LSP_Kevin Posted June 9 Posted June 9 So, it seems I'm fairly active around here: No wonder I don't get many models built! (50,001 now) Kev RadBaron, D.B. Andrus, Christa and 20 others 10 13
CRAZY IVAN5 Posted June 9 Posted June 9 Fairly active?? Why ,Ike ,whatever do you mean? Christa and LSP_Kevin 2
mozart Posted June 9 Posted June 9 Leading from the front Kev……good man! Shoggz, Christa, CRAZY IVAN5 and 2 others 4 1
Out2gtcha Posted June 9 Posted June 9 You're the main reason this place still exists Kev! Kagemusha, mozart, Shoggz and 3 others 6
mozart Posted June 9 Posted June 9 3 hours ago, Out2gtcha said: You're the main reason this place still exists Kev! THAT is so TRUE! LSP_Kevin, Out2gtcha and Phantom2 3
dennismcc Posted June 9 Posted June 9 Now that's not hanging around Kev. Cheers Dennis mozart and LSP_Kevin 2
thierry laurent Posted June 9 Posted June 9 The average amount per day is... rather incredible! 😱 mozart and LSP_Kevin 1 1
MikeC Posted June 9 Posted June 9 On 5,375 I'm only just over 10% of that! Keep up the good work LSP_Kevin 1
Mark P Posted June 9 Posted June 9 Only 48,000 more for me and I will catch up.... Mark Proulx geedubelyer, thierry laurent, LSP_Kevin and 1 other 1 3
LSP_Kevin Posted June 9 Author Posted June 9 4 hours ago, thierry laurent said: The average amount per day is... rather incredible! 😱 It's funny you should say that, as the actual figure is somewhat higher. Normally, the forum software doesn't deduct deleted posts from the count, but a few years ago, when we upgraded the forum software, all the stats got recounted from scratch as part of the database update, and I lost a few thousand in the process! (I make a lot of admin posts that only need to exist for a short time, and are then removed.) Kev
LSP_K2 Posted June 9 Posted June 9 The glue that holds this place together, needs a high count. Congrats, Kev. LSP_Kevin 1
Archimedes Posted June 10 Posted June 10 Well done Kev - All you do is greatly appreciated by us all. Kind regards, Paul LSP_K2 and LSP_Kevin 2
