I thought the P-40N-1 was the only hawk with two fifties per wing.
But hey I could be wrong, it has happened before. lol
The p-40L was an attempt to shed some weight off the P-40F. The L had 2 guns per wing, the F had 3. The benefit was negligible, and disliked by pilots. Subsequent variants returned to the 3 guns per wing configuration. Apparently, some P40Ls had the outer row of guns replaced. Therefore, some Ls ended up with a 6 wing gun configuration.
I knew the -1 version of the P40N was a two fifties per wing aircraft(they also reverted back to three per wing with later versions)but did not know this about the earlier marks.
Thanks for the info!
Gerald
Tracking all the above.  I think they just used a blanking plate over the outboard .50 cal machine gun...and left the three gun shell chutes in place...so adding the gun later makes sense if that is all they did.
I was just looking to see if anyone has a detailed picture of the blanking plate...I want to mash together a Trumpeter P-40F and P-40M to get a long tail P-40L (in a two gun config).
Cheers All
Collin
