Adrian A. Posted January 13, 2007 Author Share Posted January 13, 2007 The worse area I had on closing the fuse was the lower front. It popped oped before I realized I had not quite correctly aligned the engine - I felt the motor mount pop into place when I tried to close the gap but it was a little too late. I had to work on it for a while before I got it straight. I'll have quite a bit of sanding on this part. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 13, 2007 Author Share Posted January 13, 2007 This pic is of my test fit on the wings. After reading Ian's post on the gap at the wingroot, I was a little concerned. I have to say that the fit at the wingroot was surprisingly perfect! It was so tight I almost thought I was going to have to do a little sanding. It was a relief to have it fit so well. I did initially leave the cockpit floor & radio deck unglued in anticipation of having to shim it with some sheet styrene if a gap was evident. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 13, 2007 Author Share Posted January 13, 2007 My last pic for the night is a closer view of the wing fit. I'll have to use just a small bit of filling & sanding & hopefully I'll have a nice smooth join. Thanks for looking! Adrian A. Link to comment Share on other sites More sharing options...
Ian A Posted January 14, 2007 Share Posted January 14, 2007 Looking great, mate. Sorry to have caused the concern. As you said, the cockpit spreads it a fair bit! I've actually worked out that I'm going to have to use a spreader on mine as well, but that's not a problem. Your build is coming along really well. Keep it up, can't wait to see her finished. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 15, 2007 Author Share Posted January 15, 2007 Not to worry Ian, I was anticipating it fitting better than what you had in your pic because of the cockpit. I was surprised that it fit so well, a very pleasant surprise to be sure. This weekend was almost a bust on working on 'Ina' - been out of town for a good part of it. I did manage to get to Hobby Lobby yesterday & get a K & S mini tubing cutter. It was one of those 'had to have' tools. I couldn't do the machine guns without it. The next few pics are of the work I did tonight on 'Ina' - I just had to try out my new cutter, so I did a 'test' run on the machine guns. These are just the blast tubes & barrels protruding from the leading edge - not the gunbay M.G.'s. I made these out of 3/32 & 1/16 brass tubing, I'll probably redo them now that I've worked the correct size/depth of them out on this test run. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 15, 2007 Author Share Posted January 15, 2007 Pic # 2 Sorry this ones a little on the blurry side - I have got to get a new camera!! Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 15, 2007 Author Share Posted January 15, 2007 Pic # 3 Top view - the inboard gun seems to be cocked just a bit, I'll have that straight before it's glued in place. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 15, 2007 Author Share Posted January 15, 2007 Pic # 4 Top view showing both sides. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 15, 2007 Author Share Posted January 15, 2007 Last pic for the night is of the other side - sorry again for the blurry shot. Like I mentioned, these are just 'test' shots - the final setup will probably run all 4 guns flush with the leading edge. I'll do a goggle search & see if I can come up with a few photo's showing the actual placement. As far as I know, I don't think they actually protruded as far out as I have the inboard set, although they may be offset a bit. To be honest, the only reason I have them that far out is I messed up cutting the first one & decided to see what it would look like! Just trying to have a little fun with it!! Thanks for looking! Adrian A. Link to comment Share on other sites More sharing options...
Erwin Posted January 15, 2007 Share Posted January 15, 2007 Nice barrels. Makes it look just that bit more real. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 16, 2007 Author Share Posted January 16, 2007 I managed to work on 'Ina' again tonight - did a bit of seam work on the fuse. I had started a little last night (as is evident in the pics I posted of my 'test' machine guns) with two different grit sanding sticks. Tonight, I smoothed the seams even more with a fine grit sanding stick, then I went with a 500 grit wet dry, then 1000 grit, 1500 grit & finished off with 2000 grit. I have to admit it's not quite perfect yet but it's getting close enough for me. I'll probably do a little more filler work (on the bottom rear fuse - the seam popped open a bit - I'll have to re-glue & fill tomorrow or so). The raised detail on the fuse is giving me a bit of a time - I have to be very careful & not to destroy any (or much anyway) detail. I'm not quite sure how I could re-add raised detail. I've decided not to try my hand at sanding & re-scribing. I've never done it before & I'll be satisfied with 'Ina' when I'm done - I'd rather not pooch the whole job by trying to re-scribe it. Pic # 1 is of the nose. I've got a little more work on the framing to do. I'll probably fill the holes I drilled, then re-drill them in straight pairs, they don't match up very well as they are now. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 16, 2007 Author Share Posted January 16, 2007 Pic # 2 shows the top rear fuse. This area was real tricky - I was concerned about wiping out the rivet detail on such a visible spot. This area took me quite a while. But after four passes with the different grade sandpaper, it came out just fine. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 16, 2007 Author Share Posted January 16, 2007 Pic # 3 is of the overall top view. The seam is probably the best I've done to date (which really ain't saying too much!) But, it's getting better as I go. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 16, 2007 Author Share Posted January 16, 2007 Pic # 4 is of the bottom of the nose that gave me such a fit when I was buttoning up the fuse. After quite a bit of sanding it came out pretty good - it needs just a little more attention & it should be fine. Adrian A. Link to comment Share on other sites More sharing options...
Adrian A. Posted January 16, 2007 Author Share Posted January 16, 2007 Last pic of the night is of the bottom rear fuse - it popped apart when I was handling it in front of the tailwheel. It shouldn't be to hard but sometimes with this build I think I take two steps forward & one step back! Thanks for looking!! Adrian A. Link to comment Share on other sites More sharing options...
