Yup - you can call me a mad man!
With the summer holidays here, and lots more bench time available, I always get an itch to start something new. Therefore, it was time to get the old ID Models (now Tigger) kit of the Super Constellation in 1/32nd scale down from the loft and get cracking!
Those who have followed my big vac builds before know these kits are very basic indeed, but that's all part of the fun. Building vacforms is something any reasonably competent modeller can do, but the size of this one does make it quite a challenge. Here's what you get in the box - or in this case a large bin liner - and as you can see it's a right brute... approx.  45" long once the radome is added:
With kits of this nature you need a decent set of plans and I like to use another kit as a guide - in this instance I've been using the excellent Rare Planes vacform which, if reviews are to be believed, is the best rendition of the Connie in 1/72nd scale. Here you can see the size between 1/72 and 1/32 - I'd just finished rubbing down the fuselage when I snapped this shot:
DSC_0517
My initial task was to make a nice strong centre section and wing spars, which I did from 1.5mm plastic card. With the fuselage perfectly circular along the majority of its length, this was relatively simple and didn't take long at all. For the more complex, non-circular sections, I used a profile gauge to get the basic shape, and transferred it on to old cereal packet card to ensure the shape was correct before transferring it on to plastic card:
DSC_0522
After a few bench sessions, the entire fuselage was done:
The basic shape of the nose gear bay was boxed in, and the floor of the flight deck added. Cabin windows were also drilled out at this point:
And with the interior structure in place, the fuselage halves slotted together nicely when it came to test fits:
With everything looking good, some serious nose weight was added, and the interior sprayed black. The fuselage halves were then joined with poly cement for a nice strong join, before a good lashing of P38 automotive filler was applied. After a hefty sanding session, I gave the joints a quick spray of Tamiya white surface primer, and although there are a multitude of sins to sort after this initial sanding/filling cycle, it's not looking too bad, even if I do say so myself!
When it comes to the cockpit and flight deck, I will remove the forward crown area which will enable me to work on the cockpit windows on a small, easy to handle piece as well as giving me access to detail the interior:
The rear end of the fuselage where the tail will attach is all over the place, so I think I will work on this area next whilst it's still reasonably easy to handle.
I'll keep you updated as and when I progress...
All the best,
Tom
Tom,
Evidently the PBY-5A was not big enough? 🤣  I'm amazed how quickly you knocked out the fuselage!
I'll be glued to this thread for sure and will no doubt be mesmerized by the incredible workmanship and problem solving that lies ahead!  I am forever in awe of guys who can bring a vacuform to life while my feeble start on a vac, the F-82 sits in a box, taunting me...
Already looking forward to the next post!
Regards
John
32 minutes ago, Cicchino said:
Tom,
Regards
John
Ha ha thanks, John. I’m a teacher on summer holidays so I have had a lot more bench time than usual. In fact, I’ve had a couple of full days working on it this week so progress has been pretty swift.
The Catalina is still being worked on - I’m making some progress on detailing the interior which is my least liked parts of builds like this as they take so long! This, on the other hand, has only the cockpit to worry about so it’s been much quicker!
Oh cool! The idea of the 1/32 Constellation crosses my mind as I work up the Lockheed Electra Junior for a 3D print, but I’ve came  to the conclusion it’s simply too mind blowing lol. Looking forward to your journey here.
Lockheed  🥂
So glad you've started a thread here on this one, Tom. Amazing project. And you work so fast, too! What you've achieved so far would have taken me a year. Looking forward to your continued progress!
Kev
Kev
Cheers, Kev. As you know I am teacher currently on summer holidays (one of the very few perks of the job) so have been making hay whilst the sun shines. I’ve put in a few full-day shifts on this over the last week - and being a relatively simple shape in regard to most of the bulkheads being perfectly circular, it’s come together really quickly.
Another bonus as the scratch work needed for the interior is really minimal compared so some of the big bombers I’ve done in the past, and only the front of the flight deck will be visible so, again, I’ve been able to progress quickly. And this will be done later in the build once it’s structurally complete and the heavy lifting done. The Catalina, for example, needs all the ribs and stringers adding to the fuselage before I can even think about doing any other internal parts - I hate making cockpits and interiors so work slows measurably when I get to that point!
8 hours ago, Archimedes said:
What a great choice of subject!
I have no doubt of how good this will look in the end. Highly interested in this build!
:popcorn:
kind regards,
Paul
Thanks, Paul - as is usual with my builds it’ll no doubt be a long and winding road to completion, but I’m hoping to get the majority of the main building work completed over the winter in the hope I’ll be ready to paint/spray when the better weather arrives in the spring/summer.
Having said that, that’s been  the plan with a lot of my vac projects, and they end up taking years 😆
5 hours ago, scvrobeson said:
Another fine addition to your hangar of giant builds. I also assume that you have your own hangar in the back garden for your completed planes.
Matt
I wish, Matt! To be honest I don’t know where this will reside once done as my loft is at capacity. I think I’ll move a couple of my older builds on to a museum or two. I’m also considering cannibalising my old 1/32 B-29 I did many years ago - my skills have progressed considerably since then and I look at it now and shudder! The engines could, more or less, be transferred straight into the Connie and being a similar size, it will create room for this!
Tom
Edited by tomprobert
Typos
I'm not much into non-military aircraft...   but the shape of this one has always intrigued me.  I'll definitely be stopping by.  I wonder if anyone has successfully covered a vac-form kit in foil before...
WoW, Vacu modelkit, never done one, and some scratch for the interior.
Good start indeed it is.
Hit the follow button asap, dont want to miss a thing.
What, no internal fuselage details?
Just kidding. Great start, Tom. I'll be following this one although i`m a post-war jet guy. But who could resist a Conny? My absolute favorite prop plane.
Cheers
Rainer
Cheers
Rainer
Cheers, Rainer - I’ll detail the flight deck in due course but other than that, nothing can be seen… thank the Lord.
This will be a Warning Star, so very military - but I know what you mean!
And the thought of natural metal - it’s enough to bring me out in a cold sweat. I’m leaning more towards an all over grey (or should that be gray?) USAF version, although the Navy did some attractive schemes. Time will tell.
As large as that kit is, gray is the way to go!
I definitely can’t fathom trying to do a landing gear for this bird.
