blackbetty Posted June 21, 2010 Author Share Posted June 21, 2010 thank you, mark i mounted the speedbrake next, to help in positioning the bases Link to comment Share on other sites More sharing options...
blackbetty Posted June 21, 2010 Author Share Posted June 21, 2010 from the side Link to comment Share on other sites More sharing options...
blackbetty Posted June 21, 2010 Author Share Posted June 21, 2010 with some mr.dissolved putty and a q-tip with thinner i closed the small remaining gaps sanding them will be next Link to comment Share on other sites More sharing options...
blackbetty Posted June 21, 2010 Author Share Posted June 21, 2010 the gun bulges are on Link to comment Share on other sites More sharing options...
blackbetty Posted June 21, 2010 Author Share Posted June 21, 2010 and i located the place for the posts of the LORAN antenna using the pic i will take a measurement of that antenna from the tamiya F-4D kit to see if its similar in lenght (allthough i know it has three posts, the hunter has only two ) more to come, stay tuned Link to comment Share on other sites More sharing options...
blackbetty Posted June 22, 2010 Author Share Posted June 22, 2010 some primer is in order, so i made some mask out of thin styropor packaging material its thin enough to bend, its soft to wedge in nicely. small gaps can be closed by filling them with strips of the material Link to comment Share on other sites More sharing options...
blackbetty Posted June 22, 2010 Author Share Posted June 22, 2010 this is how they fit, not perfect, but if you dont drown it in paint, it works Link to comment Share on other sites More sharing options...
blackbetty Posted June 22, 2010 Author Share Posted June 22, 2010 another reason not to apply too much paint (at least with laquer based primers): it reacts with the styropor, you can see it in the pic Link to comment Share on other sites More sharing options...
blackbetty Posted June 22, 2010 Author Share Posted June 22, 2010 adding weight to the nose was next i use lead weights that are for balancing tires, the one for the alloy wheels. they come stamped for weight, so if the instructions suggest a weight (as revells do), you can exactly match the number. Link to comment Share on other sites More sharing options...
blackbetty Posted June 22, 2010 Author Share Posted June 22, 2010 the 40gr dont fit the nose, so some were glued above the front wheelwell with thick ca glue dont forget to see if the nose still fits before it cures thanx for watching comment welcome Link to comment Share on other sites More sharing options...
Azgaron Posted June 22, 2010 Share Posted June 22, 2010 Progressing nicely Karl! Good tip for masking the wells. Cheers, Håkan Link to comment Share on other sites More sharing options...
geedubelyer Posted June 23, 2010 Share Posted June 23, 2010 Neat progress Karl. She's starting to look like a Hunter now. Thanks for the tip on using packaging material for masking, clever call. Keep up the progress. Link to comment Share on other sites More sharing options...
spacewolf Posted June 24, 2010 Share Posted June 24, 2010 That masking idea for the well wells is a life saver ! Learning a lot here. Cheers Vaughn Link to comment Share on other sites More sharing options...
blackbetty Posted June 24, 2010 Author Share Posted June 24, 2010 thanx hakan, guy and vaughn for the nice comments, it really helps when somebody appreciates my (mediochre) efforts nose is on, fit is not all that great (my fault) Link to comment Share on other sites More sharing options...
blackbetty Posted June 24, 2010 Author Share Posted June 24, 2010 just a liiittle more sanding and the bases are there Link to comment Share on other sites More sharing options...
