Erwin Posted August 8, 2010 Share Posted August 8, 2010 Hi, Is it me or doesn't regular kit glue work on 21 st CT kits ? It looks like plastic but doesn't glue like it. Link to comment Share on other sites More sharing options...
phantomdriver Posted August 8, 2010 Share Posted August 8, 2010 Hi, Is it me or doesn't regular kit glue work on 21 st CT kits ? It looks like plastic but doesn't glue like it. Erwin, CA/ Epoxy works perfectly Ed Link to comment Share on other sites More sharing options...
cipher74 Posted August 8, 2010 Share Posted August 8, 2010 Hi, Is it me or doesn't regular kit glue work on 21 st CT kits ? It looks like plastic but doesn't glue like it. Tenax 7R and Amroid Pro Weld also works nicely. I used both and CA glue as well. D Link to comment Share on other sites More sharing options...
KOTR Posted August 8, 2010 Share Posted August 8, 2010 Kibri liquid plastic glue #9996 does the work for me. Might be easier to get in Belgium than Tenax or Pro Weld. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 8, 2010 Share Posted August 8, 2010 I have no idea what kind of plastic the 21st Century kits are made from, but it's definitely not your garden variety polystyrene. It feels more like a cross between ABS and polythene. Really strong liquid cements will indeed be effective on it, but most other types less so. I found Tamiya Extra thin only marginally effective, and switched to using CA (super glue) instead. Kev Link to comment Share on other sites More sharing options...
maverick728470 Posted August 11, 2010 Share Posted August 11, 2010 Erwin, The only glue that will work on the 21rtC kits is super glue and a hardener.As for the plastic.One could compare it to the plastic as to the plastic straws one uses for drinking out of a take out from a gas station we use here.May sound strange.But some plastic has a different type of polyurathane formula as to the smoothness of the plastic.Larry Link to comment Share on other sites More sharing options...
tomp. Posted August 11, 2010 Share Posted August 11, 2010 The plastic is ABS. The best optiona are CA and Proweld and I've had some luck with Tamiya extra thin. I use CA for filling the trench like panel lines for rescribing. Link to comment Share on other sites More sharing options...
