ju 88 cockpit floor
offender
hello i have just started the revell 1/32 ju88 i have noticed from various photos that the cockpit floor is light wood could somebody tell me what the best colour paint to use to get the colour
thanks
rob
Hello Rob
I build a lot of WWI aircraft, so wood gets featured often.
For a light coloured wood, such as ash or beech i usually start with a base of Gunze Desert Yellow, and once properly dry I paint on a thin coat of Yellow Ochre oil paint, and after about 12 hours mix a lighter version of the same colour, and very lightly drag it across the drying coat, with an old knackered brush. this gives an apperance of grain, and although i think my efforts are usually no0t bad, i have to admit i've seen much better.
Once totally dry i use a thinned down mix of Tamiya Satin Clear, and Tamya Clear Yellow to seal it all. I find adding the Satin helps, as it avoids the high gloss sheen you'd get if you used the Tamiya Clear alone - I tend to use that on propellors rather than flooring / panelling.
hope this helps
Rob
