blackbetty Posted October 6, 2009 Author Share Posted October 6, 2009 i am getting ready to button up the fuselage, so i did a little painting on the cockpit. Link to comment Share on other sites More sharing options...
blackbetty Posted October 6, 2009 Author Share Posted October 6, 2009 one more thing to do before closing of the fuselage is fitting the aires wheelwells. i primed them in white and fitted them a lot of times before finally glueing. closing the fuselage will be quite a task, with all the resing going in Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 6, 2009 Share Posted October 6, 2009 Nice work Karl. Looks like you got those wheel bays to fit nicely! Can't wait to see them painted up. Kev Link to comment Share on other sites More sharing options...
Azgaron Posted October 6, 2009 Share Posted October 6, 2009 I agree with Kev! Looking good! Cheers, Håkan Link to comment Share on other sites More sharing options...
Rotorhead Posted October 7, 2009 Share Posted October 7, 2009 Hey blackbetty, Question for you on the Tail Pipe Fix. What did your filling and sanding do to the surrounding detail? Did it rub away much of it? I like the new look of the tailpipe. I'm contemplating that fix as part of my future build also. (I say future because the kit is still enroute). Regards Steve Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 thanks guys as for the rear of the fuselage, steve: i tried to be extra carefull while cutting and fitting, but will likely have to rescribe some seams. not a big problem, because there isnt that much detail to begin with and the fuselage left half to right half fit isnt that good eithter. this trump kit has quite a lot of flash that you dont notice right away, a lot of the parts edges are soft and need to be adressed to fit correctly. it looks like a kit from a very old worn out mold (but its not) the rear stab attachment modification is nearing completion, some more sanding to do Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 wing assembly was straightforward Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 the modified flaps were fitted and positioned in a slight downward angle Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 first try for fuselage fit. i hope with that amount of resin (pit, nose, intake, gearwell) it doesnt need noseweight to sit on its front leg there isnt much room to put any Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 i used the wing to hold the thing together, fit is nice here and shoulnd need reworking Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 you cant say that for the bottom Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 uhhh...oh Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 while it seems that these fit issues are because of the resin used, that isnt true, i tried before without and the fit wasnt stellar either Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 so this is what i will do: contrary to the instructions i will assemble the lower fuselage part/airbrake assembly first and then fit the whole enchillada to the fuse. i was thnking about chickening out first, and displaying the airbrake partially open , but there is a lot of detail inside i would have to scratch. maybe i would be able to finish the build for the 20th aniversary then Link to comment Share on other sites More sharing options...
blackbetty Posted October 8, 2009 Author Share Posted October 8, 2009 you can clearly see where there is work necessary on this pic. see the soft edges of the lower sidepart? the gap in the fairing itself will be closed with thin sheet tell me what you think Link to comment Share on other sites More sharing options...
