It's funny the amount of books I have purchased over the last few years since really getting into the hobby.
I painted the line next to the pilot yellow due to this picture I found in the JaPo book on the 109K4.
It appears that the line comes from a small fuel tank used for priming the engine during starting. Not 100% sure but that was my thinking...it would be nice to be able read the print in the rest of the book.
Again, thanks all for looking and commenting.
Shawn
  • 2 weeks later...
Finally, cockpit complete!
The tail was warped...so I cut it off to do some tweaking
The motor is on its mount that I made out of styrene. I also modified the kit piece to accept the new propeller rod.
Thanks for looking
Shawn
  • 9 months later...
I'm back to continue work on my 109K4. With the help of the forums I was able to go through and see where I left of and to get re-inspired with this project.
I glued the halves together and closed off the tail wheel doors.
There was a bad alignment issue at the base of the tail, but some putty and fine sanding should fix the problem.
I purchased a Loon Models tail. Since I'm running a light to the back I chose to modify the kit piece.
Now I need to figure out how to scribe the tail doors on.
I completed the seams running down the spine and belly. Also finished scribing the tail-wheel doors(2 trys).
So now I'm working on the small compartment door behind the pilot.
From left to right is the kit piece, MDC, and a Eduard photo-etched piece. I like the MDC one.
Super work Shawn, I do like piloted A/C and had a go at one waaay back before the Hasegawa kit. Figured it the best way to finish up the old Revell instead of tossing it.
http://www.largescaleplanes.com/articles/WW2/ErikMark/FW_190D-9/FW_190D-9.php
Is that the spin action motor? I will be following this one so keep posting! Looking great.
Thanks for the comments. The motor came with the Dynamic Scale Modeling sound board kit.
Ran into a slight issue...the MDC piece is a hair too small...soooo
I think I may just do a high breed mix of the kit and MDC pieces.
Thanks Harv.
With my focus on the storage compartment I decided to recheck my reference material and found this
These are from the JaPo 109K and Scmolot mysliwski Messerschmitt Bf109K books. I also found on page 119 of the Bf109K-4 Flugzeug-Handbuch an image that clearly shows the compartment shape being more like the eduard photoetched piece.
My thinking is that maybe the other shapes were more for the G-10s and the "eduard" shape was the factory built K-4s
Just something to think about. (not that it will be seen) :rolleyes:
Akondo
 Share
