Good to see it's going together well, in spite of the complexity. Have to ask, can it be built without all the inner details?
Don
Don
Hi Don,
Yes, it is going together well.  Z-M do a first class model, these days.  I think you could build it with a little less of the inner details, starting with omitting the fuel tanks and the oxygen bottles in the fuselage.  I would advise against leaving out the rear fuselage ribs as these hold the four sides of the fuselage together.  They slip in very easily, so just don't paint anything back there.  For the wings, just paint the undercarriage bays and wing spar centre, and put in only what you need for the guns.  The inner wing ribs will need to go in, but this is only one piece and it locates top and bottom wing surfaces as there's no locating pins on these parts.  Also, bear in mind that I've been building this model for just short of a month, and I'm starting to think about paint, so even though it's not Kotare simple, it does go together quite quickly anyway.
Cheers,
Michael
More progress on the Butcher Bird, though progress has been a bit slow due to life stuff.  The cowlings are mostly in place, along with machine guns, gun sight and windscreen and a few other bits.  First up is the oil cooler tank ans supercharger intake covers.   In front of the model is the oil cooler, gun cover and top engine cover.
Next, the machine guns have to be fitted after they are painted.  This is fairly straight forward aside from fitting the brass gun barrels and painting that compressed air tank.  Then the top engine cover can be fitted, which must engage with the three gun synchronization pipes at the back of the top cover.  I've painted the gun troughs first so that I can mask off the gun barrels when I air brush the camo on.
The oil cooler ring and it's armoured front has gone on now, along with the top gun cover and side engine cowls.  The gun and engine cowls are only placed on to test fit, which I'm not happy with.  It looks to me that I've got to remove the supercharger intake cover and refit it properly.  I'll do this when I can test fit the lower engine cowls after they're painted.
This side is OK.
My next step was to fit the main undercarriage legs.  These were painted in RLM02, except for the rubber bellows over the sliding oleo.  Then decals were applied as instructed - all five per side of them :rolleyes:.
These were glued in place after test fitting, along with the actuator arm and spring.  The undercarriage was electrically operated on the FW-190.  The legs themselves go into a square hole in the main wing spar, and have a matching square on the leg mount.  Make sure they're pushed all the way home and that the pin on the back of the leg mount goes into the small hole in one of the frames behind the spar.  That way, the angles will all be correct.
A closer view of the undercarriage leg installation.  Everything fits well and quite easily.  :thumbsup:   Once it's all done and dry, the cover can go on over the leading edge and cannon.  The kit provides undercarriage up/down indicators,but these will be fitted during final fit up.
I jumped forward a little here and fitted the gun sight and glare shield, after each of these were painted.  This is where I ran into a little trouble.  First of all, the gun sight, which is a clear part.  I painted it over all silver, then flat black over that, except for the reflector light, then dark brown for the crash pad and dry brushed the sight in silver to bring out some of the detail.  Clear green was lightly painted around the circumference of the glass reflectors.
Then the glare shield was added.
Problem :doh:.  I fitted it where it wanted to go, which is too far forward.  The windscreen has a separate armour glass piece fitted to it and when these two are placed over the top, the windscreen won't fit.  I took the glare shield off (praise be for extra thin glue!!) and had to modify it and the instrument panel a little, then fit the glare shield a little further back, by the thickness of the armour glass.
It now fits.  This is just a test fit.
Here it is as it is now, with the now masked windscreen in place, along with the brass pitot and aerial beneath the fuselage.  I've also dry fitted the inner cannon covers after painting the camo colours around the overlapping parts of the wing, and have daubed some white paint as primer over the rudder which will be yellow.  The prop is only partially painted and also dry fitted just for the photo.
Lastly, I've fitted the inner wheel well doors in the closed position, as they usually were on early A models when the undercarriage was down.  Most of the photo's I saw when researching which position to fit the doors showed it this way, but open is not wrong either.  However, in the open position, they blank off the exhausts when the engine is fired up which may cause problems.
My next task is to start masking and dry fitting gun and engine cowls, then I can start painting.  I have painted the lower engine cowls and rudder in yellow tonight, so I'll test their fitment next against that pesky misaligned supercharger intake cover.  Then I can paint it, which will be revealed next time.
Cheers,
Michael
On 8/11/2026 at 1:24 AM, Out2gtcha said:
Great work!!
The engine and pit details look exemplary!
Thanks.  It's a nice model, and goes together well despite my increasingly aged fumblefingers :rolleyes:.
Cheers,
Michael
On 8/13/2026 at 2:48 PM, Gazzas said:
All of that work looks great, Michael!   I bought 2 of these and haven't touched them, yet.  Can't wait to see more!
Thanks Gary.  It's a pretty good kit so I hope you enjoy building it.  Just don't use Z-M's green masks on the clear parts.  They don't stick down that well and it seems paint causes them to lift a bit at some edges.  :hmmm:  I've started painting this and it looks like I'll have to remove the masks and chip off some paint from the canopy then polish it up and cut my own masks.
One thing I have noticed is that the clear sprue has the later blown canopy as well.  Is there an A-8 in the offing???  Z-M would need to move the engine forward and provide longer engine cowls, but that's not difficult.
Cheers,
Michael
Progress on this model has been very slow recently due to a lack of workbench time, but I'm trying to pick up the pace a bit.  After my last update, I started on masking, beginning with the lower engine cowls, tail wheel and rudder.  The lower cowl is not glued, but has been painted yellow (RLM04), as has the rudder.  After I took this picture, I stuffed the wheel wells with wheel well shaped foam and placed the gun bay covers in place, but no glue.  I may display this model with lots of stuff open.  I made masks for the undercarriage legs too.
The top camo colours have now been airbrushed on and the wing roots masked off.  The model will be painted grau grun, grau violet, and light blue (RLM65).  I wasn't entirely happy with this so I diffused the edges of green areas.  This picture is before any re do.  Diffusing the green edges didn't work out too well, so I re did all the grau grun.
While waiting for upper surfaces to dry off completely, I started on the canopy.  As I mentioned in a previous post, I ran into problems with the canopy.  I mistakenly used the kit masks which are rubbish, as they start to lift as soon as they see paint.  Here it is painted RLM66 on the outside as I have no inner masks and as can be seen on the forward edges after I removed the kit masks, paint has leaked underneath the masks.  I've used making tape inside to guard against overspray, which has also given me a place to pick up the part.  I spent quite a bit of time getting this off and polishing the clear back into the plastic, then masked off using Tamiya masking tape and have painted it to match the plane.  The canopy will be displayed open, so this is the "narrow" canopy.  The white tape gives me reference point to start cutting my own masks.
Next, the RLM 65 has been applied to the fuselage sides and lower surfaces.  Wings and tail were masked to guard against over spray, and I used tape to get a line to begin the camo pattern on the fuselage.
Here is the model as it is now, partially unmasked and with that hard edge removed on the fuselage sides, with blotches applied.  Notice also the diffused edges of the camo pattern on the wings.
I have a little more painting to do on this before I can start thinking about varnish and decals.  I'm using the kit decals, and the model will represent the plane shown on the box art.  This plane had been repainted in service, hence the mottling down the rear fuselage overpainting a band.  More bands have to be applied on the wings in a slightly lighter shade of the camo colours to cover up more previously applied bands.
Hopefully, by the next update, I'll have the bands done, and varnish/decals/varnish done, ready for final fit up.
Cheers,
Michael
All the painting is now done, so I thought I'd show off the results before I get into varnishing and decaling.  This is the plane it supposed to look when I'm done.  As depicted here, it was flown by Luftwaffe ace Siegfried Schnell, but had been flown by others before he took it over, hence the overpainting of bands on the wings and rear fuselage.
And my model as it is at the time of writing, with as much of the masking removed as can be removed at this stage.
That's all for now.  I'll do a proper update when it's got all the markings on and the last of the masking removed.
Cheers,
Michael
13 hours ago, Uncarina said:
Just catching up Michael. Not sure how I missed this but I love your work on this kit!
Cheers,  Tom
Thanks Tom.  I enjoy building Z-M kits.  Lots of detail and they go together well.  Just waiting very patiently for their P-51B/C to hit the market.
9 hours ago, geedubelyer said:
Nice job on the cammo Michael. Those yellow highlights look great.
Eager to see the markings go on next  :thumbsup:
Thanks Guy.  I'm eager for that too, but trying not to rush this.  I currently don't have any FW-190's on my shelves, so I want this to be a good one.
Cheers,
Michael
20 hours ago, Gazzas said:
Lovely paintwork, Michael!  An A8?   Do tell.
I among the clear parts is the bulged canopy to suit the later 190A variants.  Bigger guns, a longer engine mount and cowlings, and you've got a new variation on this kit.  I'm wondering when, rather than if, Z-M will release this.  I'll be buying one when they do.  Unless I'm wrong and they plane a D in which case I'm also buying one.  That would be relatively easy too.  Jumo engine and annular cooling system and the tail extension, plus some detail changes in the cockpit would do that job.
Cheers,
Michael
Hello Michael
please what's ZM planned for the antenna wire in this version?
Thanks
