AEROPOXY Posted July 12, 2007 Share Posted July 12, 2007 I'm always short with the time to build the kits, so i learn to build few kits simultaneously, so, i started this Brewster Buffalo from Special Hobby, together with Hansa Brandenburg W-20 and 1/32 scale carrier deck tractor, ( see the topics for these kits in Member Builds). I just checked the completness of kit parts and will start the work on this kit tonight, will be made out of box, with standard paint scheme supplied with this kit. Link to comment Share on other sites More sharing options...
AEROPOXY Posted September 7, 2007 Author Share Posted September 7, 2007 Well, here is some pics of Buffalo build process. Lost some time transfering all the pics from old to new PC and arranging them to post it here. Starting with cockpit details, good, clean parts, easy to clean and assemble, And P&W engine, And gun compartment, Link to comment Share on other sites More sharing options...
AEROPOXY Posted September 7, 2007 Author Share Posted September 7, 2007 Fuselage -cockpit sprayed in aluminium(Revell 99) and one coat of water diluted Rotring black draughtsman's ink, and cleaned with cotton swab to achieve a discrete structure details accented, Fuselage assembled,instro panel details,need some drybrashing and Future wash . Link to comment Share on other sites More sharing options...
AEROPOXY Posted September 7, 2007 Author Share Posted September 7, 2007 Fuselage need some filler on joint lines, as well and undercarriage legs, P&W drybrushed, front view, rear view, More will follow, RGDS AEROPOXY Link to comment Share on other sites More sharing options...
SeanH Posted September 7, 2007 Share Posted September 7, 2007 Hi Aeropoxy It looks really nice. You did not have to add any extra stuff to make it look good. I have the new P-39 kit from these guys and it looks the same. I do not think that I would have to add very much of anything extra to make it look nice. Also instead of taking months, like my current Revell P-40E, I think that I will be able to do this relatively quickly OOB. How do you like the OOB detail on your Buffalo? Link to comment Share on other sites More sharing options...
AEROPOXY Posted September 8, 2007 Author Share Posted September 8, 2007 How do you like the OOB detail on your Buffalo? Kit comes as complete pack,no need for any aftermarket, and resin and PE parts included are of high quality. Link to comment Share on other sites More sharing options...
AEROPOXY Posted September 8, 2007 Author Share Posted September 8, 2007 And todays update of Buffalo build. Sanded, polished and rescribed fuselage details, Glued wings and tailplanes, Minor filler intervention is need on horisontal stabiliser-fuselage join lines, Link to comment Share on other sites More sharing options...
Impatient Pete Posted September 8, 2007 Share Posted September 8, 2007 It's looking great so far! Pete Link to comment Share on other sites More sharing options...
Azgaron Posted September 8, 2007 Share Posted September 8, 2007 Looks good so far! One question, admitting I don't know much about Buffaloes, but are there different colors inside the wheel wells in this one and in the ones with bluegrey/lightgrey scheme at Midway? Pics I've seen shows light grey. Also (while I'm at it) is the color on top of the IP black? Azgaron Link to comment Share on other sites More sharing options...
Guest Rigor Posted September 8, 2007 Share Posted September 8, 2007 look's good and a quick build with i could build that fast Link to comment Share on other sites More sharing options...
AEROPOXY Posted September 9, 2007 Author Share Posted September 9, 2007 Hi, Buffalo will be in boxart presented-Yellow wings scheme (see top of this topic), and instruction says aluminium cockpit,yellow zinc chromate engine and undercarriage compartment. Have no idea about bluegrey/lightgrey Midway scheme . Link to comment Share on other sites More sharing options...
Azgaron Posted September 9, 2007 Share Posted September 9, 2007 Ok, thanks! I think I'll go for lightgrey, and if turns out to be wrong, it's easily fixed. Azgaron Link to comment Share on other sites More sharing options...
Brandon Wood Posted September 10, 2007 Share Posted September 10, 2007 Yellow-wing F2A-1s and F2A-2s had aluminium laquer wheel wells, same color as the fuselge color. F2A-3s in the overall light gray and blue-gray over light gray scheme had light gry wheel wells. For anyone building the 1/32 Trumpeter F4F-3s and -4s, the same "formula" is applicable. BW Link to comment Share on other sites More sharing options...
Azgaron Posted September 11, 2007 Share Posted September 11, 2007 Thanks Brandon! Azgaron Link to comment Share on other sites More sharing options...
AEROPOXY Posted September 15, 2007 Author Share Posted September 15, 2007 I hope this weekend will finish this bird, Canopy was masked and some putty applied at windskrin base, there is a gap of some 1mm, in fact, whole canopy is problematic, not so good fit, some where is too wide, and on some places too narrow, so, some trimming/sanding and some putty is necessary. For small cracks/gaps i use automotive acrylic putty, not regular modeling putty.This "Lechler Spat-O-Rapid" is fast setting, fine grade putty. Then i masked canopy frames, first vertical, and after spraying with aluminium ( Revell 99) and drying, will do the same in horisontal way. After this, some final touch with fine pointed brush will be done. Its time for wings, Trainer yellow, mixed from Revell Lufthansa Yellow-semi gloss and Lemon yellow, gloss paint. here is the first part of paint job, yellow was sparayed over the wings and tailplane. And just a shot of prop blade matt black spraying, yellow wing tips will follow, So,thats all for now, hurry to see F1 qualifications at BELGIUM | Spa-Francorchamps,while the yellow paint dries. Updated, KIMI was fastest today, Link to comment Share on other sites More sharing options...
