spacewolf Posted June 26, 2010 Author Share Posted June 26, 2010 Shaping up nicely Vaughn! Excellent work! Cheers, Håkan Thanks Håkan It's coming along well, better than I'd hoped. I just might pull this off yet ! Cheers Vaughn Link to comment Share on other sites More sharing options...
spacewolf Posted June 26, 2010 Author Share Posted June 26, 2010 I wasn't sure I was getting the lines right so afret more fill and sanding, I shot the fuselage with Mr. Surfacer 1000 I'm not sure that I'm satisfied with the curve where the oil cooler intake meets the fuselage but it's close. Size comparison with the old Revel Spitfire. I had thought the nose of the spit would be close but the Lancaster cowling is totally different. Link to comment Share on other sites More sharing options...
spacewolf Posted June 26, 2010 Author Share Posted June 26, 2010 A question/request for help.... does anyone out there have pics of the oil cooler area behind the cooler, the flap area. I have searched on airliners.com and done a google search with no luck. Any help would be greatly appreciated. Cheers Vaughn Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 I'm working slowly on the other fuselage half, getting a bit bogged down so I needed a change of pace. Wings... we need wings ! I grabbed the old Typhoon kit and cut the wing parts off the tree's. So here we are with one wing top half. Cover your eyes if you're sensitive this is gonna get messy! One of the guys here did up a Kate Torpedo bomber using parts from a Zero. His way of making the wings was amazing so I'm going to try and do a similar job here. First cut is here as to remove the molded in angle to the wing top. Edges are trimmed and support tabs glued in. The wing is glued back together without the angle and the inner section which will not be used cut away. Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 Using a shape finder ribs were glued in to help support the wing and keep everything straight. I got all excited and forgot to take pictures as I was going too fast but here is what I did. I cut through the ribs and wing from root to tip. A spacer was cut, then doubled and glued in. Where the ribs had been cut strips were glued in for support. The wing was puttied and sanded. Wing tip shapes and ailerons are yet to be fixed but I'm pleased with progress tonight. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 27, 2010 Share Posted June 27, 2010 That's fantastic work Vaughn! I find myself looking forward to your every update now. One of the guys here did up a Kate Torpedo bomber using parts from a Zero. That was Loic in his famous Carrier GB entry: http://forum.largescaleplanes.com/index.php?showtopic=21139 Fantastic build that. Kev Link to comment Share on other sites More sharing options...
Cees Broere Posted June 27, 2010 Share Posted June 27, 2010 Inspirational modelling, absolutely fantastic. Cheers Cees Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 That's fantastic work Vaughn! I find myself looking forward to your every update now.That was Loic in his famous Carrier GB entry: http://forum.largescaleplanes.com/index.php?showtopic=21139 Fantastic build that. Kev That's the one Kev, jaw dropping build and such a great finish with the canopy ! His work is part of the reason I'm doing this build as I am. It's intimidating to cut up major parts and modify them, but if you plan it out it actually works rather well. Glad you are enjoying... so what aircraft are YOU going to cut up to get what you want ? Cheers Vaughn Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 Inspirational modelling, absolutely fantastic. Cheers Cees Thanks Cees, I'm having a blast with this. Glad you are enjoying ! Cheers Vaughn Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 Just a quick update. After building up the tip edge and trimming the trailing edge I shot it with primer. There is still sanding to do to smooth the surface more but it's coming along. Gun bay, tip light and aileron are rough sketched in place. Cheers Vaughn Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 Going nuts here, on a roll and grooving to 80's music ! (A little Van Halen never hurt anybody !) Starting with the lower wing and this time I've taken pictures ! Ribs were added again for support... Then using a straight edge and a sharp # 11 blade the cut was started. Once I was close to cutting through I flipped the wing over and cut through the ribs, then finished the cut on the wing. Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 Tabs were glued to the under surface to support the insert. The insert was cut and positioned, then glued. The ribs were reinforced where they had been cut. Link to comment Share on other sites More sharing options...
spacewolf Posted June 27, 2010 Author Share Posted June 27, 2010 Because the wing has such a deep profile a tapered insert had to be built up on the leading edge. I made this extra thick as I'm setting the edge of the lower wing back a bit so as to be able to round the leading edge. Once glued and sanded this will look good. Link to comment Share on other sites More sharing options...
Allok Posted June 28, 2010 Share Posted June 28, 2010 Good Stuff Vaughn. I really like the nose. Glad you are enjoying... so what aircraft are YOU going to cut up to get what you want ? I don't know about Kev, but I was thinking of chopping up a PCM Ta 152 to see if I could make a... Ta 152? Link to comment Share on other sites More sharing options...
spacewolf Posted June 28, 2010 Author Share Posted June 28, 2010 Good Stuff Vaughn. I really like the nose.I don't know about Kev, but I was thinking of chopping up a PCM Ta 152 to see if I could make a... Ta 152? .... I have that kit too... go for it and I'll take notes before I build mine !!! Link to comment Share on other sites More sharing options...
