Cheetah11 Posted October 1 Posted October 1 I came upon a profile by Claes Sunden of a Me 109 night fighter and since I still have a few Hasegawa Me 109 models in the stash I decided to model it. Almost OOB. The only additions were brass barrels from Master and foil seat belts. Spinner and prop from Revell. The fuselage was stretched 3 mm and the slats corrected. The photo of the real subject opened a small can of worms. The Werk no was airbrushed out on the photo but according to the Falken Eins website it is a G-6 and not a G-5. The head armour was also removed on these planes. Cheers Nick alain11, aircare84, Mals Way and 19 others 22
Kais Posted October 1 Posted October 1 Mighty fine Cheetah, You caught the short fuselage on the Hasegawa 109 !!Bravo. 3mm total, but I see two splices. What the break down? Congratulations! Martinnfb 1
Cheetah11 Posted October 2 Author Posted October 2 (edited) On 10/1/2026 at 4:37 AM, Kais said: Mighty fine Cheetah, You caught the short fuselage on the Hasegawa 109 !!Bravo. 3mm total, but I see two splices. What the break down? Congratulations! Hi Kais, The front is 2mm and the rear (on the joint of the fuselage) is 1 mm. BTW the G-10 and K-4 from Hasegawa have the correct lenght. Cheers Nick Edited October 2 by Cheetah11 Kais, Martinnfb and IainM 3
mattlow Posted October 4 Posted October 4 (edited) Nice build and good work to correct the length.. If there's a photo of the cockpit area of this machine, you can identify a 'de-pressurised' G-5 airframe by the little desiccant capsules which were retained in the windscreen. Light coloured disks. EDIT: Hi again. I assumed you'd want to know this. If you follow this link to another build (https://modelingmadness.com/review/axis/luft/109/pres109g5.htm) there's a photo of White 4 which clearly shows the pressurised canopy armour. This essentially sealed off the cockpit from the rear glazed area. The fact this is still present would say to me - just a supposition - that this machine is still pressurised. Why? Because that armour severely restricted the already poor rearward vision. If the machine wasn't pressurised it would be a simple matter to fit a standard G-6 canopy in its place. I agree about the swastika. If you look at the machine in the background,there's something there that looks like a swastika with a blob in the middle to obscure it. Matt Edited October 5 by mattlow Martinnfb 1
Cheetah11 Posted October 7 Author Posted October 7 On 10/4/2026 at 1:04 PM, mattlow said: Nice build and good work to correct the length.. If there's a photo of the cockpit area of this machine, you can identify a 'de-pressurised' G-5 airframe by the little desiccant capsules which were retained in the windscreen. Light coloured disks. EDIT: Hi again. I assumed you'd want to know this. If you follow this link to another build (https://modelingmadness.com/review/axis/luft/109/pres109g5.htm) there's a photo of White 4 which clearly shows the pressurised canopy armour. This essentially sealed off the cockpit from the rear glazed area. The fact this is still present would say to me - just a supposition - that this machine is still pressurised. Why? Because that armour severely restricted the already poor rearward vision. If the machine wasn't pressurised it would be a simple matter to fit a standard G-6 canopy in its place. I agree about the swastika. If you look at the machine in the background,there's something there that looks like a swastika with a blob in the middle to obscure it. Matt Hi Matt thanks for the link and the info. The reason I build mine as a G-6 was the info I found on the Luftwaffe blog Falke Eins during my search for info on this particular machine. I include the screenshot. According to the moderator the aircraft in question is a G-6 and not a G-5 as was commonly believed. This info was based upon the original photo where the Werk No was visible. As you know the G-6 was not pressurised. The larger poto also shows the whistles on the exhaust which was intended to warn Flak crews about the presense of night fighters. The shawow of the building on the left side of the photo also makes detail interpretaion a chalange. The spinner yellow ring was based upon similar marked aircraft of the same unit but it might also be a spiral. Cheers Nick
mattlow Posted October 7 Posted October 7 (edited) Hi Nick Thanks for the article, I couldn't find it when I looked. It's a bit of a tease.. Basically here's a photo, important stuff is obscured, we know what it is but aren't going to tell you. It's a real shame that such images become coveted items and the info they contain is closely guarded. No offence to you, your model is excellent, but the only visible ID feature in that photo is the G-5 style rear pressure bulkhead. I cannot see anyone fitting one of those if it wasn't necessary. Having the Werk number places the machine into a batch of aircraft. My understanding of G-5 and G-6 was that they were produced side-by-side and an individual WNr wouldn't denote the aircraft as being one or the other...? I could be wrong. But I'd want some evidence to back up an assertion that appears to go against the only visible diagnostic feature...? Matt EDIT: If you look at the article, linked HERE, the photo of White 1 clearly shows the pressure bulkhead in the canopy and the desiccant capsules in canopy and windscreen. So I honestly can't see how this is characterised by Falke Eins as a G-6...? Edited October 7 by mattlow
