Things are ramping up around here with kits heading to the cabinet at an unprecedented rate!
Today's completion is @Ali62 Martin Baker MB3.
An entirely 3D printed kit, the 1/32 version is tweaked slight from smaller scales, with a fuselage split and brass inserts for landing gear. An addition of a poster of the box art was welcomed.
First up, the parts were beautifully smooth. YES, there are Striations, but they were the finest I've seen on a 3D kit, and the worst layers were usually hidden on unseen surfaces. Very thoughtfully laid out!
For such a physically large model, there weren't many parts at all, one of the benefits of 3D printing. The breakdown of parts allows the completed cockpit module to be dropped into place after the main structure had been assembled.
My first hurdle was self inflicted: after assembling the fuselage and wings, i dropped the unit, resulting in 3 pieces. interestingly, the fuselage did NOT snap at the joint, rather on a new and winding path.
Whoopsies
20260222_195021
A bit of Bush-Mechanics and a bunch of epoxy glue (Used throughout the build) has it back together unnervingly easily.
20260225_185143
There was a bit of filling and sanding to be done, especially around the wing roots. the underwing radiators made smoothing the joints a bit tricky, especially since the 3D printed resin sands VERY easily.
20260302_230408
20260302_230408 20260313_184014
This allowed for more satisfactory cleanup of the wingroots.
20260316_213350
After the clean up, the usual heave spray of primer filler to make new, slight proud standing, wing root fillets aided in hiding any remaining untidyness.
20260705_181043
Once the fuselage was looking clean enough, the cockpit was dropped into place and entombed by the fuselage section. a but more priming/sanding/filling and the big bits were completed and ready for paint.
20260312_193642
20260313_105032
The kit comes with a lovely @airscale Sutton harness, but knowing itd hardly be  seen under the narrow cockpit, i made my own from masking tape, saving the harness for a more visible project in the future.
20260313_110336
Lately, a breakout of heavy-handedness has resulted in a frustratingly large number of wing tip trailing edge snappages.
20260321_134016
im sure this is fix #57
A dry fit to see some Visual progress.
20260707_224210
The kit comes with pre-cut Vinyl masks for the canopy. mine didnt quite fit. Ill blame shrinkage in the Texas head. No matter, i like masking my own anyway.
20260712_094233
I seem to remember the rudder having rudimentary fabric ribbing molded onto it, but i sanded it off, cut a stencil with the silhouette, and sprayed a few thick coats of primer filler to replicate the fabric covered control surface.
20260712_130609
A coat of primer filler over the top looked the part.
20260712_220901
Wingtip nav lights are supplied as clear resin. I wasn't convinced of being able to get crystal clear results with the resin, and substituted clear Perspex the the light covers. Here you can see both the resin and Perspex polished, and it turns out, you CAN get the resin printed part looking nice and transparent.
20260730_134428
There IS one caveat to that, which we will discover in a little while.....
Built up examples of this kit looked a little too 'clean' to my eyes, so i decided to rivet the airframe. Accurate? probably not, but it certainly breaks up the surface.
20260805_201901 20260806_163023
Now for to hide all those sins!
RAF prototypes of the time all had glorious yellow undersides. Id wanted to try pink-priming, and here was the perfect candidate.
Tests started small, all the gear doors were primed straight from the Tamiya rattle can.
20260731_110012
Then hit with varying layers of SMS yellow
20260731_133851
Looks Yellow to me!
Lets try the whole thing....
20260808_074847
Pictures don't show the colour variance from pre-shading, but it IS there!
20260808_085146
also, i managed to snap off the rudder tip for the milion and oneth time
20260806_172715
The kit comes with water-slide decals, which look perfectly useable, but i prefer painting on my markings, so i drew them up and painted them all on, leving a very colourful looking machine!
20260814_193038
SMS paints were used for the main colours. Ocean grey went on first.
20260815_174640
Then we both studied supplied painting diagram, noting that it didn't quite reflect photos of the real machine.
20260816_122143
I used pohots of the real plane, and Hurricane standard camoflage application charts to choose my demarcations.
20260816_143044
Leeping in mind that the prototype didn't see much use before coming to grief, weathering was kept to a minimum.
For me, the make-or-break factor was going to be the myriad of unpainted quater-turn fasteners holding fuselage paneling in place. see all those little dots?
I had initially drawn and printed hunderds of little Dzus fastener heads, to be installed in the molded in holes around the airframe.
I eventually came to my senses and tried a different, SLIGHTLY more sane aproach.
Micro Solder Balls
20260821_122441
I poured piles onto masking tape and glued them in place with Bae metal Foil adhesive.
20260821_123058
Starting with the wings, the balls were installed one at a time.
20260821_124127
Don't you just LOVE the EUREKA moment!
Nothing left to do but fill the remaining holes!
20260821_150918
Home straight now, i didnt think the kit supplied antenna mast would hold up to the tension of an antenna wire. also, refer back to my bout of ham-fistedness, i wanted a SECURE AND STRONG antenna mast. so i made one from brass sheet and squashed aluminum stube
20260823_151951
After masking was removed, there was a bit of accumulated debris INSIDE the canopy. i found my first ever used for a 'micro brush'
20260823_154357
DeMasking the canopy also revealed that the clear resin parts had reacted negatively with Humbrol Maskol I used to fill in between masking tape borders. Almost as if the maskol had begun eating into the resin. Weird. Luckily, a polish with micromesh and a polish with ScratchX got things shiny again. Note to self: no maskol on clear resin!!
Gaining momentum, i started busting out the precision tooling. Here are the wheel straightening jigs.
20260825_180302
And with that, we are finished!
Edited by RadBaron
The completed model
20260830_145419
20260830_145507
20260830_145453
20260830_145343
20260830_145316
20260830_145237
20260830_145221
20260830_145123
20260830_145028
20260830_145045
20260830_144941
What a beast she is!
20260828_190121
Thanks again to Ali of Aerocraft for putting out this Big Scale version of his MB.3 kit. It's been a fun build and if any of you are on the fence about having a go of a 3D printed kit, don't hesitate. There are so many excellent subjects now being covered by the new age cottage industry, dive in and support your local little guy!
I've got my next 3D printed kit heading towards the bench, i cant wait to get started on it!
Thanks for checking in :thumbsup:
Denzil
35 minutes ago, geedubelyer said:
Superb :clap2:
Really good to see someone tackle something more unusual and with real skill..
You've done a splendid job. Well done :bow:
Cheers,
Guy
24 minutes ago, RCPlym said:
Nice job!
Thankyou very much, gents!
On 9/1/2026 at 9:25 AM, RadBaron said:
The completed model
20260830_145419
20260830_145507
20260830_145453
20260830_145343
20260830_145316
20260830_145237
20260830_145221
20260830_145123
20260830_145028
20260830_145045
20260830_144941
20260828_190121
Denzil
Cool!
May I post it on the website?
:clap2::clap2::clap2:
9 hours ago, scvrobeson said:
That looks awesome! These Aerocraft kits are really nice, I look forward to seeing what Ali can come up with next. The canopy looks comically small on that huge airframe.
Matt
Thanks Matt, yeah I was thinking the same thing during the whole build!
4 hours ago, LSP_Ray said:
Cool!
Certainly mate!
Cheers,
Denzil
Very nice work! Such a badass look!
Might be not cheap to ship to France with shipping and fees... But this kit is definitly on my wishlist !
