LSP_Kevin Posted June 2, 2010 Share Posted June 2, 2010 Nice work Karl. looks like a Su-7 without the nose Hey, whaddaya know, you're right! Kev Link to comment Share on other sites More sharing options...
Azgaron Posted June 2, 2010 Share Posted June 2, 2010 Nice work so far Karl! Cheers, Håkan Link to comment Share on other sites More sharing options...
blackbetty Posted June 7, 2010 Author Share Posted June 7, 2010 (edited) thanx dave and hakan! taking great care i was able to join the fuselage with the wings without further problems Edited April 6, 2012 by blackbetty Link to comment Share on other sites More sharing options...
blackbetty Posted June 7, 2010 Author Share Posted June 7, 2010 only a minimum amount of putty will be required here Link to comment Share on other sites More sharing options...
blackbetty Posted June 7, 2010 Author Share Posted June 7, 2010 (edited) next i took a look at the loadout the pylons for the kit supplied 100 gallon tanks will move from the stations 2/5 to the stations 1/6 (outermost) on pics the omani birds sport both kinds of tanks, so the bigger tanks of the kit will be used on the stations 2/5 with their respective pylons the launrails for the sidewinders will be mounted inboard (station 3/4). there are no pylons for this in the kit, so i will have to scratch something, maybe using the kitpylons (that are meant to be mounted on 1/6). the LAU-rails were mounted using white painted blocks looking pretty home-brewed on pics Edited April 6, 2012 by blackbetty Link to comment Share on other sites More sharing options...
blackbetty Posted June 10, 2010 Author Share Posted June 10, 2010 the measurements were not easy to come by, i found no drawings of an inboard sidewinder pylon so jakubs excellent site to the help again! this pic shows a loaded and emty pylon and the shadows determine the lenth, so i can get close some more things to see: the chaff/flare expenders on the rear fuselage and the LORAN antenna on the bottom of the fuse (again note shadow) both things i will have to scratchbuild one can also clearly see the position of the (empty) rocket launchers on the outer wings Link to comment Share on other sites More sharing options...
blackbetty Posted June 10, 2010 Author Share Posted June 10, 2010 here you can see the monting position of the pylon (black are the areas that have to be cut off), the launcher and the missile Link to comment Share on other sites More sharing options...
blackbetty Posted June 10, 2010 Author Share Posted June 10, 2010 the pylon now has the correct tapared extension forward and will be puttied and sanded after drying the launcher on the pics doesnt have the gaps the kit part has, so i closed them Link to comment Share on other sites More sharing options...
blackbetty Posted June 10, 2010 Author Share Posted June 10, 2010 windshield is masked and mounted too comments and critics welcome... Link to comment Share on other sites More sharing options...
geedubelyer Posted June 10, 2010 Share Posted June 10, 2010 This is a great project Karl. I'm learning a bunch about the Hunter that I never knew before so thanks for including the background with your build. You got a very neat fit with the wing joints, excellent work there. The windshield looks like it fitted well too. It's hard to tell from the photo but did you paint the inside framework black? I'm impressed by the new AIM-9 rails. She's going to look splendid when you're done. BTW, have you seen the new Zactomodel AIM-9s? http://www.zactomodels.com/ I'm not sure if they'll be any use for what you need as the for-fins look to be a different shape but the resin missiles look phenominal. Keep up the good work. Link to comment Share on other sites More sharing options...
PhilB Posted June 11, 2010 Share Posted June 11, 2010 Karl, Great work with the pylons for the missiles. She's coming together very nicely! Great work, Phil Link to comment Share on other sites More sharing options...
blackbetty Posted June 11, 2010 Author Share Posted June 11, 2010 thanx guy and phil for the comments. i tend to paint the frames the colour they should have on the inside from the outside, because its easier to mask - but, no they are not black (yet) i have seen chris´ and alexanders winders and consider them for a future build. but i am a little reluctant to use them, because they are so much more detailed than the planes i manage to assemble anyway, the pylons and launchers recieved a first guidecoat Link to comment Share on other sites More sharing options...
blackbetty Posted June 11, 2010 Author Share Posted June 11, 2010 and to keep it interresting, part 257 of the "if i wernt so stupid in the first place, i wouldnt have to corret this now"-saga i thought i would slip the exhaust pipe in from the rear after painting - but didnt notice it is conical/has a step, so i didnt get it in Link to comment Share on other sites More sharing options...
blackbetty Posted June 11, 2010 Author Share Posted June 11, 2010 dont you love it when you have to open up an allready finished seam? Link to comment Share on other sites More sharing options...
blackbetty Posted June 11, 2010 Author Share Posted June 11, 2010 i scratched the paint while manipulating the pipe into place, it glues in from the front, so no just snapping in place insert colourful language here oh, the joys of modeling... should have stayed with lego Link to comment Share on other sites More sharing options...
